Infinity Army Bugs
  1. khayne666
    khayne666 New Member
    Trying to add Ko Dali into OCF and it won’t save or print but is all correct otherwise including tick.
  2. locksmith
    locksmith comlog active
    Mcmurrough is listed as Regular Impetuous in the Daedalus Falls Profiles
    In Army6 he is Extreme Impetuous
  3. khayne666
    Yeah this is my problem too!
  4. archon
    Courtesy List in OSS list Asura Spirfire Lt. L2 as Lt L2 ! This should be private information, I guess.
    Invincible Army: Zhanshi Profile shows no Spec Op (I hope there will be a Zuyong Spec Op Version).
    Edith: It look like they are all gone, I could swear I´d seen this on wednesday ...
  5. TheDiceAbide
    Any idea when the updated Spec Ops experience rules will be put into Army? They’re SUCH a big improvement.
  6. Gaffles
    Gaffles Member
    Unable to load any saved combined army or any of its sectorials lists. Not loading old ones created before update nor new ones created afterwards.
  7. RobertShepherd
    Can confirm I'm having this issue too.
  8. Hecaton
    Nexus Spec-Op is lacking the stats and skills of a basic Nexus.
    EDIT: This on Army Mobile only. On the browser/desktop version of army, the badge and top name for the Nexus show up as "treitak spec ops."
    #488 Hecaton, Apr 1, 2019
  9. Sabin76
    Looks fine in army. HD1 and V:Courage
  10. Hecaton
    Busted on Army Mobile.
  11. Sabin76
    Gotcha.
  12. emperorsaistone
    +1
  13. holycannoli
    I don't know if this has been reported yet. But the unit badges seem broken when using the Daedalus falls NA2 profiles as soldier of fortune mercs on Infinity Army. This also shows up when exporting/printing the army list. I can confirm this is with multiple sectorals.
  14. Hecaton
    I can't load any of my lists (For OCF) that I create either on Army Mobile or the browser version on army mobile. Essentially, loading lists seems to be broken on Army Mobile.
  15. psychoticstorm
    Did your lists include Ko Dali?
  16. Hecaton
    No.
  17. RobertShepherd
    If this is about not being able to load combined army lists - no, not for me. Multiple new shasvastii profiles though.
  18. Zoe
    CB Staff Warcor
    Yesterday I uploaded an update which should have fixed this error. (Ctrl + F5 or update the app to version 6.0.2).
    If still cannot load the lists, send me the code that you will find in your profile (https://profile.corvusbelli.com/me/armyList).
    Thank you and sorry for the inconvenience.
  19. Karmano
    Karmano Member
    I'm having a consistent error with the Web - PC version. Whenever I move an unit within the list (by dragging with the mouse), an empty line is created, and if enough of them are created the units on the bottom will no longer appear, and the scroll bar doesn't appear either. Since there is no way to delete the empty lines, the only workaround is to start a new list. (just confirmed now it also happens on the Web - Mobile version, but the scroll bar keeps working)
    Don't know if it's related, but it has become common to have lists not being saved properly (or not loaded properly), with units disappering from the list when I load them. For instance, I save a 300pts list, with all the units, and when I load it has only 270 pts, with 30 pts worth of units gone.
  20. Nitroflaherty
    Nitroflaherty Member
    Having same issue loading CA lists on app. Works on mobile web version though numbers replaced with text e.g eleven instead of 11 on profiles
