Marut in N4?
Discussion in 'ALEPH' started by StuporMundi75, Sep 26, 2020.
  1. Nemo No Name
    That's not strictly true. While Smoke doesn't give you -6 agaisnt Fireteams, it does help you pick the fight with the weakest member instead of whoever is on the lookout.
  2. regelridderen
    regelridderen Dismember
    The Marut can definitely win a firefight against anyone, but stacking the odds in your favor is not a waste of orders, as your opponent will be less likely to avoid damage. It also depends on who is the source of the smoke. A chain myrmidon won’t accomplish much beyond chugging smoke. While an officer with CoC can accomplish specialist tasks while moving into position and showering the Marut with smoke.
  3. Hiereth
    Hiereth AI Artichoke
    How about, two Maruts. Will probably end up investing in the old model just in time for a new one to be announced, so if we have two models we might as well run two right?
  4. Nenyx
    Nenyx Well-Known Member
    Indeed. With the TAG discount, and netrods being veteran, it's quite doable. Now we can field 2 TAGs, one of the best engineer, big hacking cover AND a zayin just in case someone would still think he could get through. I would like to see the opponent's reaction :)
  5. xagroth
    I strongly disagree. 1 smoke on top of the Marut allows her to:
    1. Cherry pick targets without calling all ARO on the fire lane.
    2. Discover a Camo marker and Fire at a different target (no attack order against a camo with no LoS => the marker gets no ARO).
    3. Improve odds against enemy troops without Sixth Sense or MSV 2+ (MSV1 can fire back with a -3).
    Also, if you manage to cover her with smoke during you opponent's active turn (because a "disposable" 16pts Myrmidon did a special smoke dodge and suceeded to cover both himself and the Marut), the enemy can suffer some trouble due to incoming fire from an ARO piece they can't see, this seems to not have changed from N3 (where I did use such tricks both with smoke and White Noise, even if the WN option is harder to survive... it's like having albedo)
    I tried to make a dual Sphinx list in Shas, not as good as one might thing. Both get to 8 troops (3 netrods, 1 EVO, 1 lamedh, Dart & Parvati with 1-2 Yudbots)
    RolandTHTG likes this.
  6. Nenyx
    Yeah, it's not optimal at all, but it may be quite fun. And no one would expect the 2 maruts.
    Thias likes this.
  7. Iver
    Iver Human Plus
    My regular opponent has been threatening me with double Jotum since N4. Now I know what i'll do to one-up him.
  8. Axelius
    Axelius Not a Rogue AI
    Hmm, very much just theorybuilding, but this doesn't look absolutely terrible to me. You could swap the Posthumans and the CSU for Parvati, although you do lose two button pushing bodies and an order.
  9. SneakyOrk
    SneakyOrk New Member
    Why Evo hacker? Danavas have good Wip and upgrade oblivion for anti hacker. This list is for frontline and similar objectiv not for heavy button smash. gr8AIE9wZXJhdGlvbnMgU3Vic2VjdGlvbiBvZiB0aGUgU1NTgSwBAQwBgkkBAgACgkkBAQADglUBAgAEgMABAQAFglUFAgAGg7YBAgAHgk8BAQAIglEBAQAJglEBAQAKglQBAQALglMBAQAMglMBAQA=
    Apollon likes this.
  10. wes-o-matic
    wes-o-matic Meme List Addict
    I've been trying to work out how to make the Marut work in N4; I was just dabbling a bit with OSS at the tail end of N3, and with the release of Phalanx I've started back in on working out Aleph lists.
    How do these look for a starting point with N4 Aleph to support a Marut?
    Smoky Marut
    [​IMG]10 [​IMG]1
    MARUT (Lieutenant, Strategos L2) MULTI Heavy Machine Gun, Heavy Flamethrower, Nanopulser / AP CC Weapon. (2 | 99)
    [​IMG] KARKATA Flash Pulse / . (0 | 0)
    ATALANTA (Total Reaction) MULTI Sniper Rifle ( | TinBot: Discover [+3]) / Pistol, CC Weapon. (1.5 | 44)
    GARUDA Tacbot (Forward Observer) Combi Rifle, Flash Pulse / PARA CC Weapon(-3). (0 | 20)
    SCYLLA (Hacker, EVO Hacking Device [UPGRADE: Trinity (+2 Damage)]) Boarding Shotgun, Pitcher ( ) / Pistol, Shock CC Weapon. (0.5 | 41)
    [​IMG] 2X DEVABOT CHARYBDIS Heavy Flamethrower / PARA CC Weapon(-3). (0 | 14)
    DANAVAS (Hacker, Hacking Device Plus [UPGRADE: Oblivion (+1B)]) Combi Rifle, Pitcher ( ) / Breaker Pistol, CC Weapon. (0.5 | 22)
    MYRMIDON Chain Rifle, Nanopulser, Smoke Grenades / Pistol, DA CC Weapon. (0 | 16)
    NETROD . (0 | 4)
    NETROD . (0 | 4)
    SOPHOTECT Combi Rifle, D-Charges / Pistol, CC Weapon. (0 | 31)
    YUDBOT PARA CC Weapon(-3). (0 | 3)
    4.5 SWC | 300 Points
    Not bad, but the myrmidons are kind of bland. Needs more heavy weaponry:
    Smoky Spicy Marut
    [​IMG]10 [​IMG]1
    ATALANTA MULTI Sniper Rifle ( | TinBot: Discover [+3]) / Pistol, CC Weapon. (1.5 | 39)
    PHOENIX Heavy Rocket Launcher, Nanopulser, Smoke Grenades / DA CC Weapon, Heavy Pistol. (1.5 | 35)
    SCYLLA (Hacker, Hacking Device [UPGRADE: Trinity (+2 Damage)]) Boarding Shotgun, Pitcher ( ) / Pistol, Shock CC Weapon. (0.5 | 41)
    PROBOT (Deactivator, Repeater) ( ) / PARA CC Weapon(-3). (0 | 8)
    LAMEDH Rebot Flash Pulse / PARA CC Weapon(-3). (0 | 7)
    6 SWC | 300 Points
    ...wait, my LT is a giant target. Better pick up some CoC:
    Cautiously Smoky Marut
    [​IMG]10 [​IMG]1
    SHUKRA (Chain of Command) Boarding Shotgun / Pistol, CC Weapon. (0 | 24)
    SCYLLA (Hacker, Hacking Device [UPGRADE: Trinity (+2 Damage)]) Boarding Shotgun, Pitcher ( ) / Pistol, Shock CC Weapon. (0.5 | 34)
    [​IMG] DEVABOT CHARYBDIS Heavy Flamethrower / PARA CC Weapon(-3). (0 | 7)
    NETROD . (0 | 4)
    NETROD . (0 | 4)
    6 SWC | 300 Points
    Hmm. Maybe too cautious. Just add Parvati for that sweet sweet Engineer +3.
    Inevitable Marut
    [​IMG]10 [​IMG]1
    PARVATI Submachine Gun(+1B), Flash Pulse ( | GizmoKit, MediKit) / Pistol, CC Weapon. (0 | 38)
    NETROD . (0 | 4)
    NETROD . (0 | 4)
    6 SWC | 300 Points
    Any feedback on these?
    Intended uses: Marut does Marut things. Atalanta as an active second threat vector, or nasty ARO option; park a yudbot next to her if possible to stand her back up if needed. Smoke to permit unfair advantages to Marut and Atalanta, via either Phoenix or Myrmidons. Lists with Scylla EVO allow for Fairy Dust on the Marut, or jump assistance for the Garuda if applicable. White Noise allows Phoenix to counter MSV snipers. Baggage to reload the Danavas pitcher. Lots of repeater bots and at least one regular hacker in the Danavas to apply Targeted. Sophotect or Parvati to keep the small number of troopers from getting smaller.
  11. Angry Clown
    Angry Clown Well-Known Member
    marut is a beast.
  12. DukeofEarl
    DukeofEarl Well-Known Member
    Any reason why the middle two have regular Scylla and not EVO or is that just a goof? She seems redundant with the Danavas as a regular hacker to me and I'll be honest the cost just for Fairy Dust seems a bit much. I do like the heavy hitter aspect of the lists though. What about these variations?
    Blackout Marut
    [​IMG]10 [​IMG]1 [​IMG]1
    NETROD . (0 | 4)
    NETROD . (0 | 4)
    EUDOROS Mk12, Nanopulser(+1B), Eclipse Grenades / Pistol, DA CC Weapon. (0 | 41)
    5.5 SWC | 300 Points
    Eudoros is a swappable unit for a few other situations, Shakti is the same points for example.
    Protected Marut
    [​IMG]10 [​IMG]1
    SHUKRA (Chain of Command) MULTI Rifle, Nanopulser / Pistol, CC Weapon. (0 | 26)
    PROBOT (Hacker, EVO Hacking Device) ( ) / PARA CC Weapon(-3). (0.5 | 15)
    BOUNTY HUNTER Submachine Gun, Akrylat-Kanone / Breaker Pistol, PARA CC Weapon(-6). (0 | 12)
    NETROD . (0 | 4)
    6 SWC | 300 Points
    This one has some flexibility in the lower points for sure to adjust to personal preference. Shukra is more there for the Counterintelligence and protection against Isolation than if the Marut goes down, but still handy in all aspects of that. I wanted to fit a CR myrmidon in there, but wasn't as happy with the way it played out. Downgrading Parvati to a Sophotect would work in that case though.
  13. wes-o-matic
    Multiple hacking AROs via a repeater network can be helpful, and normal hacker Scylla is more of a toolbox than EVO Scylla, so including both regular Scylla and Danavas allows for multiple AROs to deal with intruding enemy hackers or inflict Spotlight. The fact that a Targeted trooper suffers both a +3 to be hit by regular attacks and hacking—and also suffers -3 to Reset—means that even without a missile bot in the list there's merit to Spotlight AROs.
    The Danavas brings White Noise and Scylla brings Charybdis bots with repeaters. The idea is to leave the Danavas in the DZ and push Scylla and her bots into the midfield to complete objectives or threaten the opponent's pieces, and use both of their pitchers along with the various REMs to seed a hacking network that should make life hard for the enemy's troops in the DZ and midfield. White Noise on a Charybdis bot could be useful in helping Scylla advance, or screening your other troops against MSV opponents. Scylla, Phoenix, and the Danavas lack MSV, which means that among other things Scylla and the Danavas can fire Pitchers through White Noise to avoid being shot in ARO by an overwatching MSV sniper; Scylla will likely get better numbers once she's advanced a bit.
    It's actually harder for me to justify taking the EVO Scylla profile, but I wanted to include a list option with her since she's potentially a better escort EVO for the Marut than a regular EVO REM.
    DukeofEarl likes this.
  14. DukeofEarl
    That all totally makes sense. Thanks for the reasoning.
