Massive N4 spoilers
Discussion in 'Yu Jing' started by Surmelk, Sep 18, 2020.
  1. Benkei
    Benkei Well-Known Member
    Just proxy one for another
  2. Benkei
    Mate, that's from the leak, straight from the zip containing those hundreds of SS
  3. Teslarod
    Aight checked my folder, it does have the HRMC listed.
    Anyone with a shred of CB track record history could tell that's not a real Profile...
    25|0
    I mean, like cmon, are you even trying to be reasonable at this point.
    The entire builder isn't finished so at worst that's a display bug/typo calling the wrong index number for the name of a piece of equipment.
    On the other hand you're the guy sitting here bitching about an unfinished free piece of software, you weren't supposed to see, being inaccurate pre release, so wouldn't know how to satisfy your expectations anyway :face_with_rolling_eyes:
    BTW you're going to have fun hating on IA for years to come.
    Most of the things in there got only slightly better, while stuff like MO and JSA improved by leaps and bounds :stuck_out_tongue_winking_eye:
    wuji, fatherboxx and A Mão Esquerda like this.
  4. Space Ranger
    I'm going to assume they are all fake. Some are too good and others just mistake ridden.
    wuji likes this.
  5. tox
    AS ALREADY TOLD MULTIPLE TIMES, THE LEAK IS FROM AN INCONSISTENT DATABASE JUST TO CHECK FUNCTIONALITIS.
    Sorry for Caps, but we should all cool down.
    wuji, Dragonstriker, Errhile and 2 others like this.
  6. colbrook
    IJW already confirmed it's incomplete, unfinished, unproofread test data that was being used for functionality testing of the builder.
  7. fatherboxx
    The good Liu Xing profile went down to 33 from 38 while Santiago is whole 45 points and CANNOT use parachutist (coming from the side), also only boarding shotgun
    wuji likes this.
  8. Benkei
    Liu Xing can't Parachutist now neither if the denesting is real, and those 12 points get the Santiago 1 ARM, a real W (not that it matters), 360 visor, KHD, 1 PH, 1 BS, Stealth, Mines, and a quite strong CC presence. More than worth it, much more; basically it turns every one of the LX weaknesses and turns them into strength
    Also, loving that "only Boarding Shotgun", because AD template weapons are always so bad.
  9. Mc_Clane
    Mc_Clane Zhànzhēng bùzhǎng
    Long ya panzerfaust B+1 and Flanmmenspeer B+1, Makes some kind of sense due to the ammo. They can't repeat the panzerfaust +1B. can they?
    Somehow the Guijia becomes a seraph
    This TAG goes nowhere. I Don't like it. too expensive
    Well, I'm surprised to see that mimetism -6... It's not a bad solution but feels like a total capitulation over the "were gonna make something like the shikami but not exactly like it" stated when it first apeared.
    the koalas could be a solution to the problems of forward deployment without marker state... but they are a weird as fuck solution for this troop. A solution only for one profile and the kind of solution I've would expected on the zencha and not the hulang for ground control and protection.
    Plus, I don't see the point for the non froward deployment versions even with a multi and the point reduction.
    BS attack: shock? that's it?
    And we loose the regeneration AP HMG from C1? seriously?
    I didn't like the C1 makeover... but this seems even worse
    Looses CC-3 to the rival
    Looses Martial arts (Lv2 on C1, Lv3 on N3)
    Looses Specialist oterative
    Looses Nanopulser B+1
    Looses PARA CCweapon (-6) compared to C1, and electric pulse compared to N3
    gains +2PH
    gains +2ARM
    gains +3BTS
    Gains 1 unconscious state
    gains triangulated fire
    Something is off with this profile... seems half baked. I don't see the point of taking it over a crane or over it's lighter version
    This is the only profile I see quite interesting
    #49 Mc_Clane, Sep 18, 2020
  10. Triumph
    @Mc_Clane I don't think they're real dude. @ijw already said they're not.
  11. colbrook
    Technically real, but out of date, unfinished, not proof read, and not final.
    Benkei likes this.
  12. Mc_Clane
    I don't know. what is clear to me is that whatever this is... is half baked. I don't need to be an insider to see typos and errors everywere
  13. Teslarod
    Looking at Wildcats, who have an official N4 Profile, relative to the rest of the terrible terrible dead Profiles I've seen in there, we're looking at a 90% done forecast.
    You can see the small changes everywhere, but often it's just not enough.
    LI isn't changing much, what's good now stays good, what wasn't didn't get the revision necessary to keep up form what I've seen (but did get a revision).
    N4 doesn't look like it's going to be a good place to be a MI.
    HI seem vastly improved and so seem TAGs, even if that's not final.
    DZ bound Camo seems cheaper or level compared to before. Infiltrating Camo is a mixed bag, if you were good at CC you're usually cheaper.
    With improved and cheaper high stat budget troops the expensive inbetweeners turn into a big question mark. Usually despite also dropping a point or three, simply because the optimized 2W dude next to you dropped 5 (and a bunch of things dropped 7, 9, or even double digits).
    I'd very much appreciate if Wildcats weren't in the same ballpark as their (true) 2W competition.
    Even if this isn't final, it's somewhere on the road to what will be. And it's too far away from the goal I was hoping for.
    Either way there's a bunch of really cool stuff in there I can't wait to play with. Learned to live with N3 and N4 looks to be at worst more of the same.
    WiT?, barakiel, Aldo and 1 other person like this.
  14. colbrook
    Bear in mind IJW has spent the last few weeks proofreading final profiles before they get added to Army. So he would know.
  15. Benkei
    This is 100% my stance after looking at all the leaked profiles. Just kinda sad it feels like a missed opportunity in some regards.
  16. ldgif
    ldgif Well-Known Member
    Whether it is currently updated or not, Hundun got HD on all profiles in the leak.
  17. Mahtamori
    My guts tell me this is data predating WB N3 release. Best we can see is direction and I like the direction of Long Ya and Hulang.
    90% done is still one helluva error margin. Sun Tze with 4-2 MOV? Doesn't seem likely. Sun v2 going down 11 points while Sun v1 doesn't budge? No.
  18. ldgif
    So not to stir the pot, but the Domaru shown in the Studio update matches the Domaru in the leak.
  19. Amusedbymuse
    it's a safe bet that some things might have been done at that point of time while other weren't even touched. Or this is the biggest troll ever. Or N4 is going to be unplayable :)
  20. ldgif
    Yeah I imagine not everything is correct, but it does show to the naysayers that there is some credibility to the leaks.
