Invincible Army Pre Pre Mortom
Discussion in 'Yu Jing' started by atomicfryingpan, Nov 29, 2018.
  1. colbrook
    Really? All the skins have been metal so far.
  2. Triumph
    It's labled as an Aristeia release not an Infinity release, so I'm assuming plastic.
    If it is metal I might use it for my Guilang sniper as I've already converted that mini into a combi Guilang.
  3. colbrook
    Spartimus, Clockwork Parvati, Hexxer Witch, and Pirate Gata were all labelled as Aristeia releases and were all metal.
    paraelix likes this.
  4. Triumph
    Well I'll take it then
  5. banthafodder
    Hoping for double pistols.
    I thought all the alt skins were metal.
    Kallas likes this.
  6. Joametz
    Oh god, I didn't even know I wanted that so badly until you mentioned it!
  7. psychoticstorm
    Hi, alternative skins for Aristeia:3:are always metal models.
    colbrook and A Mão Esquerda like this.
  8. Section9
    That answer is 2. Tai Sheng NCO Mk12, HMG, Tinbot, Haidao, and Shang Ji HRL. Sure, in theory you could stuff 4 in there, but then you're losing out on at least one Wildcard.
  9. Alphz
    Alphz Kuang Shi Vet. Retired.
    I think the implication from some posters has been that all CB *should* release is HMG's and combis because why would anyone take any of the other zuyong profiles...
    My very first link had tai sheng, bsg, missile, HMG and Haidao. But I guess I'm just a scrub.
  10. paraelix
    paraelix Seed Embryo Scholar
    Only model that raised my eyebrow for the starter was the Liu Xing hacker. I guess it can lead a double life as a generic BSG Liu Xing... But if I'm going to throw 38 points at one, it'll probably be the Multi, D-charges, Specialist Operative version.
  11. Alphz
    Yeh, I would have preferred the multi but the bsg is ok. I know CB love sculpting hackers.
    It's a Shame heavy infantry hackers get such a raw deal.
  12. paraelix
    At least the majority in IA (not the Liu Xing, though) have access to a linkable TinBot B. Which can be stacked with Fairydust for a -9 to enemy hackers before any other modifiers...
    EDIT for clarity - Yes, still just a -6 vs KHDs because they ignore Firewall.
  13. Alphz
    Fucking killer hackers, ruining everyone's fun.
    -Ghost- and Kallas like this.
  14. Triumph
    Kaleidoscope exists for dealing with them.
  15. Miraclebutt
    Miraclebutt Well-Known Member
    Obviously that is only an issue if you have AHDs or KHDs in your Zuyong link, but nobody takes the Shang Ji AHD, and your Haidao KHD should probably be safely Cybermasked until you need them if they're not in your Zu link. There's a viable argument for having the KHD in the link itself, but I feel like the MSV2 version is much stronger offensively since if you need to hack someone, you can do it through the Pangguling FTO where you'd be getting the firewall benefit anyway.
    Honestly most of my IA lists lately have started with 2 Chaiyi, a Weibing, and an EVO Pangguling and are then built from there. The supportware flexibility from the EVO is enormously beneficial to IA.
  16. Mahtamori
    While you could bbe correct for any other unit, Zuyong has 14 profiles of which 4 are HMG of which we have 1 release, 1 is Multirifle of which we have 1 release, 7 are combi of which we have 0 releases, 1 is BSG of which we have 0 releases, 1 is missile launcher of which we have 0 releases.
    By sheer statistical probability, the likelihood that people will want multiple Combi is very high. This is not only limited to the Haris profile, but also utility profiles like the unit's only specialist and the only Number2 in faction, neither of which are TacAware.
    BSG is probably the unit's profile people are least likely to field and the ML while a good choice and a more relevant release than Multirifle (IMO) should still be ranking fairly far down anyone's list.
    If the FO had a BSG, then sure. If the ML had TacAware... maybe? It's not only about min-maxing, but overwhelmingly about unit profile and ability distribution.
    I'd go so far as to argue that this is the first time when 3x Combi would probably have been the best possible weapons distribution for the starter!
    EDIT: Or better yet, one of them wielding two breaker pistols akimbo, with a slot for a gun on the back so weapon conversion isn't only easy but utterly trivial.
    #516 Mahtamori, Dec 6, 2018
  17. Alphz
    And I'd point out thwt differentiating between the multi and the combi when you'd happily field a dude just weilding pistols is trying to build a mole hill.
    Seriously, CB have definitely released some question mark boxes. You're drawing a long bow to say this one is from any point of view that isn't about min-maxing.
  18. Mahtamori
    No, mate, because the pistol/CCW weapons have always been officially universal miniatures. You can accuse me of min-maxing all you want, but since I'm going to spend real money on a real physical item, I'd rather that item be useful. The BSG won't ever be useful, just like the Zhanying ML which I've never used as ML.
    Ten Thousand Arrows and Zewrath like this.
  19. Alphz
    And that's boo for you. I'd also rather spend my money on useful things, which don't match with your perception of useful things.
    Gamers certainly like to think they're literally the only person buying a product.
  20. Mahtamori
    Then by all means, what's your source for that these two models are a better release?
    I do note that the number of weapon options indicate that the likelihood of further Zuyong releases are... slim... because of this as well.
