Invincible Army post mortem
Discussion in 'Yu Jing' started by Triumph, Oct 16, 2018.
  1. jimbo slice
    jimbo slice Well-Known Member
    @Teslarod You are right. I've been fighting the flu for the last few days, guess it's hitting me worse then i thought :mask::hankey:
    Teslarod likes this.
  2. ambisinister
    ambisinister Broken Zoetrope
    Exactly. Strategos is at its best in low order elite lists, especially lvl 3. You’d think Sun would be one of the ways to help keep IA competitive in the absence of netrod style units.
  3. Alphz
    Alphz Kuang Shi Vet. Retired.
    If turn 1 Tarik attacks are wrecking face in your meta consistently, something is wrong. The terrain or the way people are playing their lists.
    The fact someone has to leave kuang Shi and pangguling in the open indicates a horrifically open table.
    Even our least favorable tables don't force a player to have leave models exposed to dz or near dz firelanes.
    This would also explain the reliance on strong ARO or dominance of link ARO presence.
    Balewolf and krossaks like this.
  4. ObviousGray
    ObviousGray Frenzied Mushroom
    Or, a Chain Rifle dominating stone age field.
    Overall mentioning and one-sided opinion about absence of ranged ARO can mean a hellhole of total covers for Warband CR party.
  5. Alphz
    @jimbo slice sorry quoting on phones is hard.
    Yeh Alpha can work, particularly against a poorly deployed opponent. But it's a risk, one which only becomes greater against a competent opponent.
    Triumph is implying even the best yu Jing player us pucked because we don't have oniwaban or Raiden. And I'm struggling to understand the logic.
    With 8 orders, my opponent has to advance into my dz to kill my important stuff. That's 3-4 orders minimum.
    Kill the warcor/cheap aro. Normally two layers. 2 orders.
    Get through at least 1 kuang Shi or Shaolin. Let's be generous with 1 order.
    That's 6-7 orders. You now must kill my best troop on the table in 1-2 orders. And there will be another one which will kill you unit.
    More efficient units are more likely to die to chain rifle or crit AROs.
    JSA units didn't change this dynamic. The risk of an HD tac Tao appearing and wrecking you isn't any less scary than an oniwaban.
    YueFei23 likes this.
  6. jimbo slice
    Firstly, I've never played as Yu Jing, so I don't want to comment too much on Yu Jing specific problems. I'm only over here because I've been excited for IA for 6+ years and wanted to join the discussion about what we've been shown so far.
    More to your point, I think that he was complaining more about how the loss of Oniwaban as an option means no one has to be afraid to advance out of their DZ against YJ anymore. Granted, your opponent knew if you took one (Sup Inf roll), but it was still a scary threat. I'm not convinced it's better or worse than a Hac Tao ML. It was just a different option to achieve similar goals. But I don't claim to speak for for Triumph.
    Also, I'm not a big fan of setting up a lot of long range AROs anyway. I prefer concentrating my force and rolling up a flank.
  7. Section9
    Because I typically face 5 mines in the midfield.
    Shikami are very dependent on terrain density.
    Open tables, they do suck horribly.
    Dense tables, bordering on Warband Paradise, they're awesome.
    Dude, my standard Yu Jing Roulette list is a Daofei AHD, Guilang Minelayer, and Guilang Sniper.
  8. Triumph
    I'm not sure if English isn't your first language or you've just gotten lost somewhere in the conversation or something just hasn't come across right, or if it's your phone garbling the message and it's making what you're trying to convey difficult to understand.
    Vanilla Yu Jing aren't, I think you're trying to write fucked, because we don't have Oniwabans and Raiden. However, what we are is limited to a particular playstyle because our range of units and their various playstyles have shrunk, the biggest offenders being the Oniwabans leaving. Yu Jing have a relatively weak ARO presence, it's a faction nuance, but it was offset by the threat of hiding super scary super killy models in a very unpredictably wide range of the table regardless of whether or not they were in the list.
    It caused polarising deployment and movement from your opponent, it's like what the mere threat of a Speculo causes you to behave like whether or not you know a Speculo is in your opponent's list, and in a similar vein, how @ijw is hoping the Shooting Fart's explode rule will cause opponents to deploy differently and behave cautiously, because they might be in a list.
    Now to cover the absence of Oniwabans causing defensive play, being cautious around the mid field etc, the offset you need to make is to strengthen your defenses and your presence during your opponent's turn to decrease his order efficiency. For other factions, that means strong ARO pieces. As we discussed, Yu Jing is on the weaker side there and it's not particularly viable, so the alternative is you simply choke your opponent with garbage. Kuang Shi, Monks, etc.
    Hang on, you're arguing that we use cheap, Chain Rifle toting bodies as ablative armour to slow down your opponent attempting to gain access to your deployment zone and most valuable pieces? What?
    That's my point. That's what I've been saying you need to do.
    I want to go a bit further and remind everyone that Tarik is just once facet of this discussion and try not to tunnel vision on him, the reality is alpha strike pieces come in a a great deal of shapes and sizes, and they often benefit from a second combat group securing their path to your backline before they even spend an order. For example Ko Dali can go on a rampage from the get go if a Speculo takes one order to set her entrance up with a smoke grenade, while your opponent spends a few orders shoving a unidron link onto a central objective. Something like a Dao Fei can and will straight up ignore some or all of ARO pieces by Infiltrating forwards and then just dashing between cover using his marker state as a shield.
    Trying to argue "Oh, Yu Jing isn't hurt by losing invisible board pressure! You could stop Tarik with XYZ" is a pointless argument. Yu Jing is threatened by hard Alpha strikes as a whole and Tarik is merely one example out of countless of ways to aggressively cripple your opponent's army if they don't have the right composition to stop you. That composition as we are both arguing is to bring literal meat shields armed with Chain Rifles to absorb orders and keep the lighter efficient "trade up" pieces out of your DZ.
    This table is a little denser than normal, needs 2-4 pieces pulled off it but it was set up to be as eye catching as possible on a demo night at the LGS. It's a good example of why sticking stuff in the open is still advisable even on a fairly dense table
    You don't "need to" but it is advisable. Cramming all of your models behind the same pieces of terrain, especially when you're running with 18-22 models and you have 3 55mm bases is a recipe for trouble. Grouping everything up can cause some horrific high value hits for your opponent that has template weapons. Things like Daylami, Grunts, Hardcases, Shotgun AD troops can and will destroy your shit and I've learned the lessons the hard way that accepting casualties and treating disposable units as disposable with the express intent of wasting orders is better than risking these crippling hits.
    Additionally grouping up is a sure fire way to cripple yourself if your opponent has some form of speculative fire. Particular mention is the increasing prevalence of Mine Dispensers and Drop Bears, they can do some ugly things to your army especially if you've got say a whole bunch of impetuous order troops packed into those hiding spots. In that game against the Rudras I mentioned earlier if I didn't do what I did and packed all my troops in behind a few pieces of cover, that Rudras would've done some disgusting stuff.
    Taking shots at this cheap trash does not feel good to your opponent and on the Panguulings I find they're actually flat out ignored 4/5 games because my opponent is too busy trying to deal with the more important warband troops and also get their half of the mission objectives underway, especially in season 10 where stuff like the Xenotech is causing even more stress on the order pool.
    #608 Triumph, Oct 20, 2018
    Zewrath, banthafodder and jimbo slice like this.
  9. Triumph
    TBH I could never bring myself to waste that SWC on such a mediocre piece when you could have a better effect with an FO Guilang and put the guns on the Daofei. And if I didn't need the specialist I'd turn that Guilang into a Boarding Shotgun every time over a sniper, we've got so many better options in house for long range fights.
    That's not to say I've never tried her. My BRV Guilang used to sport her MSR, but after many attempts and failing to impress anyone or do anything meaningful, it was converted into a rifle.
    #609 Triumph, Oct 20, 2018
  10. Section9
    Guilang Sniper because the other major pieces are usually a Zuyong Automedikit HMG LT and Yan Huo HRMC. Got plenty of dakka, needed something with range and marker state.
  11. Triumph
    yeah, my point there would be you give the Daofei the gun and make the Guilang an FO or Shotgun one. You get the range and the marker state on a much better platform, and it can now abuse SF mode with camo as well.
    Laughably because AHD's and the Guilang MSR are overpriced you now also save some points.
    If you're hellbent on the AHD because I'll admit it stealing TAGs is actually a fun thing to do, just turn the Guilang into the AHD and give the Daofei the gun, you get +1 WIP to boot on your AHD out of this trade. There really isn't much of a good reason to make it the MSR.
  12. banthafodder
    Yeah, a lot of the best Alpha Strikers are that way precisely because they have a relatively easy way to get there. Not all of them can take them can take our best hitters, but they can take down our other troops, the order batteries and mission specialists just fine.
    And a lot of the scariest lists in this regard, have multiple combat groups to both Alpha and steal the bacon.
    And in regard to the sheer bredth of Alpha Strikers, when I tried to compile a primer, post Uprising, Pre TAK, the vanilla Ariadna section alone almost broke me.
  13. Zewrath
    Zewrath Elitist Jerk
    Literally all Interplanetario tables I played :joy::joy:
  14. Koni
    Koni BanHammer
    Be careful with your language towards the rest of the forum users. This thread deserved to be closed a few times since its opening.
    And I recommend you to wait until IA become fully unlocked at Army before...I don't know how to say in English...in Spanish is "hacerse mala sangre". Google it.
    Have a nice weekend.
  15. Section9
    google says 'to be made (into) bad blood', I'm guessing there's a bit of a colloquialism there, and it means something close to "don't lose your mind" (or a bit more vulgarly, "don't get your panties in a bunch").
    I admit, I am really concerned that the two new-cool-models chosen to get people excited about Invincible Army are so far from what people had been talking about. If the Zhencha really does have Shock Immunity (or Bio), that's about what I was expecting it to be, a lighter/cheaper Daofei.
    But seriously, Koni, would it have killed someone to say, 'The Invincible Army troops MIGHT not all be traditional Heavy Infantry'? That would have avoided a whole lot of hate and discontent.
    Kallas and Zewrath like this.
  16. krossaks
    krossaks Well-Known Member
    Mala sangra means try to be more negative don:'t try to be more negative in porpouse. And my recommendation for people that heavy disappointed with new is to just do it. Take a break from this part of the forum and relax.
    And pl note that different metas implie different point of view about units ( for exemple in my zone most Yu Jing players just pick a ninja in hidden and abbandon completly the midfield do the damm Ariadna camo Spam and nomad camo spam)
    Ps: try lunah, it's the only ARO ypu may need
  17. krossaks
    Probably, but i suspect that some people where just wating an oportunity to rage, and saying might just wasn't enought to stop them
  18. psychoticstorm
    I strongly advice to wait and see the whole army released.
    YueFei23, Joametz, Badlazzor and 2 others like this.
  19. Triumph
    I am apparently one of the few who already use her according to the army data. She's passable but she' s nothing special, and she pays points bloat for a literally useless skill marksman LVLX and a stupid CC 17, which feels pretty bad, and nobody can really come up with a good reason for a sniper to pay for Stealth other than "Muh Aristiea fluff".
    If CB fixed her bloat and brought the cost down a bit or dropped the bloat and upgraded her to proper camouflage you'd see her played alot more I guarantee it.
    Or at least just fixed Marksmanship lvlX so it wasn't a worthless rule jesus christ how hard is that to do? It's nearly 2019 for christ's sake we have the technology.
    #619 Triumph, Oct 20, 2018
  20. eciu
    eciu Easter worshiper
    Well OSS probably wont be able to field any meaningull (more than Dakini) link team if Marut is taken.
