Base sizes for older miniatures
Discussion in 'Miniatures' started by evilmonkey, Feb 20, 2019.
  1. evilmonkey
    evilmonkey That man over there
    I remember back when N3 came out that they changed the base sizes for a lot of older miniatures but I cannot seem to find which bases changed. Is there a list out there or does anyone have a link to that old announcement? I pulled out some old Pano and figured it was about time I rebased them to the correct sizes. Thanks for the help.
  2. chromedog
    It's probably easier just to ask what you have.
  3. Golem2God
    @evilmonkey The current base sizes are 25mm, 40mm, & 55mm.
    25mm is for a 1-3 silhouette size.
    40mm covers the 4-6 silhouette range.
    55mm is 7 & above.
  4. Golem2God
    What unit/model are you trying to rebase? That info would go a long way to help your predicament. Just find the unit in CB's army builder look at the unit's S/silhouette size. You should then know which base size you'll need.
  5. chromedog
    Not quite.
    S1-2 is 25mm.
    S3 is 40mm.
    S4 is 55mm
    S5-6 is 40mm
    S7 is 55mm
    S8 is 80mm.
    Some profiles have skills that will modify their S value (sapper for example, changes an S2 to an S4 while you use it).
  6. Golem2God
    @chromedog Thank you for correcting my mistakes. I'm sure that your numbers will help evilmonkey's debacle.
  7. evilmonkey
    Thanks for the info. Looks like they need 55mm bases. Just a cutter and a couple of Bulleteers.
  8. colbrook
    I got 2mm MDF disc bases and simply glued my old TAGs and Bulleteers, old base and all, on top, then reflocked the whole thing so they look like they're on a little hillock.
  9. Arkhos94
    Customeeple used to sale plastic rings to transform your 40 mm base ino a 55mm ones, they are likely still somewhere on their webstore
  10. Section9
    Yup. TAGs went up to 55mm bases (with some exceptions), and all the combat and baggage REMs also went to 55mm bases.
    Golem2God and chromedog like this.
