Infinity Dice Calculator
Discussion in 'News' started by toadchild, Dec 5, 2017.
  1. toadchild
    I've updated the dice calc with PanO and Combined Army changes. I'll try to push them out incrementally this time, rather than waiting until absolutely everything is done.
    coleslaw, ijw, Icchan and 4 others like this.
  2. toadchild
    Also updated Ariadna and Yu Jing. The Ariadna updates are all Vulnerability (Viral) on dog-warrior units, but I haven't coded the new Total Immunity rules yet.
    coleslaw, BLOODGOD, Icchan and 4 others like this.
  3. Cartographer
    Nanoscreen doesn't seem to be automatic, have to manually add in cover.
    coleslaw likes this.
  4. toadchild
    Hmm, that’s accurate. I never re-evaluated that one after the N3 rules change to make it not care about direction of attack. I’ll add it to the list!
  5. toadchild
    New Haqq profiles are live (and the Monstrucker, too, since that is part of Ramah)
  6. toadchild
    New merc profiles are also available.
  7. toadchild
    Dice calc is updated with the Tohaa/Spiral units, and the Guard changes. Additional skill updates will be forthcoming, but this should be all of the unit data.
  8. Section9
    Awesome, thank you!
    toadchild likes this.
  9. toadchild
    As always please report any data errors you encounter; bug reports improve both this and MayaNet.
  10. Cartographer
    It seems that Martial Arts isn't applying its negative modifier to an enemy Dodge, unless I'm doing something very wrong.
  11. toadchild
    Hmm, it’s possible I messed that up. I think ikohl has the same issue. I’ll take a note and try to fix it - I just haven’t had as much time/energy to spend on this tool lately.
    inane.imp, Urobros, jherazob and 2 others like this.
  12. sevinkydink
    sevinkydink Well-Known Member
    Is the die calculator open source as well?
  13. toadchild
    It is, although it is not particularly beautiful or extensible code. You can definitely tell it’s an extended series of weekend hack projects.
    https://github.com/toadchild/inf-dice
    inane.imp, BLOODGOD, Icchan and 3 others like this.
  14. sevinkydink
    My kind of style :D
    jherazob and toadchild like this.
  15. Section9
    Is there a "buy toadchild a coffee" tip jar someplace that would improve your energy availability? :innocent:
  16. Section9
    I may have found a glitch or a gap in the programming, trying to have both models 'dodge'.
    Well, the Active Drago is trying to Dodge Shinobu's Engage ARO, which should be a FtF roll. But the calc is treating it as two separate Normal Rolls. Maybe we need to add "Dodge-Engage" as an option?
  17. toadchild
    Thanks for the thoughts but I mostly prefer to keep money out of it.
  18. toadchild
    Can you get me a rules reference on that? I don't actually have any idea what happens if you have a dodge vs. an engage.
  19. Mahtamori
    Both are dodging effects and neither are attacks, so it's normal rolls. Beats me which model is placed first, though...
    Edit: Actually... I do know what happens.
    Since Engage is an ARO, this means the Dodging trooper is active and will not get a Dodge move. Dodge in resolution requires the model to be Engaged in order to separate, but the Engaged state happens after effects have been resolved.
    So, they will be normal rolls and regardless of if the Dodging unit succeed, as long as the Engaging model succeed it will be placed in base contact with the Dodging trooper.
    #159 Mahtamori, May 16, 2019
  20. Section9
    Fair enough!
    Huh, I'd thought that since the Engaging model is attempting to enter CC, the Dodging model would be able to evade the B2B contact even in Active Turn.
    OK, nevermind then. Saw something that looked weird and reported it here, instead of looking up why it looked weird. Mea Culpa!
