DHD might actually work
Tema en '[Archived]: N3 Rules' iniciado por TheDiceAbide, 9 May 2019.
  1. Berjiz
    Berjiz Well-Known Member
    15 Jul 2018
    I think the best solution might be to move the checking of requirments from declaration to when it's executed. So you can declare whatever you want but if it's not possible to use when the order happens it gets turned to idle.
    A ChoTimberwolf le gusta esto.
  2. Sabin76
    Big problems with this... not least of which is giving every single model a potential ARO every time you move (including HD units).
  3. toadchild
    22 Feb 2017
    I think you would still want to keep the rule where you need LoF or ZoC (or Hacking Area) to receive an ARO trigger in the first place.
  4. Berjiz
    15 Jul 2018
    Yeah the ARO trigger would stay as it is. The point is to that you no longer can get forced into declaring AROs that you don't want to declare
  5. Mahtamori
    Marker uses Sixth Sense to Delay ARO
    Fusilier declares BS Attack on Marker
    Marker curses in French
  6. toadchild
    22 Feb 2017
    Chasseurs are definitely an interesting corner case when talking about changing this level of core rules. I don’t think anyone else has the combo of Sixth Sense and a camo state.
    Sometimes you can’t streamline one thing without breaking another - do you think that losing this interaction would unduly hurt them? Camo is still strong and Chasseurs still have good weapon options to force bad choices.
  7. Cartographer
    It also further screws CC, as forcing a "change facing" ARO goes away.
  8. Mahtamori
    I don't honestly know. I think it hurts MRRF a lot more than Chasseurs in isolation. Chasseurs have such perfect skills and gear for a skirmisher.
    A toadchild le gusta esto.
  9. toadchild
    22 Feb 2017
    True, although stealth probably covers a lot of that.
  10. Section9
    Very much agree with this.
    A Hecaton le gusta esto.
  11. Berjiz
    15 Jul 2018
    That's actually part of the point and why I had the idea. In my opinion any forcing a wasted ARO in the form of "I know declaring X is best and that is want I want to do but I can't because of Y" is bad design, and most(all?) of those interaction seems to be uninteded and is not something that rules explicitly allow. However I don't think situations such as an hakcer being able to chose between hacking or bs and forcing a bad aro on the reactive unit.
    But that would mean that CC needs a buff, which is probably true anyway.
  12. toadchild
    22 Feb 2017
    Not necessarily, if you don’t lift the restriction on what you can declare for a ZoC ARO. Even if you don’t check requirements until skill execution you still can’t declare BS Attack from a ZoC violation.
  13. inane.imp
    28 Ene 2018
    Right now, there's no restrictions on what you can declare for a ZOC ARO. Either you meet the requirements at declaration or it's not valid.
    You'd need to Introduce a 'if the ARO is generated due to X you can only respond with Y'.
  14. toadchild
    22 Feb 2017
    You’re right; I managed to get the restricted skills list from CC crossed with this in my mind.
