Dodging to engage a model entering Camo/Marker state (all at once question)
Discussion in '[Archived]: N4 Rules' started by Triumph, Oct 28, 2020.
  1. kinginyellow
    nah, the camo marker can declare idle + cc attack / dodge to get away from the non camo guy (who will aro with hold + his own cc attack / dodge), and the non camo guy can declare idle + dodge (assuming the camo model doesn't reveal itself). so not 100% playable like the engage up a wall situation from n3, just very very weird situation.
    But agreed, The answer just needs a resolution, regardless of which one is picked.
  2. Triumph
  3. mightymuffin
    My first question to all of this is how is the Shang Ji able to declare Dodge if it doesn't have LoF to the Zero? And if the former does have LoF then surely the Zero can't re-camo cos there's a model looking at it?
    Abydog likes this.
  4. colbrook
    You can Declare Dodge at -3 if the active trooper is in your ZoC.
  5. Abydog
    Abydog Well-Known Member
    but the Zero has stealth, doesnt that deny the aro in the first place?
  6. Abydog
    maybe not everyone able to enter a camo or for that case impersonation state has stealth, but as it was a nested skill in n3 I would assume everyone does.
  7. colbrook
    Re-camo is an entire order, so does not benefit from Stealth.
    inane.imp, Abydog and Stampysaur like this.
  8. Abydog
    that's true. very interesting. the wording for stealth in N3 was the same as now as far as I can see. So this situation has not come up in years of N3 (when the dodge still was engage)?
    I guess one has to asume that the dodging model can reach the zero and so he won't enter marker state and does nothing. and is murdered in c.f. in the next order ;)
  9. Sabin76
    The big difference is that you couldn't do it in N3. In N3, you could only change facing if you did not have LoF (required for recamo). Now you can dodge with movement and reach B2B without LoF.
  10. colbrook
    You couldn't Dodge or Engage without LoF in N3, only Change Facing.
  11. toadchild
    The only precedent we have for resolving this is in the sequencing of dodge moves themselves. That establishes that the active model goes first. If I had to provide an on-the-spot TO ruling, I would use that to say that all active player effects are evaluated in any order, followed by all reactive player effects in any order.
    Edit: I had initially stated the order backwards. Overall premise is the same, but details have been corrected.
    #31 toadchild, Nov 5, 2020
  12. Triumph
    That's the opposite of how Dodge resolves though, active player first reactive player second.
  13. toadchild
    Derp, my mistake. I’ll edit the post for clarity and correctness.
    Myomer and inane.imp like this.
  14. Triumph
  15. toadchild
  16. Triumph
    Bumping the thread to see if there's an answer yet
