Scoring in Frenzied Dance?
Discussion in 'Rules' started by Hero of Sparetime, May 8, 2019.
  1. Hero of Sparetime
    Hello :-)
    Have a question about scoring in Fenzied Dance! I think it is the same as in Conquest, but it looks like that they forgot some sentences? In Conquest it says that the Scoring Zones are still remain Conquered if there is no Character in them at the end of subsequent. This is not written in Frenzied Dance.... so did they forget it? Otherwise it makes no sence with the color Counters in FD....
    Hope you can help?!
  2. der_narr
    der_narr Member
    Hi @Hero of Sparetime
    No, it's not the same.
    In Conquest:
    You conquer a zone at the beginning of the Objectives Phase, You score during the Objectives Phase and the zone remains being conquered
    In Frenzied Dance:
    You conquer a zone at the end of the character's activation (see spanish version)*. You score during the Objectives Phase and the zone stops being conquered.
    *Therefore it's possible that a character can conquer more than one zone (e.g. with Hannibal's Code:"Audible")
    treiral likes this.
  3. -V-
    -V- A! Team member
    It should be read:
    "A Character has conquered a Ziggurat at the end of their Activation if they are the only Character on the three Scoring Spaces of the Ziggurat"
    #3 -V-, May 10, 2019
    der_narr and treiral like this.
  4. CAnon
    CAnon Well-Known Member
    The only character clause - does that mean that if, hypothetically, an ally were to be displaced into the Ziggurat (say, when the opponent activates before you), that you then couldn't score it?
    As, since an ally was already present, you would not be the ONLY character within the Ziggurat.
  5. Kelthret
    Kelthret Usuario
    Correct, you need ot be alone in the Ziggurat, if there's any other characters, either allies or enemies, you wouldn't conquer it
  6. AdmiralJCJF
    Which seems a bit odd, but I guess prevents unwanted strategies?
  7. Jonah
    Jonah Active Member
    Hi, the newest scenario document (1.8) still omits this and states ;'A Character has Conquered a Ziggurat if they are the only Character located in one of the the three Scoring Zones of the Ziggurat' but not 'At the end of their Activation'.
  8. Jonah
    Jonah Active Member
    Is this last bit definitely the case? The rule states at the end of their activation so if Hannibal makes Bixie move for example, or hexx3r displaces someone into a Ziggarut only Hannibal or hexx3r are ending their activation?
    Thanks
    AdmiralJCJF likes this.
  9. AdmiralJCJF
    Yeah, either way each Aristo can only score a maximum of one zone per round.
  10. Jonah
    Jonah Active Member
    But can you Conquer multiple in the same activation? Hannibal could move into one himself and then tell Bixie to move which places her in another. So you've moved two characters into Ziggaruts but only one of them is having their activation which is when you check for whether it's been conquered. So I would assume that only Hannibal in the example I give would Conquer a zone? With the wording as it is.
  11. AdmiralJCJF
    Exactly, only Hannibal can Conquer a Zone.
    Jonah likes this.
  12. Jonah
    Jonah Active Member
    Great, thank you.
  13. AdmiralJCJF
    Hilariously I managed to contribute to this discussion without ever actually reading the core ruling @-V- made in it.
    I, too, am an idiot.
  14. Genesis
    Genesis Member
    so if your character has conquered one ziggurat, and be displaced out of the scoring zone during opponent's activation, you still count as conquered that ziggurat right?
  15. AdmiralJCJF
    You checked to see if the Aristo conquered the Ziggurat at the end of THEIR activation.
    No matter what happens to them after that (Displaced, Placed, Fragged etc.) they still conquered that Ziggurat.
    Only an opposing Character ending THEIR activation as the only Character in the Ziggurat will change that.
    Well, 'till the end of the Round (when everything is wiped clean and you start again with conquering).
    Jonah and Genesis like this.
  16. Genesis
    Genesis Member
    get it. thank you so much :)
