  1. Section9
    For older minis, yes. Pre-CAD sculpts!
    For newer, CAD sculpts.
    You can also use Hasslefree on CAD sculpts, though you're going to have to sculpt your own hair.
    jherazob and Golem2God like this.
  2. Bors
    Bors Beltalowda Nomad
    So, the answer is - Statuesque Miniatures FINE SCALE for old models and PULP SCALE for new line in infinity? Someone tried to use them? Any pics maybe?
    I used in past Hasslefree heads, but I think they are a little to small for this.
    Golem2God and jherazob like this.
  3. Malleus011
    Malleus011 Well-Known Member
    I use Statuesque fine scale heads for a lot of Infinity conversions (I'm nowhere near as good as most of the guys on here, but these should help for scale)
    [​IMG] - Patsy conversion on Joan body
    [​IMG] - Bipandra conversion on Bolt medic body
    [​IMG] - SAA Engineer conversion on SAA regular body
    [​IMG] - Tomcat conversion on a ALEPH Spec Ops body
    Does that help?
    Section9, Abydog, Usashi and 8 others like this.
  4. Dedled
    Dedled Speculo Agent
    I decided to try something a bit different with my Medchanoid.
    It's basically a transport unit for the Nanobot cloud that performs the Doctor and Engineer role.
  5. Golem2God
  6. mittenninja
    mittenninja Invincibles NCO
    Finished up my Ghulam conversions, so here's the whole crew together.
    DustGod, Tongfa, Deltervees and 11 others like this.
  7. Ugin
    Interventer conversion, with the torso of Danavas, legs and right arm from female Interventer, and the left arm of female Moderator.
  8. ThananRollice
    I. Love. This.
  9. archangeleong
    Authorised Bounty Hunter on Bike WIP.
    I wanted to get her looking more like the pinup style artwork in the N3 books
  10. Bors
    Yest. Very Much. I was thinking about Statuesque, but had no size comparison. Which sets you used? Now I see there is some problem with availability.
  11. FireFangs
    FireFangs Space Oni
    I have that one on my list as well, though I'll go for the normal pose and custom color scheme. Largely because I don't want to cut the hand from the gun. Cutting the head on the Kuroshi was hard enough. x_x
    Good work though!
    #1431 FireFangs, Sep 30, 2019
  12. Musterkrux
    Musterkrux Well-Known Member
    It took a while, but inspired by Archangeleong's work above, I've cooked up my own RoboGeisha using the Malifaux Geishas from the 'Youko Core box':
  13. Golem2God
    I had the same problem with availability but the owner of Statuesque Minis was able to provide the sets I wanted even though they weren't posted as in stock on the site. Just look over the different sets in the heroic section and send him an email asking if he has this set or that in pulp size. He should answer you back shortly.
    #1433 Golem2God, Sep 30, 2019
    Bors and jherazob like this.
  14. Section9
    Bors and Golem2God like this.
  15. cazboab
    Last year during Kurage, I came up with the idea of using Haqqislam minis to fill in for FRRM, as the Merovingian Foreign Legion.
    I've decided to make it permanent, and I'll be paining these blue with red and white bits soon.[​IMG]
    I have some resin 7.62 belts to finish off the M60, I'll find them tomorrow. Not sure about the heads, might swap them out for helmets at some point.
    Just like the Moblots, the heads are possibly not staying on... I'll probably grab a few more Ghulams to make an M60 gunner, a d-charge carrier and a D.E.P.
    Abydog, Del S, jherazob and 3 others like this.
  16. SuperD
    SuperD Well-Known Member
    Neat missile launcher bit! Where's that from?
  17. cazboab
    Both the at4 and the rpg are from project z spec ops kits from Warlord games.
  18. ashigaru
    ashigaru Member
    I'm so slow to respond! (sorry)
    The spear is a plasticard Rod and I then cut the Guijia sword down and had to sand/sculpt it to that shape. The haft is the butt of the same sword.
    Golem2God and Deathwig like this.
  19. Malleus011
    I ordered one of every fine scale pack he had at the time. ;)
    Section9 and Golem2God like this.
  20. Golem2God
    That was a good idea. Though, like I said before, I think pulp size is more in line with CB's current sculpts.
    Section9 likes this.
