New nomad unit in N4 ?
Discussion in 'Nomads' started by PurpleSquid, Aug 7, 2020.
  1. ijw
    You will.
    Solar, Errhile, loricus and 2 others like this.
  2. AmPm
    AmPm Well-Known Member
    That was my thinking with the effectiveness of hacking in N4. Totally worth taking.
  3. Willen
    Willen Well-Known Member
    Well... idk tbh. If the ARO is Spotlight I would shoot or move with the second half if I can engage. I can totally reset with another short order when not under fire or in ZoC of a hacker. And if it is Oblivion... then it gets serious. Hacker to Hacker wars now seem mosltly stupid since only the KHD can engage and harm other hackers, which I really think is a very bad decision.
    emperorsaistone and Ghost87 like this.
  4. colbrook
    Carbonite and Oblivion can be used to squelch enemy hackers too.
  5. ijw
    I suggest having a closer look at how Hacking works in CodeOne, notably the negative Reset MODs for Targeted and IMM-B States, which stack with each other.
    Solar, loricus and jfunkd like this.
  6. Willen
    True. We need to play and understand the dynamics of the new rules... if you look at the forum looks like any edge case is the end of the world.
    "Oh now everybody can ARO me Spotlight through a deep repeater Network!!!"
    "Yeah then move your one single KHD on the Network and kill the sucker FIRST."
    RolandTHTG likes this.
  7. Willen
    I am familiar with C1 rules Ian, thanks, my point was more about the KHD being the only device that can cause a wounds to another hacker. Sorry if I was unclear. THAT I don´t like as a concept.
    You seem to imply an IMM and Targeted HI or REM. It is still better than the old IMM-2, so I am willing to take it :)
    Unless you are replying to the other part of my post where I say that I would rather engage on a shootout than declare Reset vs a hacking ARO, or perhaps move.
    Second Edit: If Tinbots NOW provide a Firewall, it is going to be a passive -3 to attacking Hacking Programs or will it be only if you FtF with Reset or Hacking?
  8. kanluwen
    kanluwen Well-Known Member
    It's really weird that there's no 'limit one Wildcard per linkteam' rule.
    Smiler, dexterv and Stiopa like this.
  9. loricus
    loricus Satellite Druid
    Remember the Wildcats have the only linkable NCO and KHD and No.2 that we know of. Decide for yourself what those are worth but they are at least not something you can ignore.
    Smiler and Hachiman Taro like this.
  10. Stiopa
    Stiopa Trust The Fuckhead
    Also, you can now take a Wildcat Core, and just add Wildcards to taste :P
  11. Triumph
    The old reverse wildcard?
    Hachiman Taro, inane.imp and Stiopa like this.
  12. loricus
    And everything you would want but Jaguars are wildcards.
    dexterv likes this.
  13. Tourniquet
    Tourniquet TJC Tech Support
    Feuerbach in a defensive team.
    dexterv and loricus like this.
  14. micawber
    micawber Junkship Jockey
    So according to the official information we have right now this fireteam would be possible:
    Vostok (MK12, Mimetism -6), 38 pts
    Wildcat (Spitfire, NCO), 31 pts, 1.5 swc
    Wildcat (Combi, Engineer), 28 pts
    Evader (Multirifle, Firewall), 25 pts
    Daktari, 14 pts
    for 136 pts and 1.5 swc
    That looks REALLY saucy and very self-sufficient. Swapping the Wildcat engineer for an Evader engineer profile is an option but then you have to take another Evader for the firewall. Maybe you want a hacker in there or swap the Evader for a Feuerbach version. Lupe is also an option but I'm not sure what I would take out and since we have ultra-cheap Jaguar Haris without the need for Massacre now there should be enough order-efficient smoke available.
    That still leaves more than enough points for a Jaguar haris, an Intruder, a Gecko an Evader/Wildcat Duo, a Tomcat and some other stuff.
    So many options...
    #554 micawber, Sep 19, 2020
  15. Snowball
    Snowball Well-Known Member
    I wonder what different fireteam combos everyone will come up with. Personally I want to try this:
    Vostok ODD MK12
    Evader AP Spitfire engineer
    Wildcat KHD
    Señor massacre bsg
    Daktari
    assuming points on massacre don’t change much that should be roughly 1.5 swc and 139 points.
    My main worry is all the wildcards feels like a trap. I like having multiple offense vectors so I may make it an Alguacil or jaguar core to lower the point cost. At least we have so many options.
    Lampyridae, wuji and Hachiman Taro like this.
  16. loricus
    My current go-to full core in mind is:
    Jaguar CR
    Jaguar CR
    Jaguar CR
    Jaguar CR/Panzerfaust
    Tsyklon Feuerbach
    Althou a cost increase on Jags might make it:
    Alguacil Lt.
    Alguacil
    Alguacil FO
    Alguacil FO
    Tsyklon Feuerbach
    Of course I'm currently expecting to use a small Core and a Haris instead of trying to link 5 guys.
  17. Armihaul
    Armihaul Well-Known Member
    I would not asume that the vostok odd is the FTO. I have the feeling that it would be one of the albedo ones.
    The wildcats, more than the core, I think will be more interesting in the haris, because of the non tax, the little extra mobility, and putting the MSV where you need, with Lupe for both missions and smoke (if she retains it)
    Enviado desde mi M2004J19C mediante Tapatalk
  18. inane.imp
    Albedo Vostok with a Tysklon and Wildcat Engineer in a Haris will murderise MSV AROs if you're willing to take 2 x DA on the Tysklon's chin. Which is probably ok assuming UNC 2 stays.... (do we know if UNC 2 stays? I assume it will as it's a core part of the Remote Presence rule which exists on N4 REMs). Very expensive though... something you could easily build into a list as just one option for list building (I can easily see myself taking a list that can be configured into multiple different starting links depending on table or opponent).
    Re: Hacking.
    If anything I'm seriously hoping Gromez gets "Assisted Fire" as an Upgrade. It'll give her a clear role in CJC and DBS. Because otherwise EVOs will rapidly become a 'tax'. Which given that they're limited to Reseting vs Trinity... is double-plus-ungood.
    I'm not too concerned about HDs vs KHDs as if you can get Oblivion off on them, you can follow up with Spotlight and Carbonite to take them out of the Hacking fight PROVIDED that Trinity is DAM13-14 and doesn't ignore Firewalls (ie. I want BTS12 Interventors vs KHDs exploiting my Repeaters) as the inability to do effects that can't be Reset out of combined with losing Firewall benefits would... well... suck.
    I do want to see a B1 DAM program on some of our Hackers though (Custodiers in particular - as this would provide a point of difference) - equally, I'd expect to see it on some CA hackers and on Dansavas.
    Hell, I now have a Profile I want to see:
    Custodiers to see if they have something like Suckerpunch (say B1 DAM13 DA ) and Surprise Shot (-3). Something to make them the killiest of HD+s to fit their roll as a combat hacker.
    #558 inane.imp, Sep 19, 2020
    Spitfire_TheCat and Armihaul like this.
  19. Lampyridae
    Lampyridae Well-Known Member
    I like the idea of KHDs being the only thing that can cause wounds. It clearly separates the different roles, and encourages synergistic hacking: regular hacker can Spotlight, the killer hacker can then Trinity with a stacking penalty to the target.
    Edit: I believe we won't see custom programs as this immediately starts working against the goal of simplification. Rather, we may see characters get bonuses to hacking or indvidual hacking programs. +3 WIP for Overlord might be something Gromoz does in line with her N3 anti-TAG skill. Asuras, already hinted to have an upgrade by Bostria, maybe get Trinity? That sounds appropriate.
    EVO stuff I think will largely stay for those people who've bought the EVO remotes, I think. This gives some kind of HQ "resource" for opponents to try take down that isn't your Lieutenant. Fairy Dust, say, is way more powerful now since it protects from all Comms Attacks, so it would be a very singular character that could take it.
    #559 Lampyridae, Sep 19, 2020
  20. Mann1ng89
    Mann1ng89 Member
    Did anyone see the apparently leaked Nomads TAG profiles? I saw them on Facebook this morning but now can't find them.
    Do we think they're real?
