Infinity Army Bugs
  1. Sabin76
    It happens to me too in Chrome. It's a minor annoyance, but I think I noticed it several months ago, so it's not entirely new.
    I can't seem to post images from google drive, but here are a couple links:
    This is before I add a unit. Note that the window is sized appropriately.
    This is after I add a unit. Note that the last unit is no longer visible as the window has not resized with the addition.
    Let me know if the links don't work.
    #401 Sabin76, Feb 7, 2019
  2. DukeofEarl
    DukeofEarl Well-Known Member
    Not sure if this would be considered a bug exactly or a conflict with drivers. I have two printers at work and neither is able to print the colored range bands correctly. I just upgraded my system here. Prior to that the local printer worked fine and the network one had similar issues. Now they both do.
    Does anyone have any thoughts?
  3. tox
    1) Have you tried to print to pdf? Do you have the same problem?
    2) Are the 2 printers the same model? Do they use the same driver?
  4. DukeofEarl
    The PDF comes out fine and prints fine as well from both printers.
    They are different models. A HP LaserJet Pro 400 and a Toshiba eStudio 5055c.
  5. oldGregg
    oldGregg Well-Known Member
    This happens to me as well.
  6. Nuada Airgetlam
    Yep, Chrome as well.
  7. DukeofEarl
    Invincible Army SpecOps can not select weapons on either base profile.
  8. locksmith
    locksmith comlog active
    CSUs have Fireteam: Duo in Army. This doesn't match the wiki.Same problem in ISS
    #408 locksmith, Feb 12, 2019
  9. colbrook
    Technically that's correct, all CSUs in any faction have the Fireteam: Duo Special Skill as it's part of their profile, but only StarCo and OS are allowed to form CSU Duo Fireteams.
  10. locksmith
    Yes, I'm asking for the notation to be updated to indicate that.
  11. colbrook
    That's my biggest problem with Army at the moment, there is no notation about non-special Fireteams, and they bizarrely include Fireteam: Core in the skills/equipment section where it absolutely should not be.
    Sabin76 likes this.
  12. Zoe
    CB Staff Warcor
    Okay, I keep trying. Make sure you don't have any browser addon that generates that error. :sweat_smile:
    Thank you.
    I'll check it out, but I'm afraid it's going to be a problem from your printer.
    CSU Duo Fireteam is allowed and totally legal on the following sectorial armies:
    - NeoTerra
    - Imperial Service
    - StarCo
    - OperationS
    :sweat_smile:
    locksmith and colbrook like this.
  13. Triumph
    Glad for this update.
    I have a question though. For Imperial Service the Authorised Bounty Hunters still have the same problem the CSUs had. They have AVA 2 and Duo on their profile in Army, but they have no fireteam option listed in the wiki. Is this intentional?
  14. colbrook
    Ikari too!
  15. Triumph
    Ikari don't have Duo on their profile so one would assume that's intentional they don't get a fireteam. The Imperial Service ones do have Duo on their profile though so either the wiki or their profile should get updated there.
  16. colbrook
    Fair point, but I thought it was worth asking.
  17. Triumph
    The main point being that Army lists it as a legitimate fireteam like it did with CSUs like so for ISS. It doesn't do that for Ikari when you print a list. So one way or another there is a definite bug here for either Army or the Wiki as they have conflicting information.
  18. sorniak
    sorniak Well-Known Member
    Is it bug or feature: can you have up to two holoecho states (for example have a miniature to deploy with only one holoecho)? According to rules you deploy with just three, no more, no less?
  19. colbrook
    Holoprojector 2 is always 3 Echos.
  20. DukeofEarl
    Technically you could have 1 decoy and 1 real if a decoy gets discovered/shot with the real one not revealing.
    The Holoecho state of a holographic decoy is canceled, whenever:
    • It is successfully Discovered.
    • It enters base to base contact with a model.
    • It receives a successful hit that forces him to make an ARM/BTS Roll, or a Critical hit.
    • It breaks Coherency with the other Holoechoes.
    • The real Holoprojector L2 bearer's Holoecho state is cancelled for any reason.
    At deployment though it is all 3 or nothing
