Ariadna in N4
Discussion in 'Ariadna' started by psychoticstorm, Aug 6, 2019.
  1. dhellfox
    if they do add an ariadnan tank instead of a tag how would you think it work? a tag with motocycle and heavyweight skill and 10 armor (since tags are meant to be lightly armored vs conventional war machines)
  2. Stiopa
    Stiopa Trust The Fuckhead
    Ratnik isn't bad, but I found HRL loadout a bit underwhelming. Also, it'd be good to do away with Lo-Tech altogether.
  3. dhellfox
    i feel Lo-Tech would be more interesting if the Ariadna HI P-armors degraded over four wounds although depends how its done can be easily game breaking. but yeah i agree with you in its current state
    #183 dhellfox, Mar 2, 2020
  4. FreezeZ
    FreezeZ Well-Known Member
    I just cant fit him anywhere. He is bit expensive for his kit. But propably I just need to test him more.
    S7 or S8 motorcycle could do a trick but it would be very dependent on scenery. It would be less mobile Maghriba.
    Kreslack likes this.
  5. Stiopa
    Tanks are unlikely to happen because anything that would really qualify as a tank would be much heavier than ARM 10 with STR 3/4. What we're describing would be more akin to an IFV. TAGs fall somewhere between light IFV and heavily armed scout car.
  6. Imperator Wolf
    I would be interested in seeing what non-TAG units the sectorials might get. Right now TAK has 4 more units available to it the USARF and 5 more then CHA, not including characters.
  7. McKaptain
    McKaptain Well-Known Member
    I don’t disagree. Buuuut, I will say, if CHA has a CoC option, it would pretty much become a mono-build faction. With so many cheap irregular orders, I couldn’t imagine building a competitive list other than Wallace/CoC.
    Stiopa likes this.
  8. dhellfox
    for the missile ratnik being overpriced, maybe give it full auto L1?
  9. colbrook
    Eh, I'd rather see dual HRLs as that's what the model has.
    Modock, Foxep and McKaptain like this.
  10. SpectralOwl
    You don't have to go all the way with CoC. Veteran L1 on some of the mid-price veteran units like the Scots Guard and Highlander Greys would mitigate the issue nicely and let you do things during the LoL turn, but losing Wallace would still be appropriately painful.
    LankyOgreBP and Foxep like this.
  11. McKaptain
    That actually sounds like a pretty good solution and makes Scots Guards a more palatable option in general.
    RasPuto likes this.
  12. Cloud
    Cloud Well-Known Member
    I think that the Unknown Ranger, like a big ranger, it deserves some kind of airborne or infiltration deployment.
  13. McKaptain
    I like that. I would think Airborne, because him showing up not deployed with the boys and coming to save the day out of nowhere seems to fit the fluff.
    RasPuto and Cloud like this.
  14. SpectralOwl
    With N4 dissecting Camo it could even be an extremely rare Hidden Deployment unit without any Camo state at all, just appearing out of the blue to shield-bash passing soldiers. Both Airborne and HD would give his CoC profile an even worse case of Kirpal Singhitis than the original though, since he's more expensive and USAriadna has even more vulnerable LTs than Acon.
    Foxep, Cloud and McKaptain like this.
  15. McKaptain
    I had a new unit idea today, specifically for USARF. With camo being detached from vis mods, I would like to see a Green Beret profile. You could give them infiltration and TO but no vis mods to represent their knack for becoming part of the local population. I wouldn’t make them super amazing at anything. Decent BS, stealth. And then scavenger and D-Charges with an Engineer profile. They could even be an irregular profile to represent their long service behind enemy lines.
    Essentially it would be a USARF flavor of Irhmidino. Enough different to have its place and compete for that slot in vanilla.
    RasPuto and Nuada Airgetlam like this.
  16. FreezeZ
    I have this feeling that new YJ drone is what out kuryers should be.
    Nuada Airgetlam likes this.
  17. cazboab
    I think kuryers are fine as a mid level fire support option, but the problem is they're the top end of mechanised assets that Ariadna has access to, and they're only in TAK. The regular muls are just enough cheaper to make them a better option for order heavy lists, but the kuryers don't have enough extra to make sense in limited insertion or tactical window when the trooper slots used by them and the Dozer could be filled with Frontoviks or Veterans...
  18. MATRAKA14
    MATRAKA14 Well-Known Member
    A remote with camo seems too high tech to me, or at least it seems difficult to camuflage a big traktor mul.
    But I expected something more creative/playable instead of a regular mul +1bs
    The only mul that works realliably is the minesweeper. The rest of them are plain bad, there is no point on using them and the kuryer is a missed opportunity to have a unique and fun profile.
    They are not fine by any means.
    cazboab likes this.
  19. Nuada Airgetlam
    We successfully camouflage semi feral Antipodes.
  20. kanluwen
    kanluwen Well-Known Member
    Lo-Tech was one of those "cool concept, lackluster execution" things I felt. They coulda been something cool.
    Stiopa likes this.
