N4 Changes
Discussion in 'Yu Jing' started by Triumph, Aug 10, 2020.
  1. Triumph
    With the threat of oblivion gone I think hacking got weaker? Like alot, weaker.
    Although on second thoughts the stacking -6 between targeted and immobilised is still relatively difficult to get out of in any order efficient manner. Definitely leans towards wanting multiple HD to spread aids as an ARO though as quickly as possible.
    #521 Triumph, Sep 24, 2020
  2. Amusedbymuse
    If it's not a mistake then it's basically only carbonite. And now we can reset out of it. It really is almost no downside to be HI. But then again it might just be misprint xd
  3. Triumph
    If you get both targeted and immoblised trying to reset out on WIP7 is gonna be pretty aids, especially if you're still getting contested on the F2F. But it certainly won't be the fire and forget that oblivion is currently in N3 where it doesn't really matter if the hacker immediately dies trying to get the oblivion off as long as he sticks it on an important target.
    No duration for buffs either, seems like you can buff the Rui Shi and as long as your EVO doesn't eat shit it'll keep marksmanship up.
  4. the huanglong
    I really hope this is the case.
  5. Amusedbymuse
    Well in you eat both spotlight and carbonite then why not just call engineer and be done :)
    My meta isn't even heavy on hacking so I have no idea how does stealth on reactive work against active hacker. Can he target you without lof or not?
  6. Zewrath
    Zewrath Elitist Jerk
    Wut? It’s insanely strong now. More obnoxious than ever.
    Sedral likes this.
  7. Triumph
    Huh, that directly contradicts the chart. It only lists TAG, REM, Hacker.
    It's also only burst 1 in the chart
    So one of the two is wrong. @ijw
  8. Zewrath
    the picture above is from a N4 rulebook tho
  9. Triumph
    I figured the picture of the chart was also from the N4 rulebook
  10. Amusedbymuse
    What chart are we talking about? Is it something in physical book?
  11. Triumph
    OK. To throw further confusion onto the fire
    From the battle report it targets HI (which are listed as IP? @Benkei if you could confirm with the spanish), but is only listed as Burst 1 in its infographic.
  12. Triumph
    Some kinda slightly blurry picture leaked online. I figured it's the book, maybe that's not the case.
  13. Triumph
    Stealth doesn't affect units in the reactive turn. Won't hide you from hackers if you're the reactive player.
    In N3 anyway.
  14. Triumph
    Shotguns are small templates as well if we didn't already know that. All shotguns are small templates.
    MSRs kept burst 2 DA, that nerf didn't stick. (I think this might be a typo because there's no reason for them to split the antimaterial and burst mode entries with this like they did). They did lose stun ammo though which is a pretty big nerf
    #534 Triumph, Sep 24, 2020
  15. Mahtamori
    I'm looking at a slightly less blurry picture and the quick reference chart lists Oblivion as Burst 1 and doesn't have HI among its targets, though the latter I find more easy to accept as being a simple typo.
    Edit: btw, if Tinbots do indeed make Firewalls and if Fairy Dust do indeed also make Firewalls, then they won't stack. On the plus side, all Firewalls reduce the incoming Comms Attack's DAM by 3.
    Stiopa and Willen like this.
  16. Triumph
    Maybe they copy paste error'd Carbonite? That'd explain how it wound up with B2 and the wrong targets.
  17. Willen
    Willen Well-Known Member
    The good thing is that with the wiki being supreme, and IJW keeping it "alive", those things can be easily errata'ed.
    Edit: I would still like to see a good official statement saying: "The Wiki reins supreme, as does the ARMY."
  18. Mahtamori
    Occam's Razor. It makes no sense, what so ever, for HI not to be targetable by Oblivion. Burst is up in the air until IJW/Koni clarifies it, I think
  19. SpectralOwl
    The closest statement we have is that the Fireteam Chart overrules Army thanks to some silliness going on in the background that makes Army horrible at listing them. Hopefully that issue got fixed, but I doubt it.
  20. Benkei
    Benkei Well-Known Member
    Yes, IP is Infantería Pesada so Spanish for Heavy Infantry
