ITS 13 and Biker Bounty Hunter AVA
Discussion in 'ITS' started by Triumph, Oct 1, 2021.
  1. ldgif
    ldgif Well-Known Member
    I think a lot of us just assumed 100% free and not conditionally free.
    Robock likes this.
  2. Hecaton
    Yup. This is a big part of why any event I run is likely to not use those rules.
  3. Triumph
    Ok I didn't start this thread with the intention of causing an argument and contradiction, honestly hadn't even thought of the ramifications, but bear with me here:
    If we take this ruling where it counts for AVA then we need to basically build and submit illegal army list that only works for some missions as the biker needs to be submitted with the list to avoid going over AVA, so OTM needs to able to accept 11 man combat groups with 16 model limits. This also means players deciding to utilise this rule lock themselves into an issue where they may be locked out of using lists for each mission at an event. This seems like a bad idea.
    Was the intent of the rule to basically add a bike to each army for free as a 16th member in certain missions? Are we supposed to submit lists with this in mind or are you supposed to just put an extra model on the table when you get to a certain mission?
    #23 Triumph, Oct 1, 2021
  4. dijit
    dijit Active Member
    This is what I assumed after first reading the posts on Facebook. Anything else just seems to add problems.
    Robock likes this.
  5. Triumph
    Yeah I have no intention of being a pedantic idiot over wording matching RAW, given understanding what the intent behind the rule was it's easy enough for me to TO missions with it.
    #25 Triumph, Oct 1, 2021
  6. Lawson
    Lawson Well-Known Member
    Yeah, it would've been this simple except for the weird AVA requirement.
  7. Lawson
    What about the question no one's been asking...
    Where are we gonna get our turrets from?
    unclesrouce likes this.
  8. Hecaton
    This seems to be pretty consistent with the ITS seasons, there's these additions that seemed like they were analyzed in the "Wouldn't it be cool...!" step and not given any more thought other than that. Do they just ignore feedback from WarCors? Because I haven't heard anything good from them about this either.
  9. Nuada Airgetlam
    Three of those are in the Defiance terrain pack. Feel like you missed out yet? :|
    Robock likes this.
  10. Lawson
    I guess I'm going to be designing some more tokens, then...
  11. Pierzasty
    Pierzasty Null-Space Entity
    If I ever play this crap, I'm just gonna use Aristeia Jackbots from Customeeple.
  12. HellLois
    You can use the Defiance ones. In the tournament pack Fiddler have two jackbots, that you can use it like turrets, and also we are going to update the ITS Tokens PDF with Turrets tokens.
  13. Mogra
    Mogra Well-Known Member
  14. Willen
    Willen Well-Known Member
    That is is nice base, the rather bland weapon can be replaced with a Monstrous MakingsĀ“ Combi to make it more detailed as well.
  15. MattB89
    MattB89 Well-Known Member
    Isn't this gun an O-12 HMG? Kind of weird that they didn't use an actual combi rifle.
  16. HellLois
    STOP THE MACHINE!
    I made a mistake (yep, im human) It doesent count for AVA. We will add that profile in the Army that take all tha considerations (no cost, no combat limit and the AVA) so there were not problem.
    Sorry for the inconvenients.
  17. spears
    spears Well-Known Member
    Does the bounty hunter count for points scored/killed etc?
  18. Ugin
    Sooo.. does the MBH from Bike Recon, contribute to the order pool? Can Pano now get another regular order, by having Jean and a free MBH?
  19. Triumph
    Doesn't say anywhere that they don't generate orders as normal, so probably?
    Can't really begrudge Pan-O an extra order in a combat group when shit like IA is rolling around running 15 orders through a single link team tbh.
  20. Mogra
    Irregular orders do not go to the order pool, but with Joan the order will be converted to regular and it will go to the pool.
