Monofilament/Vorpal and Protheion
Discussion in '[Archived]: N4 Rules' started by Arkhos94, Oct 2, 2020.
  1. ijw
    Coup de Grâce is automatic. There's currently no option to do a normal CC Attack instead. :-(
  2. Sabin76
    This makes my Shasvastii/Samaritans very sad, indeed...
  3. ijw
    To be fair, if the target is 'only' Unconscious, something's probably gone horribly wrong already! Especially for Calibans with D-Charges...
  4. Mahtamori
    Hmm... that means performing Predator Classified Objective is indeed very difficult. You wouldn't happen to know if there's a re-print of the deck on the way?
  5. colbrook
    It removes the option of hoovering up troopers that have been made Unconscious by shooting though :'(
  6. toadchild
    Well, I guess that means Sheskiin’s Red Fury technically no longer has anti-synergy with her protheion.
    Dragonstriker likes this.
  7. ijw
    There are no plans to reprint the Classified Deck in the near future. And yes, it makes it hard to hoover up Unconscious targets. :-(
    My preferred option would be to make Coup de Grâce optional, and let you resolve a regular CC Attack instead.
  8. Nuada Airgetlam
    Does that mean there will be no new ITS deck for the new season as well? And if so, will the new season not use a Deck or are we forced to look for an OOP product to facilitate gameplay?
  9. colbrook
    It'll use the current classified deck, which is not OOP.
  10. Kn1ght
    Kn1ght Warning: Abrasive
    Wow, didn't see that coming but fair enough [emoji4]
    Sent from my SM-G955F using Tapatalk
  11. colbrook
    Move straight to dead, do not pass Go, do not get 200 Wounds :P
    Ashtroboy and Dragonstriker like this.
  12. ijw
    Responding here, as it's the appropriate place...
    No you can't, and no the rulebook doesn't. If the rules text and an example contradict each other, the rules text is going to take priority.
    Unless and until it's FAQed, or there is a provisional rules answer post, Coup de Grâce does not work with Protheion. In a similar way to Berserk not working while in Engaged State until the FAQ.
    Then you won't be playing by the rules, as clarified by a member of the rules team. Disagreeing with me or disliking my answers doesn't change the status of those answers.
    And also:
    I didn't shut up.
  13. Nuada Airgetlam
    Didn't we recently have HellLois state (Facebook?) that it does? There was a bit of noise about that some month ago.
    Lesh' likes this.
  14. Lesh'
    Lesh' Infinity LATVIA
    It was FAQed:
    https://downloads.corvusbelli.com/infinity/faq/n4-faq-en.pdf
  15. ijw
    No, it was in the private Warcors forum, rather than anywhere public. And it required the FAQ entry for it to actually apply in the rules.
  16. Nuada Airgetlam
    It still was leaked and shouldn't have been stated this way in contradiction to what you're telling us. You guys need to be on the same page about those rulings.
    Also, by this same logic - are your rulings also unofficial until FAQ then? Even the "provisional answers"?
    xagroth and Hecaton like this.
  17. tox
    ALL is unofficial until FAQ. But a "Provisional answer" has already been discussed, so it is very unlikely that it will be changed (maybe just further clarified)
  18. Hecaton
    You also said that someone wrote the example without being aware of the changes to Coup de Grace as a justification - which is incorrect as the example takes into account both the fact that CDG is something that happens when you declare a CC Attack now, and the fact that it moves them straight to dead without saves. The language of that example in Protheion is written with the N4 changes to CDG in mind.
    Given that your "preferred" solution is clearly going against the example in the book, and your general "Infinity c'est moi" attitude, it comes off more like you have an opinion on how that interaction should work that isn't shared by CB, and you're trying to force it.
    It's also worth noting that having "gotcha" rules answers that can only be known if you are active on the forums and read very specific threads (not even the stickies), and have no actual documentation in anything CB puts out, make for a bad game situation.
  19. psychoticstorm
    Please explain to me why we have to have this conversation every time you do not like an answer?
    On the red text side I would greatly appreciate it if you cut that attitude and worked on how to express your objection in an at least civil way.
  20. Hecaton
    The fact that people don't understand that having a rule that isn't in the rulebook or FAQ is a problem is worrying. It wasn't even in the forum thread collecting rules questions until I pointed it out. When TOs who are listening to IJW spring this on people, there's no way they're not going to be blindsided by it, because it directly contradicts an example in the book.
    So no, you're not going to get this conversation every time I don't like an answer, but you are going to get it every time there are "rules" which mysteriously contradict what's in the rulebook.
    #40 Hecaton, Feb 26, 2021
