Xenotech deployment question
Discussion in '[Archived]: N3 Rules' started by Romulas, Oct 20, 2018.
  1. Romulas
    Romulas Active Member
    question popped up locally:
    Does the xenotech deploy in the normal deployment zone, or if a mi model that meets the requirements deploys in its new 4" advance does the xenotech deploy ahead as well?
    Tried to see if it was already answered but that is a lot of salt i dug through and couldnt find it anywhere other than the entry in the comlog app.
    Thanks ahead of time,
    -Rom
  2. inane.imp
    It doesn't have any Deployment Rules. It deploys inside the DZ.
  3. solkan
    solkan Well-Known Member
    You don’t attach the xenotech to one of your troopers and then deploy the xenotech along with that trooper. The entry “During the Deployment Phase, the Xenotech will be deployed in the CivEvac state, Synchronized with a trooper that meets the requirements to declare the Synchronize Civilian Skill.” means that You deploy the xenotech according to its own rules (it doesn’t have any, so you deploy it in your deployment zone), and then you put it into CivEvac with whatever qualifying trooper you have there.
    SilverSpoon likes this.
  4. SilverSpoon
    SilverSpoon New Member
    Hello guys. May I delay deploy Xenotech for free, with my last mini in deployment pashe ?
    For example
    1) my roster has 10 miniatures + 1 xenotech. I am deploying 9 mini and deley 1 last mini + xenotech or
    2) i am deploing 9 mini + xenotech and delay 1 last mini ?
  5. daszul
    daszul Well-Known Member
  6. SilverSpoon
    But CivEvac and G: Synchronized it's different skills. I asked this question because don't understand. I am deploying Xenotech then synchronize or synchronized in my mind with mini)
  7. Mahtamori
    Xenotech is not a G:Synchronized unit (it gains the skill after it has been synchronized) and does not deploy together with the miniature you slave it to. Being a civilian, it should also not count as a trooper you are allowed to hold back. You are free to deploy it un-synched, however.
    BLOODGOD and SilverSpoon like this.
  8. SilverSpoon
    Nice! Thanks! That's what i wanted to hear))
  9. ijw
    The Xenotech rules do not give you an option to deploy it unsynched.
    My emphasis.
  10. WarHound
    WarHound Well-Known Member
    What happens if you have no valid unit to synch it to during deployment (either due to the sync rule exclusions, or everything that could be valid being in a fireteam (and therefore invalid)?
    Does it mean you have to have possible link options deliberately not in a fireteam so there is an eligible synch option?
  11. BLOODGOD
    BLOODGOD Vampire Hunter
    This is the argument I made to a TO a couple months back, and I still think it's correct.
  12. kinginyellow
    I was under the impression that xenotech deploys the same time as the data tracker is deployed. Which is after the reserved models are deployed. Is this the case?
  13. ijw
  14. daszul
    All models get deployed normally,
    the only thing that happens afterwards is the designation of the datatracker,
    like, which of your already deployed troops is the datatracker.
    Solkan quoted the rules:
    The Xenotech gets deployed in the CivEvac state and Synchronized.
    And as I posted earlier, synchronized models get deployed at the same time as their controller.
    So if you hold the controller back, you have to hold back the Xenotech as well.
    #14 daszul, Jun 20, 2019
    NorthernNomad likes this.
  15. kinginyellow
  16. Mahtamori
    The Xenotech still doesn't have G:Synch when you deploy it, so you won't have permission to keep it with your reserved model because as long as it's not on the table it doesn't have anything allowing you to do so.
    BLOODGOD likes this.
  17. daszul
  18. ijw
    Wouldn’t that require the text to say that you deploy the Xenotech unsynched, and then put it into synched state? As it’s written, there is no point at which you are deploying a Xenotech that doesn’t have G:Synch.
  19. SilverSpoon
    I think Mahtamori right because "the Xenotech will be deployed in the CivEvac state and THEN synchronized" with legal trooper. look at comma after CivEvac state
    • During the Deployment Phase, the Xenotech will be deployed in the CivEvac state, Synchronized with a trooper that meets the requirements to declare the Synchronize Civilian Skill.
  20. Tongfa
    Tongfa ULTRA INSTINCT UKR
    Extending on this point, can I sync my Xenotech to my Antipode Controller?
