Infinity Army Bugs
  1. DukeofEarl
    DukeofEarl Well-Known Member
  2. DukeofEarl
    but the unit is showing the skill in Army, hence reporting it as a bug
  3. psychoticstorm
    Ah I see, when did that show up there?.....
  4. DukeofEarl
    I'm guessing....today? :laughing:
  5. Mcgreag
    Mcgreag Well-Known Member
    The Specialist version is still listed in the Profiles PDF for JSA.
  6. n21lv
    n21lv SymbioHate
    Libertos extra profiles in the PDF lists them as available to Spiral Corps, but in Army thees are only available to Dahshat Company. Which is correct?
    KestrelM1 and Hiereth like this.
  7. DukeofEarl
    Considering they aren't on the list for Spiral Corps at all (they get Helots instead), I'm guessing the PDF has the typo
  8. TheDiceAbide
    It appears the Specialist Operative version of Saito has been removed from JSA. Probably because the Saito entry in the Mercenaries section states that profile is Druze only.
    According to the JSA profiles section of the most recent doc they should still have access to that profile.
    meikyoushisui and Hecaton like this.
  9. DukeofEarl
    Miranda Ashcroft Authorized Bounty Hunter is giving a Regular Order in lists. Checked in all Vanilla factions.
  10. Hecaton
    Kerr-Nau is not displaying as a Character:
  11. Hecaton
    There's some other bug where the game doesn't count all your orders correctly, and you can end up with negative orders in a combat group. I'll try to recreate it.
    EDIT:
    It seems to be related to these blank spaces that pop up between profiles that you can't remove:
    #471 Hecaton, Mar 28, 2019
  12. Hecaton
    Also, Ko Dali's profile isn't working correctly in Army; clicking or right-clicking on it once it's in the roster doesn't have the intended functions. And the "Print courtesy list" and "print list" functions don't work properly when she's in the roster.
    EDIT: In the desktop version of Army, I can't save any lists with Ko Dali either.
    #472 Hecaton, Mar 28, 2019
  13. Lazarus0909
    Lazarus0909 Well-Known Member
    Might have missed this one in another thread, but Rafiq has an FTO option in QK that doesn't do anything (no Maghariba in QK). Who is it supposed to duo with in QK?:
  14. Sabin76
    Web version of army doesn't have the updated icons for the Noctifer or Corax Hasht. Mobile app does.
  15. Brother Smoke
    Mobile app worked for a couple of days after the update, even opened it this morning, but it is now back to the same error:
    Application Error
    The connection to the server was unsuccessful.
    (file:///android_asset_www.index.html)
    I have scoured the net for answers but can't find anything that isn't back-end
  16. emperorsaistone
    Is it intentional, that the Muyib Spec Ops cannot buy a Panzerfaust with XP anymore?
  17. ijw
    As per the Spec Ops rules, you're not allowed to double-up on anything.
    emperorsaistone and DukeofEarl like this.
  18. Space Ghost
    Space Ghost Well-Known Member
    As a follow up to Lazarus0909's comment above about the Haqq Rafiq REMs, for HB it's showing two identical Rifle/Light Shotgun options, one for 16 points and the other for 17. Neither says anything about Fireteam Duo, so I'm assuming the 17 point option had Duo edited out and is therefore redundant, at least in the case of HB.
    Note that the new HB Rafiq with the Red Fury is also 0.5 SWC and 22 points, even though it doesn't have Duo either - not sure if this should be a point less, to reflect the lack of Duo, but it's still a great new profile!
  19. Lostaris
    Lostaris Member
    Army app on android: you cannot add a uberfall to a foreign company list, or even load one in via the import code.
    #479 Lostaris, Mar 29, 2019
  20. ijw
    Flash Pulse still needs the Non-lethal/No letal/Non létal Trait to be added.
