Decapitation and unconscious Lt
Discussion in '[Archived]: N3 Rules' started by CabalTrainee, Jul 4, 2018.
  1. Hecaton
    Makes it nigh-impossible to score with Stun Ammo.
  2. inane.imp
    Not really. There's only ~65% odds they Reset out of the IMM on the order you attempt to put them Unc. I'd hardly call 2 orders and ~15% odds (assuming ~40% odds of doing only a single wound) of success 'nigh-impossible'. OTOH it is clearly sub-optimal but that's evidently a feature, not a bug.
  3. Spleen
    Spleen Well-Known Member
    Simultaneity wouldn't really allow room for CoC to work the way you want either, you're still left with:
    "Model X was the LT when they entered a null state they never returned from" you just then also append "and CoC kicked in at the same time"
    Any interpretation where the model in question isn't the LT when doing the mission check is not simultaneous, it's applying CoC first.
    I agree that it's a bit frustrating that CoC is actually a liability in these missions, but the RAW doesn't leave much room there.
  4. Mahtamori
    As written I agree, but we're dealing with a free form answer in an FAQ not a set of rules text, so asking for clarity regarding what timing they had in mind for the two effects is absolutely called for.
  5. Hecaton
    It seems weird unintended that you can't just knock them unconscious and *then* stun pistol them.
  6. ijw
    Unless CoC is involved, they'll still be the LT until the start of the player's next turn, so putting them Unconscious and then IMM should be fine.
  7. inane.imp
    This is what happens when you stare into the abyss too long. I literally had this right in my first post and then screwed it up. Oh well.
  8. Hecaton
    Special skills stop working when you're unconscious, and the LoL rules themselves imply that a lieutenant stops being a lieutenant when they enter a null state.
  9. ijw
    No, they really don't.
  10. Hecaton
    Notice that at this point it's not a matter of "your Lieutenant is in a null state, and thus you must choose a new one" but rather you don't have one at that point, period. Like other skills, Lieutenant stops working once you go unconscious and you lose your Lieutenant as soon as the old one goes into a null state.
    Of course I can bet that CB didn't think that hard about it when they made their FAQ ruling.
  11. ijw
    You're misreading/misrepresenting the text you quoted. Logically, it's 'if you don't have a Lieutenant, OR your previous LT is in a Null state etc.'. Two separate clauses.
    The other issue is that the LT Skill includes:
    My emphasis.
    Thirdly, LT is a status as much as a Skill, as the only trooper that ever has the Lieutenant Special Skill is the one that you initially choose in your army list.
  12. Hecaton
    Bummer. Awkward wording used there, maybe it makes more sense in Spanish. Lame that Chain of Command protects Lts in that mission from the "club 'em and stun 'em" trick. Tohaa are even more of a powerhouse in this mission.
