Repeaters in ALPEH
Discussion in 'ALEPH' started by Renfri, Mar 2, 2018.
  1. regelridderen
    regelridderen Dismember
    Who says, you’d need to keep track of them. They could just be sharing bodies / net rods. Its not as if there are any downsides to the Posthuman itself from losing its proxies today.
  2. xagroth
    2 slots on the combat group and 6 proxy bodies... I can sense the cry of unfairness from the other factions just from the possibility! XD
    Right out of my mind, what would happen? Well, 2xMk1, 1 Mk5, 1 Mk4, and 2 Mk2 AHD, with the Dasyus being little more than spectators from our bag, or "count as" models... (granted, I already use the Dasyu hacker has the Posthuman AHD).
  3. Renfri
    Renfri Well-Known Member
    I mostly agree with you on this, even though a simple workaround is only allowing 1 proxy of each to be taken (ie 1mk1, 1mk2 etc.) while creating a proxy Mk6. And considering the crazy SWC cost of most profiles you would not be able to field 6 proxies, but 4 or 5 at best.
    I don't see CB implementing this, as this would get really convoluted. Hell I'm not even sure we will see a Jumper L2.
    Arlic and xagroth like this.
  4. xagroth
    That would depend on the rules... maybe a Jumper L2 simply allows free ARO (broken AF) or freely use of its own and Jumper N1 bodies (a little less broken, but allowing 2 ARO from Proxy bodies nevertheless).
    Mk1 doctor (or maybe engineer in some situations), Mk2 AHD, Mk4 HRL, Mk5 FO (61 pts) would be autoinclude if Posthumans became AVA2, even without allowing repeat of profiles. And if the Mk3 would receive a Multi rifle with 0 SWC cost, it would go into the mix directly (81 pts)... 2 orders, 5-6 positions, a total of 6-7 wounds PLUS 3 NWI... For less (or little more) than Achilles cost.
    Still broken AF XD
    Arlic likes this.
  5. Kir
    Kir Well-Known Member
    Or they could just make one of every body the ava, since posthumans dont get much better the more bodies you add that dont supply orders.
  6. xagroth
    We have already considered this, and currently you cannot repeat bodies, unless I am misunderstanding what you say? :S
  7. Kir
    My suggestion: ava 1 posthuman, 2-5 bodies (1 per mk max)
  8. xagroth
    The risk is to see 5 bodies for up to 60-65 points, 10 wounds total (probably NWI will be half of those, so still vulnerable to shock), meaning something of an ARO "no risk" spam and multipresence WIP 15 BS 12-13 troopers... Sure, they cost like an Asura, but their strategic pressence on the table is much, much higher, since you will most likely have a body near anything. And having something similar to the Mk5 FO covering the flanks is too good.
    Arlic likes this.
  9. Arlic
    Arlic Active Member
    I think adding more Posthumans/bodies or available of one Kind of a body would be too strong.
    I think WE maybe will get a Posthuman Lt. option.
  10. xagroth
    Depends on the body. Being able to place an extra Mk4 sounds great... but it's 4 SWC! The Mk1, on the other hand, would be impressive, while the Mk2 would mean to see both profiles on all games.
    Having them as Lt might be a little broken as well, consider how you need to hunt 3 bodies with 6 wounds total!
  11. Arkhos94
    It would also mean to be able to use your lieutenant order on 3 differents troops without taking any risk, so free order for them with no risk to balance it. People are already screaming that proxy are OP, this would be so much worse that there is no word for it.
    boquepasha and xagroth like this.
  12. Barrogh
    Barrogh Well-Known Member
    Okay, that's going to be hella off topic, but since it was mentioned...
    Asawira says "Hi". Granted, they don't have Hacker profile which is the context here, and are somewhat easier to deal with directly because of ARM 3, but still.
    Also, with Spec-Ops rule enabled Nomads can have a native BTS 12 HD with Shock Immunity.
  13. xagroth
    Point is a HI Hacker. The Asura ALSO gets Cybermask from H+. As you say, the Asawira don't get hacking options (so it's more of a "You won't isolate/IMM1 me"), and the Nomad Moderator Specops is blowing all his points on that, I should shoot him anyway... (and that's assuming you can drop so many XP on the same attribute, I would need to check Paradiso rules... too much of a hassle). Also, none of those have 2 wounds + NWI XD
  14. Pietras404
    Pietras404 Active Member
    Something like Father Knight? ;)
  15. Barrogh
    I mean, yes, I realize it was in the context of hacking, but I couldn't stop at that point :P
    I did consider how hilariously fun (in both senses) AHD Asawira would be at some point though. Although I didn't realize Father-Knights exist and are rather maligned by PanO/MO players.
    Asawiras AHD would be a little bit cheaper maybe if they used their BSG loadout for that, but meh.
    On things I've mentioned... Army allows that Spec Ops build, 10 pts go into BTS, then the arrow button disappears. Said dude can also attempt to hide deep in DZ in Biotechvore or something, heh.
    Heh, indeed. Good catch.
  16. Nemo No Name
    Here's an idea: Netrods with Jammers :sunglasses::sunglasses::sunglasses:
  17. xagroth
    Does he have both NWI and cybermask? XD
  18. Barrogh
    Frankly I'm not sure if NWI draws a line between "broken" and "eh, FK hacker".
  19. Arlic
    Arlic Active Member
    But it’s not fluffy, that antennas, which should control the battlefield and transferring data, jam. Even if it would be funny though.
  20. Barrogh
    Then netords with repeaters. The latter is what's this thread about, after all.
    Arlic likes this.
