ITS 13 and Biker Bounty Hunter AVA
Discussion in 'ITS' started by Triumph, Oct 1, 2021.
  1. HellLois
    Well. Army update with a BIKE RECON Motorized Bounty Hunter, and this way we can cover the ITS Rule when you add it for free on your army list! ^^
    Have in mind, that now you will see two MBH, the normal one (if your army have access to it or if the SoF is selected) and the BIKE RECON MBH, the one you use on the missions.
  2. burlesford
    Why does it still cost points though? The SWCs are taken out, but not the army points.
    Nuada Airgetlam likes this.
  3. Nuada Airgetlam
    The list shows point values, but it doesn't cost points. Here's both of them.
  4. Mahtamori
    I think technically having it have a points cost but not charging for it allows the unit to control zones where applicable and to add to victory points.
  5. Triumph
    So if we go to a tournament with a mission that has bike recon, we just add the ITS bike profile to both lists we submit even if we end up using the list in non bike recon missions?
  6. Tristan228
    @HellLois there's no Bike Recon MBH available in Starmada...
    Furthermore will the gratis-MBH's points then count in order to dominate ZOs or are they added to the killed points or even counted as victory points?
    #46 Tristan228, Oct 20, 2021
  7. kghamilton
    kghamilton The_Omnishambles
    Thanks Hellois!
    Unfortunately the points on the iOS mobile app are still there
  8. archon
    In the app, the Bike Recon MBH still cost points, that will be added to the list, causing an illegal list.
    Can I upload that in OTM?
    I would say yes, it's part of your army and it is worth its point value, but you don't have to pay for it.
  9. tox
    Guys, it is "just" for the Play Mode.
    You submit your standard Army List to the referee / OTM and when you play the relevant mission you simply add him to the group you want and press PLAY.
  10. Mahtamori
  11. Triumph
    It's showing up in the Army Web app too. Sectorials like IA that don't normally have access to a bike can put this ITS Bike recon in their lists. @Zoe bug?
  12. Mahtamori
    The Bike Recon unit is for missions with the Bike Recon special rule...
  13. Triumph
    Yeah, but it's contrary to what Tox is saying that it only should be in apps for play mode rather than list creation.
  14. Mahtamori
    Ah, the browser doesn't have a play mode? I never use play mode so I just assumed it was there as well
  15. tox
    You have it in the browser because not everyone use the Play mode.
    So you can add manually to your list and print it all the same.
    It is not intended to be added to your submitted lists.
  16. HellLois
    Not a bug. The ITS BIKE RECON cause the rule states: both players can add one Motorized Bounty Hunter (any weapon option) without applying Cost or SWC. So, even your army hasnt acces to the MBH, with Bike recon you can have the option to add to your list.
    The Army mobile will be updated with this, Google and IOs has to accept the update.
