Why do we have 5 very samey heavy infantry?
Discussion in 'Yu Jing' started by Mahtamori, Jul 31, 2022.
  1. Weathercock
    Weathercock Well-Known Member
    That's what I'm saying. It's clearly a heavily modified slug-firing HMG modified for high-burst close-quarters gunfights, based on his time fighting in spaceship corridors (or whatever you want to justify it).
    Qiang Gao's gun is modified enough from the standard model that we can do whatever we want and whatever is necessary with it.
    Nope. No way. Not while he can still join fireteams. Keep that B6 crap out of Infinity.
  2. Knauf
    Knauf Transhumanist
    Can't the Kriza Boracs do it already?
    EDIT: With Mimetism (-3) no less.
    Henshini and Chaserabinov like this.
  3. Weathercock
    Yes, they can. And that trash needs to get the hell out of the game, too.
    Knauf likes this.
  4. Ariwch
    MULTI Heavy Shotgun!
  5. Amusedbymuse
    E/M ccw has both e/m and normal ammo.
    So as long as bts and arm are equal e/m weapon ia superior to what jing qo has, it deals same damage plus isolation plus immobilise on heavies. Heavy HI tends to be 5/6, after ap arm and bts saves the same. Most standard tags are 8/6 so e/m has better chances for damage with statuses on top.
    6 point morlock is stupid good.
    #85 Amusedbymuse, Aug 8, 2022
  6. Mahtamori
    Breaker Heavy Shotgun or GTFO
    Henshini and Space Ranger like this.
  7. archon
    EM causes 2 x 1/2 BTS save and the normal ammo causes a pretty normal ARM save. I see that this will put a em-vulnarable trooper quickly into a statue but the loss of W or STR is just a normal roll. In CC this is dangerous but not as dangerous as two times half ARM.
    But I agree that can take a troop out of the game without killing it outright ... just later ;-)
  8. Space Ranger
    I believe the E/M CCW still causes a wound with the E/M part of it. So a max of 2 woulds+Isolate & Immobilize.
  9. Mahtamori
    That's N3 EM CCW.
    In N4, E/M means the weapon is DA, AP and causes target to be isolated. Normal means that any failed saves causes wounds. The weapon itself says all saves are taken against BTS.
    It's quite literally the best CC Weapon in the game, and yet still not the most expensive. It only misses the anti-materiel trait that DACCWs have, but thanks to ADS of AC2s and similar this is much less useful to have.
  10. Space Ranger
    Edit: if I could read, I'd see you already answered my question!
    #90 Space Ranger, Aug 8, 2022
  11. Weathercock
    Man, I've been doing things wrong for the entire edition.
  12. Space Ranger
    I wouldn't be for that either but what if it was a MULTI-HMG!? Hell, a multi is not even as good as a Shang Ji since It's AP OR Shock instead of AND. It would still be cool. It would then have the EXP in ARO.
    Myomer likes this.
  13. Weathercock
    Multi HMI would just jack up his point cost even further with next to no benefit.
  14. Furiat
    Furiat Mandarin
    Maybe additional +1 dmg for his hmg. That would be unique and not too expensive.
  15. Weathercock
    He already has BS Attack (+1 Damage). Doesn't make him any less crap.
  16. Space Ranger
    I mean with no point increase of course.
  17. Furiat
    Furiat Mandarin
    Won't additional +1 stack?
  18. Weathercock
    That's just cheating the system then. Either fix the system that requires such workarounds, or find a better solution.
    It would. It also wouldn't help fix his problems.
  19. archon
    Multi HMG recquires a S5 chassis with stabilisators and all that fancy stuff that a Yan Huo brings to the table without beeing a TAG.
  20. Space Ranger
    Tell that to the Shang Ji who already has Shock or AP+Shock. One of the reasons for taking SJ over YH. Would it be that much of a difference to have AP OR Shock and EXP?
