NBW/MA interaction
Discussion in 'Rules suggestions' started by kenjiro2k5, Jul 26, 2023.
  1. Triumph
    It's already in the game as CC attack (+X) and CC attack (-X). You could just stick both on character if you wanted to.
    LaughinGod likes this.
  2. psychoticstorm
    I would agree but NBW does not affect models without MA so the CC attack (-3) would be a net bonus for NBW.
    Lady Numiria likes this.
  3. LaughinGod
    LaughinGod Well-Known Member
    You just word NBW rule to cancel/ignore all CC skills. I am not native English speaker or rule lawyer, but I would word it like this
    Effects:
    The attacker cannot use the CC Special Skill against the user.
    If needed add a FAQ that all CC+/- whatever skills are CC special skills.
  4. Triumph
    Enemies cannot apply MODs to their CC attack roll.
    He's talking about removing Martial Arts not NBW.
  5. psychoticstorm
    Ah I see now, but wouldn't that bring us in the same situation?
    I thought it was aa suggestion about decoupling MA to its components and NBW stopping only some of them.
  6. LaughinGod
    Oh no, I am for decoupling MA and just having CC+/- whatever skills, and NBW working against all of them. Because as is now, NBW works against MA, but doesn't work against CC skills, which is a cheat IMO, makes MA actually worse than just having CC+/- whatever. I believe this is both bad design and really confusing for players.
    I see a point some are making that NBW should work only against some CC+/- whatever skills, but this is too confusing IMO, except maybe making it work only against positive CC+ or negative CC- skills.
  7. Hecaton
    It's definitely bad design, agreed. It seems like someone on the design team was trying to do an end run around NBW. Cheating their own system, as it were.
  8. psychoticstorm
    It is an interesting proposition, not sure how NBW would be worded though, assuming it gets equal decoupling.
  9. wes-o-matic
    wes-o-matic Meme List Addict
    Delete Martial Arts. Replace it on any MA profile with appropriate combinations of: CC Attack (-3), CC Attack (+3), CC Attack (+1, 2, or 3 DAM), CC Attack (+1B).
    Reword Natural Born Warrior to:
    Special Skill, Automatic, Optional
    Requirements:
    • Declare a CC Attack.
    Effects:
    • In the Resolution step, negative MODs may not be applied to the user’s CC Attribute.
    #29 wes-o-matic, Aug 26, 2023
  10. burlesford
    I like this.
    Hachiman Taro likes this.
  11. Robock
    Robock Well-Known Member
  12. Hachiman Taro
    Hachiman Taro Inverted gadfly
    This is the way.
    Also Martial Arts should be streamlined to +1 CC / -1 CC (to opponent) / + 1 Dam per level. Would make it way more intuitive and better scalable.
  13. Errhile
    But that would elliminate not only Martial Arts, but also the old iKohl (which was now turned into straight negative CC modifier. Beefed up by the change, as originally iKohl didn't apply to models with STR).
    Is it intended to beef NBW that way?
    Is it good for the game?
    Brokenwolf and Lady Numiria like this.
  14. Brokenwolf
    For me, NBW would be fine if it just works against MA 1, 2, and 3. It should have no effect on MA 4 and MA 5. Those are the expensive MA levels and are rare enough that they should not be effected by NBW.
  15. archon
    Keep MA as it is. Just do the rewording for NBW. We already have to much of this on too much cheap profiles.
