Operation Wildfire
Discussion in 'News' started by chaos11, Jun 26, 2019.
  1. Benkei
    Benkei Well-Known Member
    And others, because having 21th century technology OBVIOUSLY makes you stronger [​IMG]
  2. the huanglong
    Yuan yuans, Irmandhinos, half of CHA. Power armour would be lucky to buy you PH 12 in YJ.
  3. Hecaton
    The problem is that PH is an amalgamation of what we would term "Strength" and "Dexterity" in DnD terms.
    the huanglong likes this.
  4. daszul
    daszul Well-Known Member
    Yeah, the conversion rules/guidelines from the RPG to the tabletop say that its the higher of either Brawn + Athletics or Agility + Acrobatics.
  5. colbrook
    It's just that no one outside Ariadna and Yuan Yuan even lifts!
  6. Hecaton
    Maybe it's that the Concilium Convention bans steroids that powerful.
  7. colbrook
    Seems like the VarGuard can still get them under the table though ;)
  8. Hecaton
    It's ok when they do it.
  9. Benkei
    Both of which a power armor should boost
  10. Hecaton
    I could see the argument that it shouldn't boost "Dexterity", only "Strength."
  11. psychoticstorm
    @Hecaton correct, dexterity is something the user has and the muscle fibres of the powered armour probably would not help with it, maybe make it a bit worse.
    As far as Zeta goes, we all knew it would never live the outlandish expectations people had for it and to be fair the child of a cutter and a Marut many dreamed of is a bad idea.
  12. Hecaton
    Shitty power armor might. Good power armor (or a Su Jian or Hollow Man remote body) might enhance it.
  13. psychoticstorm
    Well a proper power armour with a human inside probably will not enhance dexterity, technically it will make the operator more dexterous because they need to compensate the armour giving them more strength than they should have but that would make them move "normally" a remotely piloted suit of armour is anybody's guess if it would enhance dexterity, or if even 100% dexterity transference is even a operational parameter concern.
    A Mão Esquerda and daszul like this.
  14. fari
    Remember. Varegian Guard is an Ariadnan mercenary company. PH 14 it's the standard for Ariadna's warbands
    DukeofEarl, xagroth and Abrilete like this.
  15. Benkei
    So Cutter and Marut can live up to their expectations but Zeta can't because of what? You know you don't have to defend EVERYTHING CB does, right?
    SKOZZOKONZ and Kreslack like this.
  16. Disko King
    Disko King Well-Known Member
    Don't really see why use her in SP then?
  17. Spitfire_TheCat
    To stop Aleph whining?
  18. xagroth
    The whining never stops, regardless of faction.
    That being said, Peackeeper has no reason to be in SP (they do not follow the conventions by default...), and all myrmidon officers, specially heroes, have a group of followers, that makes them the Enomotarchos, excluding the archers.
    And Achilles doesn't have it because ALL of the Phalanx follows him.
  19. -Ghost-
    -Ghost- Shalashaska
    I just want some dossiers so I can get an idea to proxy for them in the meantime. Was gonna use my N2 Wulvers.
  20. Solar
    Solar Well-Known Member
    The Zeta does seem very advanced in the sense that it combines the highest power TAG armament (MHMC) with the highest level of TAG mobility (6-4 with climbing plus) and a full MBT defensive plating and anti-electronic warfare gear (ARM 8, BTS 6, ECM) and the Remote Piloting system.
    It doesn't have stealth capability or the most advanced targeting systems (PanO presumably does not allow external sale of these technologies). But it's the most advanced TAG in terms of traditional MBT roles.
