Mines and close combat
Discussion in '[Archived]: N3 Rules' started by Tanan, Jul 16, 2019.
  1. Zewrath
    Zewrath Elitist Jerk
    My God, we've been doing IRL mine clearing wrong this entire time! Turns out South Park was right all along!
    Ogid likes this.
  2. Ogid
    Ogid Well-Known Member
    Can't the mine decide the point in which it hits you? Like a BS attack may decide to hit you before you reach cover or B2B with another trooper?
    This would work, you'd need to use both move skills but it's doable.
  3. Mahtamori
    A mine, just like any template attack, has to place it's template on declaration/triggering - for this reason you need to move into base to base with the second short skill so that you know where the template is. And just like all template attacks, the template will touch anyone moving through it between start of order and until resolution - it's not just one specific point!
    Ogid likes this.
  4. Ogid
    Perfect, I wan't 100% sure about that one.
  5. tox
    This.
    You are not engaged for the full duration of the order (like Camo revealing)
  6. Mahtamori
    That's why you need to make sure you're Engaged while still touching the template location.
    Tricky but often doable. Just be very careful so as not to stand partly inside the space where the mine used to be, as this would have unfortunate consequences for your final position and will cause you to fail to enter Engaged state.
  7. tox
    mmm...
    Now i see what you meant! Yes, this should work. Really difficult to realize, but it works.
