Starting QK- how to begin?
Discussion in 'Haqqislam' started by Dogpool, Dec 28, 2017.
  1. Dogpool
    Dogpool New Member
    I do like the idea of a smart missile system with a FO or two calling in strikes-
    Even if they do look like awkward chickens!
    Are 55mm based correct mounts then for REMs now?
  2. Stiopa
    Stiopa Trust The Fuckhead
    FOs aren't all that reliable, but can certainly work. Also, look up Rafiq's Sat-Lock with Kameel EVO support.
    REMs have generally two sizes: S3 (Rafiq/Shihab/Shaytaniyah/Fanous) use 40mm base, while S4 (Kameels) use 55mm. Technically Nasmats are also REMs, but they're S1 so they use standard 25mm base.
    xagroth and Errhile like this.
  3. Errhile
    There's also a program on standard & Assault Hacking Devices, Spotlight (Claw-1 program class) that can mark targets.
    Worth keeping in mind (though setting up a Repeater network for that end isn't too easy in QK).
    I'd say, if you want to use a SML effectively, you have to build a list for that purpose. One FO is not nearly enough (because once he goes down, your entire SML-based plan goes down). Two I would consider a bare minimum, three or four should do it (still, that might mean classic FO, Hackers capable of running Spotlight, and Rafiq REMs).
  4. Barrogh
    Barrogh Well-Known Member
    They are fairly inefficient though, as far as I can tell. And more straightforward ways of doing so are already fairly situational, it seems.
  5. Errhile
    Well, if I had a Hacker in Repeater range of a target, and had to spend a number of Orders trying to get a Rafiq into position, and having to put a FO into ARO risk, I guess I'd try the Spotlight, and hope for a lucky outcome on the dice.
    But in general, you're right: no method of targetting is really cost-efficient.
    Which makes SMLs such a rare sight...
  6. Stiopa
    Well, it's not a QK list, but I was thinking about fairly efficient SML list concept and came up with something for SAA:
    [​IMG] Shock Army of Acontecimento
    GROUP 1[​IMG] [​IMG] [​IMG]10
    [​IMG] NAGA Hacker (Killer Hacking Device) Combi Rifle, Antipersonnel Mines / Pistol, Knife. (0 | 30)
    [​IMG] NAGA (Forward Observer) Combi Rifle, Antipersonnel Mines / Pistol, Knife. (0 | 28)
    [​IMG] REGULAR (Sapper) MULTI Sniper Rifle / Pistol, Knife. (1.5 | 22)
    [​IMG] REGULAR (Minelayer, Sensor) Combi Rifle, Antipersonnel Mines / Pistol, Knife. (0.5 | 14)
    [​IMG] REGULAR Paramedic (MediKit) Combi Rifle / Pistol, Knife. (0 | 12)
    [​IMG] REGULAR Lieutenant Combi Rifle / Pistol, Knife. (0 | 10)
    [​IMG] REGULAR Combi Rifle / Pistol, Knife. (0 | 10)
    [​IMG] BULLETEER Spitfire / Electric Pulse. (1 | 23)
    [​IMG] MACHINIST Combi Rifle, D-Charges / Pistol, Knife. (0 | 15)
    [​IMG] PALBOT Electric Pulse. (0 | 3)
    [​IMG] TRAUMA-DOC Combi Rifle / Pistol, Knife. (0 | 14)
    GROUP 2[​IMG] [​IMG] [​IMG]7 [​IMG]2
    [​IMG] SIERRA DRONBOT HMG / Electric Pulse. (1 | 25)
    [​IMG] PATHFINDER DRONBOT Combi Rifle, Sniffer / Electric Pulse. (0 | 16)
    [​IMG] FUGAZI DRONBOT Flash Pulse, Sniffer / Electric Pulse. (0 | 8)
    [​IMG] CLIPPER DRONBOT Smart Missile Launcher / Electric Pulse. (1.5 | 18)
    [​IMG] MULEBOT Hacker (EVO Hacking Device) Electric Pulse. (0.5 | 25)
    [​IMG] TECH-BEE (Remote Assistant Level 1, Specialist Operative) Flash Pulse / Pistol, Knife. (0 | 5)
    [​IMG] WARCOR (Sixth Sense L1) Flash Pulse / Stun Pistol, Knife. (0 | 3)
    6 SWC | 300 Points
    And since QK has the same high AVA on Fanous - and I consider those drones very useful as part of Repeater and anti-Camo net - the same concept can be adapted fairly easily here:
    [​IMG] Damn Sultanate Copycats
    [​IMG] ODALISQUE Spitfire, Nanopulser / Pistol, Knife. (1 | 30)
    [​IMG] ODALISQUE (Fireteam: Haris) Rifle + Light Shotgun, Nanopulser / Pistol, Knife. (0.5 | 25)
    [​IMG] HAFZA (Forward Observer) Rifle + Light Shotgun / Pistol, Knife. (0 | 17)
    [​IMG] HAWWA' Hacker (Assault Hacking Device) Boarding Shotgun, D-Charges / Pistol, Knife. (0.5 | 26)
    [​IMG] LEILA SHARIF Hacker (Killer Hacking Device) Shock Marksman Rifle, D-Charges / Breaker Pistol, Knife. (0 | 20)
    [​IMG] GHULAM Missile Launcher / Pistol, Knife. (1.5 | 17)
    [​IMG] GHULAM Rifle + Light Shotgun, Panzerfaust / Pistol, Knife. (0.5 | 15)
    [​IMG] GHULAM Lieutenant Rifle + Light Shotgun / Pistol, Knife. (0 | 12)
    [​IMG] GHULAM Rifle + Light Shotgun / Pistol, Knife. (0 | 12)
    [​IMG] GHULAM Doctor Plus (MediKit) Rifle + Light Shotgun / Pistol, Knife. (0 | 16)
    [​IMG] NASMAT Electric Pulse. (0 | 3)
    GROUP 2[​IMG] [​IMG] [​IMG]7 [​IMG]1
    [​IMG] HAWWA' (Forward Observer) Boarding Shotgun, D-Charges / Pistol, Knife. (0 | 21)
    [​IMG] RAFIQ REMOTE Rifle + Light Shotgun, Sniffer / Electric Pulse. (0 | 16)
    [​IMG] FANOUS REMOTE Flash Pulse, Sniffer / Electric Pulse. (0 | 8)
    [​IMG] SHAYTANIYAH REMOTE Smart Missile Launcher / Electric Pulse. (1.5 | 18)
    [​IMG] KAMEEL Hacker (EVO Hacking Device) Electric Pulse. (0.5 | 25)
    6 SWC | 300 Points
