Silhuette 0 And Fireteams
Discussion in '[Archived]: N3 Rules' started by Arkaon1125, Nov 3, 2019.
  1. Arkaon1125
    Arkaon1125 Well-Known Member
    I have two questions guys:
    • Silhouette 0: if i have to rapreset the model to see line of fire and similar. What i have to use physcally?
    • If i move my fireatem, is possible to move them to gave my backwards models some kind of cover/no line of fire with my other model i'm moving? (same model of the same fireteam)
  2. colbrook
    S0 is the height of a base, so use the base of the model or a spare base.
    Moving models never block LoF, so you can't hide Fireteam members or Sync bots with other members of the same team.
  3. Mahtamori
    1. The model's base (3mm high, and as wide as the original silhouette)
    2. Moving models do not block LOF and you can never gain Partial Cover from miniatures, only scenery.
  4. Arkaon1125
    Thanks a lot guys!!
    Another question: In case of Lietunenat Loss i can appoint another lieutenant. He MUST have the lieutenant skills to be appointed?
  5. Mcgreag
    Mcgreag Well-Known Member
    No you can appoint any model that is not Irregular or REM as the new lieutenant.
    Arkaon1125 likes this.
  6. Papa Bey
    A base?
    No. Models activated at the same time never block LoF to each other.
  7. Mahtamori
    They can not have the LT skill, only one of those per army allowed! Other than that, at the end of your turn you must appoint one that is not Irregular and not Remote.
    Can be the Uhlan, can be the Fusilier Hacker, can not be the Warcor.
  8. Arkaon1125
    Thanks a lot again. So if i loose my lieutenant n the reactive turn ca i appoint one at the end of the reactive?
  9. colbrook
    No, you don't enter LoL as soon as your Lt dies, only during the Tactical phase at the start of your Active turn.
    So if your Lt. dies in the Reactive turn you won't enter LoL until the start of your next active turn, and nominate a new Lt. at the end of that active turn.
    Mahtamori and Arkaon1125 like this.
  10. Arkaon1125
    Thanks for all your answer guys, we where playng a match and we had some doubt about those things!
