So I'm definitely not handy enough to drill out holes to magnetize these guys. What is the best build for coppers if you only had two to build at the moment.
Well, magnetizing them by placing one magnet in the socket, rasping down the pin on the weapons you want to use and drilling a fitting hole on that position to place a second magnet there is the best and easiest way. Especially the Copperbots are really handy for this. If you can't do that, some putty may work for some time.
Depends if you are playing starmada or vanilla, Starmada: TR and a flash REM Vanilla: TR, Missile bot or couble flash rem depending on your list building preferences.
For anyone going ahead with magnets, use something like plastic wrap film between the magnets. That way if glue overflows, it does not glue the magnets to each other.
Thank you for being the only person not offering input on magnetizing since I stated in my first post that I wasn't going to be magnetizing. Sounds like I def need a TR for now.
REMS all look similar enough. Build what looks neat and then be like, “Hey opponent, this one is a TR HMG bot.”
