Full Auto + BS Attack (SF Mode)
Tema en '[Archived]: N3 Rules' iniciado por inane.imp, 24 May 2018.
Estado del tema:
  1. Mahtamori
    From where I stand this knocks the Kriza down from textbook OP to merely fantastic. Why would that merit a price drop?
  2. inane.imp
    28 Ene 2018
    Yes. But you can't use FA1 in reactive, so it can't be stacked with SF Mode anyway. And you can't use SF Mode in active.
    A chromedog le gusta esto.
  3. macfergusson
    5 Dic 2017
    Yeah, I was about to say, Level 1 already didn't stack with Suppression Fire..
  4. Triumph
    Good point.
  5. Hecaton
    Well, it was the previous interpretation of the rules. But the fact that points values aren't being adjusted for this tells you that points values aren't that scientific anyway. There's a lot of "we made this unit cheaper because we wanted it to be popular" going on.
  6. Armihaul
    Armihaul Well-Known Member
    What if the upcoming changes are to supression fire beign abe to shot on active turn, as it did in n2? Thar would explain why on order "supression fire" you can not apply FA
  7. xagroth
    How would that work? You can't move but can fire in Sup Fire against a target in range as a long order?
  8. Armihaul
    Maibe. Is just a guess. When declaring supression fire you can fire against a target, using supression fire rules. Is a complete order, so you dont gain some bonuses.
  9. Mahtamori
    More likely, you'd be able to declare BS Attack in active turn, just like you would an ARO, while in Suppression Fire state. That is to say these two of Suppression Fire (State) Cancellation clauses:
    • The trooper declares an Order.
    • The trooper declares an ARO different from a BS Attack using Suppressive Fire.
    Become this one:
    • The trooper declares an Order different from a BS Attack using Suppressive Fire.
    However, I do not think this will happen at all. Rather I think this is bringing a strong skill more in line with the performance curve that they intend these units to have, so it's a straight up nerf to a skill in an area where it is over-performing.
  10. HellLois
    25 Abr 2017
    The MOD of -3 of Full Auto L2 does not stack up with the MOD of -3 of Suppressive Fire.
    That wasnt the intention. we are wornking on edit and clarify the rule and add a FAQ
    Abrilete, toadchild, oren_dotan y 9 otros les gusta esto.
  11. eciu
    eciu Easter worshiper
    Can't blame Nomads for being spoiled by CB, can't you ?
    A Janzerker le gusta esto.
  12. eciu
    So like nobody on CB put an eye on those threads disscussing Full Auto ? (and that everyone was pointing out how nicely this combines with Suppressive Fire for a possible -9 mods (-3 supressive, -3 full auto, -3 cover))
    Yay......
    A Hecaton y xagroth les gusta esto.
  13. Armihaul
    Yes, nobody else can go -9 on supression fire as kriza does, just forget there is TOs and DDOs IPs wich have more BS, and/or smallet silhouette.
  14. xagroth
    It was mentioned extensively how it was not possible to counter that, while Camo levels have a direct counter on the MSV one to three.
  15. inane.imp
    28 Ene 2018
    To which it was retorted how you could counter it because it only applies to FTF rolls whereas TO etc apply regardless.
    It's largely a pointless argument.
  16. Armihaul
    But not all factions can counter all camo levels. Those factions are forced to use other ways.. Or do something that any faction can do: shot outside SF range. It isn't like he could impose a -12 that some others cannot negate neither
    Anyway, is their game and if that is want they meant it to be, that's ok with me. But still, there are other things that need to be addressed, but as they are not nomad, is not right to complain about them as with the kriza, right?
    A nazroth le gusta esto.
  17. eciu
    Not for that cost.
    Not to mention, you know that MSV do exist ^^
    On top of this mod is affecting units who do not want to shot Kriza ^^ (hacking and melee is still a thing you know).
  18. eciu
    You know this is not direct discussion about gameplay power etc. but just a fact that CB seems surprised that someone thought that FA2 stacks with Surperisse Fire.
    Something which was actually quite extensively discussen on their own forums (old one).
    <those script kids are really getting anying nowadays>
    A xagroth y Hecaton les gusta esto.
  19. inane.imp
    28 Ene 2018
    Go back to being bitter in the PanO forums. You're embarassing yourself.
    A TriggerPuller9000 le gusta esto.
  20. Zewrath
    Zewrath Elitist Jerk
    28 Nov 2017
    Yes, being slightly worse than a Hac Tao/Swiss Guard on active turn while being significantly worse than both on reactive turn, while being vulnerable to everything a non marker state HI can get screwed over by, as well as having an increased silhouettes while still remaining on the BS13 scale, which is rather mediocre for a supposed dedicated gun platform. That’s totally what I call textbook OP. I hope you never play against a sphinx or similar.
Estado del tema:
