What happens then trooper with entire order skill 'climb ' tries to climb onto the roof, but there is no phisical way to place the model - as other enemy trooper is already on the roof? It's stays hanging on the wall and can't do anything else next order only climbe? Antoher case - what happens if climbing model can be placed only in btb with the enemy trooper, does enemy gets free aro? Can a trooper be deaploed at the begining of the game climbing on the wall if he hasn't climbing plus ?
1: If you can't place the model, you can't move there. Note: Not being able to tell whether there's room on the roof is a rare occurrence. 2: Apply Order Sequence as normal. Yes, since you made an Entire Order skill your opponent will get to react to your skill without you being able to fight back. Note: Having to climb up into BTB with an enemy is a rare occurrence, but having to climb up into a hailstorm of bullets is fairly common when you're trying to climb near enemies. 3: Yes, Climbing isn't a state, it's just a place the model is placed in with certain restrictions.
