Forté's Tóng Shi (Invincible Army)
Discussion in 'Miniatures' started by Forté, Jun 9, 2019.
  1. Section9
    Dunno about the tube, but Litko Aerosystems sells clear acrylic in any base size you care to specify.
    Forté and Golem2God like this.
  2. Golem2God
    Thanks #9 for the tip. I'll have to research their offerings and see what I can find to my liking.
  3. Forté
    Forté Well-Known Member
    For round bases I'd use clear acetate or even blister like plastic. Can get sheets of it on eBay pretty cheap.
    Plasticard is an alternative but I use clear acetate because it's usually cheaper and you can see what is going on through the clear stuff. Cut a piece so the ends match up without an overlap and tape over the join with standard tape.
    Green Stuff World have a UV reactive clear resin and also sell round metal base size cutters. They showed a few bases being done with those on their YouTube channel so maybe give that a look. Might be a simpler option than 2 part resins. Will advise a bit of vaseline on the inside of any barriers though to help with removal. I'm also use to sanding and polishing after going from 180 grit to 4000+ grit. Takes time but I'm a glutton for punishment.
    Golem2God and Dragonstriker like this.
  4. Forté
    Red done on the next two Zuyong. Hopefully finish them this week.
    #24 Forté, Jul 10, 2019
    Asreon_, Xeurian, Section9 and 3 others like this.
  5. Forté
    And that makes 4.
    Not sure which to do next though.
    #25 Forté, Jul 12, 2019
    Savnock, Xeurian, Oni and 6 others like this.
  6. Section9
    The Zuyong multi from Red Veil, if you have it?
  7. Forté
    Don't have that one so more thinking the Haidao next to make it a full fireteam.
    Then the Daoying sniper I have leaving the Liu Xing for last.
    Then look at expanding. A good proxy for Tai Sheng could be good. Maybe I'll just use the boarding shotgun Zuyong for now.
  8. Forté
    Been a while since I did some more but...
    I worked on the Haidao and Liu Xing last night.
    Just the grey areas and the Liu Xing flesh are done so far. And I admit, those diagonal sculpted details are going to be tricky.
    Still a way to go.
    Asreon_, ZlaKhon, Savnock and 8 others like this.
  9. Awash in Blood
    Awash in Blood Agent of Devastation
    Most of the links for your early pictures are broken. :(
    Forté likes this.
  10. Forté
    Well that's annoying because I upload them directly to this forum. Brilliant.
  11. Forté
    Images all re-uploaded.
    Not happy but also happy they're there again.
    jherazob, Section9 and Awash in Blood like this.
  12. Forté
    Got an hour in tonight. Just worked on the Liu Xing.
    Asreon_, Oni, Daimeow and 7 others like this.
  13. Savnock
    Savnock Nerfherder
    I really, really like your red. Like my own though, I'm a bit sad to see the darker crimson hue mostly covered by the brighter red in the final shots... but those dark hues just don't pop as much on the table.
    And great high-gloss white highlighting. Looking forward to seeing the next group shot!
  14. Forté
    Wow. Has been near three months since I did more on these. Glad I worked on the Haidao today. Need to get these finished and get some momentum back into my painting.
    Thank you for looking. Hopefully have more done by the end of the week.
    Asreon_, Usashi, Xeurian and 6 others like this.
  15. Numazokola
    Numazokola Well-Known Member
    awesome!!! im planing to get some invincibles and make them as jade warriors... inverting the red and green. What do you think?
  16. Golem2God
    Sounds good to me. Hope to see some pictures when they are done.
    Forté and Numazokola like this.
  17. Forté
    Sounds good to me.
    Numazokola likes this.
  18. Forté
    Slow one today. Just did some work on the textured armour parts in green.
    Hopefully have these done by the end of November which will give me six finished, one to paint, and a load of decisions to make about what to add.
    Oni, Xeurian, Asreon_ and 10 others like this.
  19. Numazokola
    Rui shi and zencha maybe??
    Forté likes this.
  20. Forté
    Possibilities for sure.
