Hi guys, We have a doubt regarding the interaction and resolution of the Dodge ARO against a Move+Move situation. The doubt comes from the rules of Dodge, as the movement of the Dodge action take place on the 6.1 step of the order, the effects step of the resolution, after all the movements have been done by the active player. Situation is this: 1) Player A declares Move as first action, measures and moves, and while doing so enters ZoC of player B 2) Player B declares Dodge as his ARO 3) Player A declares Move as his second action, measures and moves 4) Player B does the Dodge roll and succeeds 5) Player B does the Dodge movement...but Player A is now outside his range, even through when he could declare the ARO was in range of the Dodge movement And here is where things became weird, as there are two opinions: Opinion 1) Given that everything "happens at once", player B can Dodge into contact with player A as during A's movement, there was a point where he could reach with his Dodge movement (at this point there are also 2 options): Option 1.1 -> The troops stay at the point where B reached A using his Dodge movement Option 1.2 -> The troops stay at the end of A's movement even if that makes B teleport Opinion 2) Given that you do the movements during order declaration, but Dodge movement is done AFTER, during Effects step in the resolution, at that moment, player A is out of range, movement of Dodge can be done, but you can't reach close combat. We've been reading the rulebook, the FAQs and wiki, but nothing is crystal clear yet. Oh mighty @ijw , help us! Thanks!
It's option 2. You make your dodge movement and if you reach silhouette contact with the model where it is at the end of it's move then you can if you can't you can't
Straight out of wiki: Spoiler: Wiki for Dodge and Order Expenditure Sequence Movement and placing miniatures at their final position is part of Step 3 of the Order Expediture Sequence. Rolling dice comes with Step 5, applying effects like the Dodge movement with Step 5.1. The 4th Bulletin of the Effekts of a succesful dodge mentions, that the dodging modell can enter engaged state as long as the movement is enough to reach Silhouette contact with that enemy. When the MOV-MOVing modell is out of range to the Dodge-movement, there is no way of entering engaged state. There was a time i remember when folks like daturazi could hang on bikes that drove by, but i think the order expenditure sequence made sure this will not happen again.
