Chromedog's log of terrain and stuff.
Discussion in 'Scenery' started by chromedog, Oct 26, 2018.
  1. chromedog
    Getting there.
    Corner trims added to hide a couple of gaps. Still have to add rust to those. Window cracks applied.
    LeGweg, Errhile, jherazob and 4 others like this.
  2. chromedog
    I never asked to be augmented, Alex.
    Adam and Alex Vega, my 2 Authorised bounty hunters for my O-12.
    Errhile, jherazob, Koin-Koin and 3 others like this.
  3. chromedog
    Mostly done. A few more bits of graffiti to go, and some final weathering (it was getting too warm, and the paint was drying too quickly coming out of my airbrush, even with flow improver and drying ret*rder.)
    I've got a long access ladder or some fire escape sections to go onto the back (plain) wall. Which will be added after these areas get a matt varnish (the undamaged windows will be glossed).
    Errhile, Koin-Koin, Wizzy and 4 others like this.
  4. chromedog
    Another new flier for the table.
    13 years ago, I missed out on grabbing one of these - but they've been re-released for A2.
    The scorpion gunship.
    Pictured next to the Sea Wasp from TWOW.
    The engine nacelles pivot forward or backwards, too (as well as having blades that spin).
    LeGweg, Errhile, Jumara and 6 others like this.
  5. Koin-Koin
    We finally find an interest in Cameron making a sequel: those toys are back in stores :grinning:
    Space Ranger and chromedog like this.
  6. chromedog
    I have a background in propmaking, so I'm always interested when certain film-makers push the envelope with film making techniques (and why I still buy dvds and blu-rays. They often have BTS stuff that is faaaaar more entertaining to me than the actual feature.
    That said, more toys from a Cameron film don't go astray.
    nehemiah likes this.
  7. chromedog
    I finally got around to building myself a spraybooth for my airbrush.
    Started with a 120l plastic storage tub. Added some 90mm plumbing pipe, some timber (for framing/structure) and a 90mm 12v fan.
    The filter is a cheap pot scourer (it's the same sort of material that a "proper" spraybooth filter is made from, just thinner). It's there for "proof of concept" and it did the job. No paint or propellant solvent went through to the actual fan (the blue paint on the filter is from a rattlecan). I've since acquired "proper" spraybooth filter fabric.
    There's a LED desk lamp visible above the airbrush and holder. It is powered from the same power supply as the exhaust fan. Just basic electrical connections.
    The turntable is a cake decorating one I picked up at an ALDI store
    I still have to add a guard over the fan itself - which is also relatively quiet at around 40db - it only pulls about 54cu.ft/minute, which is nothing compared to my last spraybooth (where the extractor fan moved 65,000 cfm. and HOWLED - around 110db).
  8. chromedog
    While reading through the doc for ITS15, I came across the entry for "QAZ " critters. Ostensibly, little more than a 25mm based S1 marker (but the doc suggests "the Sasok Creatures" from TAG Raid, or the Taigha Creatures, neither of which I have - since I neither play combine/morats nor had any interest in TR) so I went through my bits box and with a little GS as well, made these little markers up. They'll probably only be a thing for a year or so, and might see a table three or four times in that timeframe - but I prefer a 3d marker than just another 25mm token that will get lost on the table otherwise.
    They were originally some kind of newer tyranid greeblie for 40k (picked up the sprue for a few $$ at a bring & buy, figuring I could use them down the track for something). The green tentacles are the nth-dimensional expression of the quantum anomaly zone into 3d space (while the greeblie is "the elder things from beyond" otherwise known as the QAZ creatures.
    jherazob and Koin-Koin like this.
  9. chromedog
    It's been a long time between drinks.
    More terrain. I picked up a couple of these OOP Plast Craft Games YJ Shopping Centre kits a while ago. I finally got around to assembling one of them. As is usual for me, I made some small modifications (the roof pieces got replaced, because that corrugated polypropylene board has never bonded properly to the pvc.) So I used 3mm foamed pvc sheet for the roof. The rest of the kit is mostly 2mm foamed pvc. I also extended the walkway on the first upper level. I have to ink in the panel lines on the roofing (they are marked, but before I could do them, life got in the way, in the form of a family member's funeral).
    I did, however, manage to get the sign lit up, also. It will join the other lit up buildings on my NewHokk board.
    NewHokk city board.
  10. Koin-Koin
    Did you put extra paint job on it or is it raw from the box?
    Because those pre-colored terrains are impressive.
  11. chromedog
    Only the roof panels (two upper and one lower) and the little extension around the back were added by me. I've got to add some more paint to the roofing and mark out some panel lines and some of the walkway around the back.
    The rest of that impressive colour scheme is all PCG.
    Assembled using nothing else but some superglue and the pictures on the box (some of their older non-colored stuff had instructions).
    Koin-Koin likes this.
  12. Koin-Koin
    Yeah, that's the roof part that makes be wonder indeed.
    Thanks for the explaination
