[EN][ES] JANUARY'21 Painting group / Grupo de pintura
Discussion in 'Miniatures' started by Koin-Koin, Jan 1, 2021.
  1. Koin-Koin
    A new year just started so a new month did it to.
    Let 2021 be full of fulfilled pledges.
    Rules:
    1) Post a picture of an unpainted/primed Corvus Belli miniature you pledge to paint.
    2) Paint it within the month, post your proof (PICS or it DID NOT happen).
    3) Rinse and repeat as much as you like.
    4) You can re-pledge a miniature next month if you didn't finish it.
    5) Enjoy and learn!
    Perdón por el retraso, y por abrir tarde el hilo también...
    Reglas:
    1) Postea una foto de la miniatura de Corvus Belli sin pintar o imprimada que te comprometas a pintar.
    2) Píntala dentro del mes, postea unas fotos del resultado.
    3) Pinta todo lo que quieras.
    4) Puedes repetir una miniatura si no la has terminado.
    5) Divierte y aprende!
    Golem2God and KGG like this.
  2. Uthoroc
    Uthoroc Well-Known Member
    My January pledge, equal parts Ariadna and Haqqislam (well, not size-wise). PledgeJanuary.jpg
    Golem2God, KGG and Koin-Koin like this.
  3. Golem2God
    Wow the new new Mirage-5 models look nice. And that Dogface is big. Is he any bigger than other Dogface models or around the same size?
  4. Koin-Koin
    As Maggie's done I can't paint anything else than her pilot.
    As I try priming with gesso for the first time I made a comparison: unprimed, primed with too diluted gesso then dried with an extra layer.
    I don't notice any detail loss so far.
    jherazob and Golem2God like this.
  5. Golem2God
    @Koin-Koin That Gesso technique looks interesting. Was the effort worth it in your opinion?
  6. Red Harvest
    Gesso on metal is tricky to get right. First, keep the brush damp, not wet. Do not thin the Gesso, and do not let the brush get dry... Ah, now you begin to see why I won't recommend it, even though it is a nice primer. I prefer white Gesso, since I've been using it as a primer for things since, er, uhm, Jimmy Carter was president.
    Anyone pledge the Defiance set yet? C'mon, you know you want to. ;)
    Koin-Koin, jherazob and Golem2God like this.
  7. Golem2God
    I've actually never heard of Gesso until now. What exactly is it anyway?
  8. Koin-Koin
    Gesso is basically primer for artists.
    If I understand correctly it's some chalk powder mixed with a binder. It works on fabrics, wood... Almost anything (I've seen it used to repaint a mug).
    I'm only starting with it so @Red Harvest is the one you must trust.
    The main property seems to be what makes it both incredible for results and tricky to use on minis: it shrink a lot. I mean A LOT.
    I had to do several retouch this morning. I think it's because I thin it too much. It is recommended to use it straight from the bottle (a tube in my case) or up to 80/20.
    #8 Koin-Koin, Jan 2, 2021
  9. Uthoroc
    No, he's pretty much the same size. Even not quite as tall,due to his hunched posture.
    infyrana, Koin-Koin and Golem2God like this.
  10. Uthoroc
    I sure want to, but my pledge is still on the boat! :joy:
  11. Koin-Koin
  12. Mob of Blondes
    Primer. In the past, whatever binder they had with some filler & pigment, mostly chalk as Koin said. Now it's mostly acrylics as "glue". One I got smelled like white PVA glue. No idea how the transparent one is made, maybe it's like matt medium.
    Shrink / contract? Stretch sounds "reversed".
  13. Koin-Koin
    Shrink indeed.
  14. KGG
    KGG Well-Known Member
    First time joining the painting group. Fairly new to painting too and slowly trying to improve with highlighting and freehand work.
    I’m hoping to get uhahu and domovoi completed this month.
    Uhahu will be a REM Racer/Mary problems proxy:
    Domovoi will be a Krakot Renegade proxy based on ‘Drax’ from Guardians of the Galaxy:
    AAB7E65D-6000-4C8E-ABCF-B10AD4D88EE2.jpeg 3EF30F75-5786-4D3B-8B7E-DEE6343DD116.jpeg
    #14 KGG, Jan 11, 2021
    Oni, Koin-Koin, Uthoroc and 2 others like this.
  15. jherazob
    Gotta hack them all!
    KGG likes this.
  16. Law Dawg
    Gesso can be bought at any art craft store. It's used to prime canvasses for painting (usually 2-3 layers with sanding in between). I usually only use gesso when it's too cold or humid to use spray cans. If you want to use gesso use it on a test model first. The first time I did it I used it straight and glopped it on a Space Marine with plasma cannon. As Koin-koin said it shrank incredibly well but the thicker part obscured fine details somewhat. It wasn't bad, just that details are less sharp.
    When I use gesso now I tend to thin it with just a little acrylic medium to help it flow and pay more attention to avoid big clumps. I also mix in a bit of black paint so I get a grey primer.
    These two models were primed with gesso
    Oni, Stormygeddon, jherazob and 2 others like this.
  17. colt
    colt Novyy Bangkok merc
    well I'm going to start painting aida swanson
    Golem2God and Koin-Koin like this.
  18. flavius
    flavius Active Member
    Hey my first post ...
    I am a bit late - but I try to paint this fellows - it will be close - but I give it a try IMG_20210115_102203733[1].jpg
    Uthoroc, Golem2God and Koin-Koin like this.
  19. Koin-Koin
    Never too late to start painting.
  20. colt
    HellLois, Oni, Uthoroc and 4 others like this.
