System Override‘s Insanity
Discussion in 'Scenery' started by System_Override, Feb 1, 2019.
  1. System_Override
    So I spend way too much time on too many terrain projects. I figure it is time to finish some stuff this year. And why not post it to get some feedback, critique and ideas for making it better from the community? :)
    To find a faction...
    I got lucky today and found a spaceship model for 50% off. It needs some work : removing the hinges on the sides, glue everything together, add ladders where the hinges were so troopers can get on top, add landing „feet” , use the existing wiring (it comes with light and sound ) to add more lights, and add a window pane to the cockpit ( polystyrene and a hot air gun? Any other ideas?)
    The size is nice and I like the blocky design. I think it might be a nice piece once painted. Any suggestions as to what faction might fit?
  2. Mob of Blondes
    Overhead projector slides cut in many pieces for the glass? It should be flexible enough to fit each individual window and by doable quickly without having to go the heat gun (or even vacuum) way. The metal parts are big enough to hide the edges, and if visible from outside, just cover with strips of card inside.
  3. Section9
    Clear blister pack materials, they will soften enough to mold with hot water (as in, not-boiling). They're my go-to for things like sails or cockpit windows.
  4. chromedog
    I had to replace the window bits from a second hand FW arvus lighter (as well as for the extension on the canopy, since I made it into a tandem 2 seater cockpit) and I used blister plastic for that. Worked well. Very careful application of superglue meant minimal fogging (the trick is to use way less than you think is necessary as it WILL spread and even 1 pinhead sized drop will cover a surprising area provided you get good mating between surfaces.
    jherazob and System_Override like this.
  5. System_Override
    Thanks for the advice! I will give that a try. Any thoughts on what faction to paint this one as? I find it hard to decide and would appreciate your input.
  6. Section9
    A crapton of guns... Druze would be a decent idea.
  7. oldGregg
    oldGregg Well-Known Member
    Yup, Druze would be sweet.
  8. andre61
    andre61 Well-Known Member
    Very Cool!
