Reset Question
Discussion in '[Archived]: N3 Rules' started by Azuset, Aug 17, 2019.
  1. Sabin76
    FTFY. Indeed, the idea is that the skill itself has to specifically call it out, like with Sixth Sense. The "No-LoF" label is not enough to generate an ARO.
  2. Whyrocknodie
    No, I specifically meant the first bullet point. That is, that having No LOF as a label doesn't mean you count that bullet point as triggered.
  3. Azuset
    Azuset Well-Known Member
    Yup that is confusing. But what makes things even more confusing is the THIRD bullet point that no one wants to acknowledge.
    • It has a Special Skill or piece of Equipment allowing reaction to enemy actions without LoF.
    If a skill that has a label No-LOF (which means you can use the skill without line of fire) won't trigger this condition. What does trigger it?
  4. Whyrocknodie
    Reset is not a Special Skill, it's a Common Skill. That bullet point comes into play with pieces of Equipment like a Hacking Device if an opposing trooper activates somewhere near your repeater (for example), or using Hack Transport Aircraft. Special Skills are things like Sixth Sense.
    Robock, DukeofEarl, ijw and 2 others like this.
  5. Azuset
    Man, thank you. That solves that problem. This was the only line that was continuing to trip me up.
    Whyrocknodie likes this.
  6. Sabin76
    And that's why I assumed they meant the third bullet point in their previous post. Apologies for misunderstanding.
  7. BishopWraith
    BishopWraith New Member
    EDIT: It didn't show me the updates on the thread when I posted this. LOL
    Just talked to WhyRock about this on Discord.
    Azuset... it took a bit to figure out where the disconnect was, but here it is:
    Reset is a Common Skill, not a Special.
    #27 BishopWraith, Aug 19, 2019
    Azuset likes this.
  8. Ayadan
    I have a question on Reset too, even if not related about the initial question:
    Is the FtF really required to have the possibility to fail the Guts roll or can I do this if it is a normal roll too?
  9. Azuset
    Are you asking about just being able to Reset without a ftf roll from ARO or using Reset as a short skill in the active turn?
    Here are the requirements for a Guts check.
    Requirements
    Several events can force a troop to make a Guts Roll:
    If you are not being attacked you cant make a Guts check.
    If you do take a Reset in response to an attack and succeed you would avoid the attach. Therefore you would not meet the requirements of a guts roll because you are not taking an ARM or BTS roll.
    I would say the answer to your question is No. You may not fail a guts roll in this instance because you are not taking a guts check at all.
    #29 Azuset, Aug 30, 2019
  10. Ayadan
    Check what says Reset and you'll see that winning the FtF with Reset lets you fail your Guts Roll too.
  11. Azuset
    Your question was about not using a FTF roll right?
  12. Ayadan
    My question was about can I still use this if it's not a FtF roll like you can use SSL1 even if you're getting hit by a DTW.
  13. Mahtamori
    If you succeed a normal roll you haven't rolled a Face to Face roll, so the answer to your question is no. Reset rules trigger Guts only on Face to Face rolls, not normal rolls.
    ijw likes this.
  14. Ayadan
    Thank you
    I asked because, with the precedent that the SSL1-2 created, I prefered to be sure.
