Deactivating MSV
Discussion in '[Archived]: N3 Rules' started by Knauf, Aug 2, 2019.
  1. Hecaton
    Well it goes back to Smoke being probably the most powerful ability in the game.
    meikyoushisui likes this.
  2. Ogid
    Ogid Well-Known Member
    That doesn't work for everyone; and even if everyone had those tools, that would force to every list to include that combo; which limits the ammount of viable lists.
    Plus your linked MSV2 sniper won't be able to cover the full board unless the board is really bad designed
  3. Knauf
    Knauf Transhumanist
    It can't just be designed to be a net positve, that much is clear:
    - it should require a significant investment (e.g. full order/command token/loss of other functionalities as mentioned by @SpectralOwl)
    - it will enable your opponent to leverage Smoke/ODD/Camo troops agaist you when they previously couldn't
  4. daszul
    daszul Well-Known Member
    Against Eclipse you are right,
    but White Noise to me is more like in GitS,
    where you can have your cybereyes hacked to simply induce a 'Blind Spot':
    You can not see that you can not see what you can not see...
