Mine Size and Triggering
Discussion in '[Archived]: N3 Rules' started by Space Ranger, Aug 8, 2019.
  1. Space Ranger
    Sorry I can't find it in previous posts and thanks for any help.
    A mine while in camo is S2, Does this mean the origin of the template is from the S2 or from the actual size of the Mine wish is S0?
    If a mine is discovered, it’s now S0. Does this mean the template origin is the base?
    bladerunner_35 likes this.
  2. ijw
    The Camo marker is S2. The Mine itself is always S0.
  3. Space Ranger
    So the enemy red can not be affected by the mine until it's practically up against the wall. Also the enemy red can discover without being affected by the mine.
  4. colbrook
    Yes, and yes.
    WarHound, Urobros and Space Ranger like this.
  5. Space Ranger
    Thanks guys that's a big help.
  6. chromedog
    It will be a -6 to discover the mine, though. Camo and cover count for this roll.
  7. Andre82
    Andre82 Well-Known Member
    Using a small lip of cover is a cool way of tricking some opponents into thinking your not a mine.
    Sadly it tends to be pretty obvious what's a mine thanks to the way deployment works.
  8. Space Ranger
    Still better than being blown to bits!
    My friend kept doing a mine behind cover and said the mine pops up to blow up!
  9. Section9
    I think they did in N2, where you could choose between round and teardrop template blasts. I don't want to dig out the books and re-contaminate my mental N3 rules with N2 hangovers, though.
  10. valukr
    valukr Well-Known Member
    Mines can get cover?
  11. toadchild
    Discovery of a camo marker is affected by cover.
    But yes, I think if you shoot an exposed mine it can also get cover. There's nothing that says otherwise in the BS Attack rules.
  12. colbrook
    The cover rules refer to the target, rather than trooper, so I don't see why equipment can't get cover.
    #12 colbrook, Aug 12, 2019
  13. Tanan
    Tanan Well-Known Member
    Enemy can also destroy the mine using intuitive attack if it can see the camo marker while not having LoF to base (where the mine actually is located).
  14. Mahtamori
    Sorry, mate, but in order to affect the mine you need to have that template touch the mine which means the base, otherwise you're just hosing down a camo marker which isn't even removed because the cancellation clause requires the mine to make a save.
    daboarder, Sabin76, WarHound and 2 others like this.
  15. Tanan
    @Mahtamori are you sure? Has this been FAQed? I thought that template needed to touch the camo marker to affect the enemy model.
    If successful intuitive attack hit can be cancelled by LoF blocking, is the same true for Discover? Technically, the discoverer doesn’t have a LoF to the mine.
  16. Sabin76
    You discover markers. A template has to hit the actual object under the marker. For anything that's not a mine, those are the same thing.
    To elaborate with an example, you can discover a mine that ends up in total cover after the discover success.
    Now the next question I have has to do with your wording... I don't think the Intuitive Attack is "canceled". You declare an intuitive attack against a marker, but for that attack to do anything to the object under the marker (the mine in this case), the template has to clip the mine itself. However, if you have other things in the template, I'm pretty sure they get hit and the attack isn't canceled.
    Mahtamori likes this.
  17. Tanan
    So no FAQ or ruling readily available? I thought so too.
    Nothing in the rules say that camo marker can avoid a such hit. If the camo marker is hit, the corresponding model is hit regardless of “actual” model position.
  18. Arkhos94
    No faq needed, you damage the model, not the marker.
    If the model (here the mine) is in total cover, you cannot damage it, that’s the effect of total cover
    BLOODGOD and Mahtamori like this.
  19. Mahtamori
    Yup, what @Arkhos94 wrote. You need to find a rule which says that hitting the Marker damages the model, not the other way around, and I'm fairly certain there is no such rules passage because I've never found one.
  20. Tanan
    Rules aren't 100% clear about hitting camo markers.
    http://infinitythewiki.com/en/Camouflaged
    Effects
    • While Camouflaged, troopers are not represented by a model on the table but by a Camouflage Marker (CAMO).
    Cancellation
    A trooper's Camouflaged state is canceled, and its Marker replaced by its model, whenever:
    The Camouflaged trooper receives a successful hit that forces him to make an ARM/BTS Roll, or a Critical hit, without previous Discovery (by means of an Intuitive Attack, a Template Weapon whose target was a nearby model, etc.)
    But how does Camouflaged trooper receive a hit? I could argue that whenever Camouflage Marker receives a hit, the corresponding camouflaged trooper receives a hit.
    And because important rules are hidden in examples, this is also relevant:
    Q: Can Camouflage Markers be indirectly hit by Templates Weapons? How does this interact with Impersonation? A: If you hit an enemy trooper not in Camouflaged state and there is an enemy Camouflage Marker inside the Area of Effect of the Template, then the Camouflage Marker would be affected too. However, with an Impersonation Marker you can not declare the Attack because it counts as a friendly trooper.
    Again, Camouflage Marker is affected. But does this mean that Camouflaged trooper is also affected? No one knows for sure.
    #20 Tanan, Aug 13, 2019
