Jammer & Intuitive Attack
Discussion in '[Archived]: N3 Rules' started by HANGMAN, Mar 4, 2020.
  1. HANGMAN
    HANGMAN Member
    Hello,
    Quick question for the masses...
    FAQ states
    Q: When performing an Attack with a Jammer, is the roll affected by the negative MOD of ODD or Camouflage, for example?
    A: No, in the case of an attack that does not require LoF, the negative MODs are not applied.
    Does this include an intuitive attack against a model in the camo or TO camo marker state?
    Thanks!
  2. inane.imp
    Yes. Intuitive attack is not affected by visual MODs.
    So low vis, poor vis, ODD, any level of Camo, cover are the main (all the?) visual MODs.
    Things like the Suppressive state and Full Auto still affect it.
    HANGMAN and Diphoration like this.
  3. Diphoration
    Diphoration Well-Known Member
  4. inane.imp
    Huh. I always remembered the Suppressive as affecting it. Goes to show you should always check the rules.
    Cheers :)
    DukeofEarl and HANGMAN like this.
