New player needs help with infantry
Discussion in 'PanOceania' started by Ayuruk, Mar 26, 2019.
  1. Ayuruk
    Ayuruk New Member
    Hi all. Looking for some advice for that infantry I should get/best infantry for the MO sub faction? I know it's kinda a general question but I'm new to this game :-)
  2. AdmiralJCJF
    I've written an article on this in the past which you may find useful:
    http://heartofthehyperpower.blogspot.com/2018/09/starting-with-hyperpower-guide-to.html
    But for starting MO right now there is no better way to get in than by buying the 300pt box:
    You will probably want more Order Sergeants, so you might want another box of those:
    And the original Military Orders starter is still super useful:
    Other than those I'd highly recommend the PanOceanian Support Pack for the Machinist, Trauma Doc and their PalBots:
    And you certainly want to pick up at least one DroneBots box:
    And a box of the Mule Bots:
    You'll also probably want to add some Knights of Santiago:
    And a Knight of the Holy Sepulchre:
    And you'll probably have MORE than you'll ever need!
    yoink101, Karmano, barakiel and 3 others like this.
  3. Ayuruk
    Ayuruk New Member
    Wow thank you so much for the fast response. I will definitely be reading your article later tonight!
  4. MikeTheScrivener
    I think The Admiral here has it pretty much covered, though might I suggest you also look into "Dart, Optimate Huntress". She's very valuable on the battlefield in MO as well as Shock Army, another PanO sectorial.
  5. Ayuruk
    Ayuruk New Member
    What about the knights hospitaller I didn't see them mentioned?
  6. MikeTheScrivener
    They come in that 300 point box! Theyre kind of like your bread and butter Heavy Infantry in MO. Generally players use them in a full link or a haris. They're one of 3 HMG sources and pretty important
    AdmiralJCJF likes this.
  7. Stiopa
    Stiopa Trust The Fuckhead
    Also note, that Santiago box is partially unusable - MO were completely reworked a few months ago, and for some reason they've lost Boarding Shotgun. But the rest is fully usable, and very important as well. I'm in the process of reworking mine into Magisters - which are also useful, if you want a cheaper HI fireteam.
  8. Skoll
    Skoll Well-Known Member
    While I very much agree with your post, you've basically listed our entire range XD
  9. Death
    Death Well-Known Member
    How to start MO with one easy step:
    Step 1: BUY EVERYTHING :P
  10. AdmiralJCJF
    Ok then smartass :stuck_out_tongue:
    @Ayuruk start at the top and work your way down the list.
    Consider the Military Orders Starter "optional" (many people will prefer to avoid it) but otherwise proceed 'till your budget gives out.
    Ayuruk likes this.
  11. Section9
    Assuming you mean the OLD starter being optional, I think you actually meant to say, "Start at the top, proceed till your budget gives out, paint what you bought until you get more budget, and repeat!" :innocent:
    Stiopa and AdmiralJCJF like this.
  12. eciu
    eciu Easter worshiper
    Well just a side note:
    MO hardest of PanO sectorials so, yea keep it in mind :)
    But yes I would start with 300 pts box, and some Santiago box.
  13. Maksimas
    Yeah, it is odd how that Boarding Shotgun Santiago is not usable in a strict sense, since there is no Santiago BSG anymore...
    And the only other HI with BSGs are Hospitallers, Father Knights and Montesas.
    Maybe there's the chance to convert it into a Father Knight, I suppose...? He'd make a cool HVT too, I suppose!
    Though then again, you'll only ever AT MOST use three Santiagos, since you are hard capped at a limit of three of them, and the remaining models fit the still existing profiles.
    P.S.: Bit off topic here, but I just had a closer look at that PanO Combi Rifle that the Santiago has... are PanO Combis miniaturised rotary guns...?!
  14. eciu
    Nah, this is just old as heck fugly combi model ;(
  15. Brother Smoke
    I believe they used to be
    Section9 and Golem2God like this.
  16. Maksimas
    I mean it doesn't look that good but at the same time it IS a miniaturized rotary gun and I am a firm believer in the concept of ''Aim is irrelevant, you just need to shoot more bullets.''
    Full Auto Lv1 on all PanO Combis now pls.
    Judge Dredd, AdmiralJCJF and eciu like this.
  17. AdmiralJCJF
    Yeah, PanOceania (and also Yu Jing I believe) used to have mini rotary weapons.
    Cool concept!
    And I think that one model for conversion fodder out of a box isn't the worst thing in the world, until they produce new Santiagos anyway!
    Further reinforcing that I didn't include EVERYTHING on my list, I just remembered what the "one thing I am forgetting" that was bugging me was.
    Magister Knights!
    Personally I'd be looking at using that old Santiago Boarding Shotgun here to replace the dumbtube Panzerfaust (the arms should fit fairly well) giving you three "standard" Magisters to run with Joan solo (for Coordinating) or filling out Fireteams.
    Ayuruk and Maksimas like this.
  18. Skoll
    These are fugly get the old ones if you can. They are dynamic and awesome.
    barakiel and eciu like this.
  19. eciu
    This picture is so sad.
    So many missed opportunities ... (and who the heck makes HyperDynamics model so static ?o0)
    Judge Dredd and Stiopa like this.
  20. Stiopa
    When it comes to Magisters I strongly recommend using the Combi/BSG Santiagos. They're very dynamic, need onlya slight helmet conversion, converting the Combi, their BSG is so tiny it can easily work as an LSG, and Spitfire and sword ones cover pretty much our whole Santiago needs.
    Skoll likes this.
