N4/C1 Token Design Questions
Discussion in 'Rules' started by Lawson, Oct 1, 2020.
  1. Lawson
    Lawson Well-Known Member
    I was under the impression that @Mob of Blondes felt it important to have squares near the center of the Silhouettes for gameplay purposes. If it's not so important I could do a stepped fade of some sort (since I'm trying to avoid soft gradients personally on my designs).
    If I was just making them for me, I'd probably just go with this design for clean aesthetics:
    They don't have the guides, but I feel like once you're trying to eyeball a 3mm square from 36" you should be playing with surveying tools and not little cardboard squares that you have to manually position anyway. Either that or come up with some 3mm magnets and stick them on both sides and then drag it around to find your spot. Call me crazy but I always assumed 3mm just sort-of a 'minimum perceivable area you kept roughly in your mind but not something you actually physically tried to measure.
    Jumara likes this.
  2. Lawson
    BTW if 3mm is make-or-break, be sure to play the game using inches instead of cm.
    Each 4-4 (inch) move gets you exactly 3mm farther than a 10-10 (cm) move :joy:
    Nuada Airgetlam likes this.
  3. Nuada Airgetlam
    Oh, absolutely, I'd love to call out a madman who proposes he sees exactly 3mm of the Silhouette to take out his theodolite and prove it xD
    Always went with "eh, I guess that's at least 3mm, you're good". I'd much rather want to see your design used than checkers, tbh.
  4. Daniel Darko
    Commander @Lawson ,
    thank you for your initiative. It is very appreciated.
    Of course I am as pleased as all the other ones around here for your meaningful artdirection and your dedication to 100% usability.
    Thank you.
    Sincerely yours
    Cmdr. Darko
    Nuada Airgetlam and Lawson like this.
  5. redki
    redki New Member
    Is there a link to download and print your work? This is freaking awesome, congrats!
    Lawson likes this.
  6. Lawson
    I'm very close to having a link - just doing final tech checks and ensuring that the tokens will be scaled properly to accommodate both metric and imperial players - should have it all set before the end of the week. I'll also be sending the files of to @toadchild soon so that they can be incorporated into his token generator.
    tox, Willen and toadchild like this.
  7. redki
    redki New Member
    Thank you very much, waiting for them.
  8. Lawson
    So here's a sneaky trick:
    This version 'cheats' with the sizes of the 3mm squares for the different silhouettes to ensure that they have a whole number across and no weird joint in the middle.
    A true 3mm square will be 71 pixels across at 600dpi
    But here's how I cheated the square size for each:
    S1, S2 (25mm wide) = 73.7 pixels per square (3.12mm squares) - 4% larger than 3mm
    S3 (40mm wide) = 72.7 pixels per square (3.08mm squares) - 3% larger than 3mm
    S4 (55mm wide) = 72.2 pixels per square (3.06mm squares) - 2% larger than 3mm
    S8 (70mm wide) = 71.9 pixels per square (3.04mm squares) - 1% larger than 3mm
    For reference, the largest variance, for the 25mm wide silhouettes, is only 3 pixels per square at 600 dpi. That represents 0.25mm which is about the minimum size that a line can be in order to be visible. The slight difference when multiplied across many squares creates a bigger variance, but since the squares aren't actually used to measure distance like a ruler, but instead just need to be roughly accurate in and of themselves, I think this works.
    If I put the S1 and S8 next to one-another and zoom in 400%, which have the biggest difference, you can see how the squares won't quite line up:
    #168 Lawson, Oct 14, 2020
  9. toadchild
    That’s sneaky and I like it!
  10. Mob of Blondes
    There is another way: double sided templates. Start the squares from one edge (and the bottom), so when in use you can get perfect edge for that side, or for the other by flipping the card (back to front, or upside down, or both). And no one will be able of saying the sizes are wrong (the checkers, this time).
    Also the text could be inverted colors, or some other way to still show checker limits.
  11. QueensGambit
    God knows I like to follow the rules precisely, but honestly, if my opponent wants to distinguish between 3mm and 3.13mm, I think I'm looking for a new opponent.
  12. Mob of Blondes
    Quick mock up of S2, obviously double width, print this way and bend, or cut each half separately and glue to each side of something thicker:
    You have perfect alignment in the top + left edges with the half marked with base in grey, and also top + right with the one without base. And if you rotate what you view (= upside down), you get bottom + right (base at top), and bottom + left (no base).
  13. Lawson
    That's an interesting idea. I'll likely percolate on it a bit for now and focus on getting the tokens out first so people can start using those.
    Regarding printing and cutting of tokens, I know I brought this up once but I'm circling back to it... does everyone here cut their tokens using craft punches and then mount on 25mm/1" rounds of some sort and just accept the fact that a 1" punch-out is going to overlap the edge a bit? I am still searching for a punch of *just* the right size to allow me to mount on 1" bases and will likely custom-size the prints I'm using personally for myself to get consistent border width. But I want to make sure that the bleed and edge width for my default sheets services the most people.
    Check this out: IMG_3049.jpg
    The Imp-2 marker is scaled down 50% from 600 dpi to 300 dpi for my home printing test, is cut using a 1.5" punch and it fits just about perfectly on the 40mm Litko base I have for it and has a roughly 1.5mm grey border around the edge (and a little bit of the acrylic border sticking out beyond that).
    Printing the 25mm tokens out with the same settings gives about the same sized border (B&W AP mine w/ 50% marking). However, when you glue it on a 25mm or 1" round (the 'Unloaded' seen in color from an earlier one of my tests, sitting above the AP) and wrap the border down around the edges of the token, the gray ring becomes dangerously narrow in places. I think people who do this would benefit potentially from one of the tokens to the right, scaled to 49% or 48%, as, post wrap, it would have about the right edge-width.
    Thoughts?
  14. Daniel Darko
    I will ask a friend, if he can print your tokens on stickers. I will then stick them on some tokens (last Edition they were mirrored and sticked under acryl-tokens (like MAS did it, but I used 25mm)). The stickers aren't pre-cut, I cut the surplus with a modelling knife - this way I can hide the fact, that I am off-center. Thanks to @toadchild again. I have 200 very nice tokens.
    Another friend of mine printed his tokens on photo-paper and glued them to MDF-tokens. He sanded the surplus and then painted the side off the token black with a pen.
    TLTR and conclusion: Take a wide edge. It helps. I like it, when the outer ring (grey) matches the inner circle (with infos) in width.
    ________________________________________________
    And while we're at edges - I am not 100 % convinced, that the ordertokens you created share the theme of the other tokens. I am missing the white (or functional colored) circles. They might not have informations, but it would help me to see the pattern. Please consider to make them match.
    Well, and I am also not 100% convinced of the Holo-Pojector-Tokens. But this is just because I don't like the mirrored images on them. This is just personal taste - you might consider it, if you see the cross eyed eyes, that I see on those tokens.... :persevere:
    #174 Daniel Darko, Oct 15, 2020
    toadchild likes this.
  15. Lawson
    I actually created several different styles of Order tokens and was going to put them out to a vote before I realized it was just going to further delay me completing this and picked one. It is a bit different than the other tokens to do borderless but it also ensures that you'll always be able to see them, so they work for me personally. But I still may make some alts of a handful of tokens - especially once these are on the token creator and I don't need to commit to adding more tokens to my sheet/layout every time I make a new one.
    Daniel Darko and toadchild like this.
  16. Lawson
    Okay I've got them up on google drive. I'd like a 3rd party (or several) to do a final tech/qc check (including possible test print and cut just to confirm no issues, particularly with those using A4 paper) before I put them out to the world. Volunteer and I'll PM you the link.
    #176 Lawson, Oct 15, 2020
    Willen likes this.
  17. Lawson
    Also FYI guys I just finally found the right cutter
    Because it's adjustable I was able to get some BANG ON perfect cuts for my 1" discs. Check it out:
    This is from one of my color proof test prints at 300dpi, so I haven't glued it down on the disc, but the fit is gonna be PERFECT.
    Also I can use it for 40mm and 55mm cuts as well because of the adjustment.
    Xeurian, Willen, Rumdog and 2 others like this.
  18. tox
    I'm here.
    (but i'd like also the 15mm states)
  19. Iver
    Iver Human Plus
    Boy, these tokens and markers look sleek. I'd love if someone more tech-savvy than me could upload them to Tabletop Simulator.
    Willen likes this.
  20. Lawson
    It's easy enough to print for 15mm fortunately by scaling the print settings to 60%. I can't guarantee legibility at this size unless you have access to a 600 dpi printer but if you do, you're in luck because the tokens exist in 600 dpi. You may just need to print a couple more pages than you would want to because I've mixed tokens you likely wouldn't want to print at 15mm on the same sheets. That should be solved when @toadchild is able to get these onto the creator, though.
