Antipode Assault Pack in Camo State
Discussion in 'Ariadna' started by IJewett, Feb 26, 2019.
  1. IJewett
    IJewett Member
    I have seen and read where players are using one camo marker for the Antipode Assault pack. If this is how they work could someone explain to me how that works in the rules. This makes them much easier to move around as well as easier to bypass ARO units.
    If its just players doing so for convenience then please also let me know.
    SirGrumpyPants likes this.
  2. Chrysis
    Chrysis Member
    Check the timestamps on what you're reading. That's how the packs used to work in a previous edition, but not anymore.
    chromedog, SirGrumpyPants and Abydog like this.
  3. IJewett
    IJewett Member
    Thank you very much. The specifics was a Video Battle Report from 4 days ago. So they were misplaying.
  4. SirGrumpyPants
    SirGrumpyPants A little grumpy
    Yep, old rules. Now each doggo gets its own 40mm camo marker.
  5. Barrogh
    Barrogh Well-Known Member
    It seems there's a connection between willingness to make Infinity video battle reports and inability to update oneself on rule changes that happened like 5 years ago or so.
    On a side note, AFAIK it wasn't just doggos, all camo troops could stack up to three in a single marker, and camo markers were always of the same size back then, regardless of what was inside and in what quantities.
    YTonic, Tongfa, Hecaton and 1 other person like this.
  6. Tongfa
    Tongfa ULTRA INSTINCT UKR
    [QUOTE="On a side note, AFAIK it wasn't just doggos, all camo troops could stack up to three in a single marker, and camo markers were always of the same size back then, regardless of what was inside and in what quantities.[/QUOTE]
    Sigh, the good old days.
    Edit: quote function memed me again.
  7. Chrysis
    Chrysis Member
    I think I might have just watched the Battle Report in question. It's just a straight up mistake, but the two people in question make quite a few mistakes, no matter the game system. Good for entertaining reports, not so good for rules accuracy.
