Haqqislam Hopes and Dreams for N5
Discussion in 'Haqqislam' started by tacos, Aug 7, 2024.
  1. Errhile
    Well, definitely a Duo would be easier to maneuver around, make good use of that Superjump.
    Big fireteams are hard to maneuver around with Superjump, at least in my experience (Haris I found to be easier on me), and mixed teams with Superjumpers (while possible under current era N4 rules) get awkward. Add to that Khawarij's relative fragility, and investing serious points into a large number of them stops being an attractive idea...
    Cadwallon and Brokenwolf like this.
  2. Brokenwolf
    I will probably die on this hill, but Khawarijs need NWI. They are currently the only super soldier in Haqqislam without it. If you give them that resilience and AP weapons, they could have a niche in RTF:
    Muktars: Best Shooters
    Nahabs: Best CC
    Namurrs: Resilient Specialist
    Khawarijs: Best anti Tag.
  3. Errhile
    And then you run into the Janissaries, who aren't that much more expensive (especially if you drop some Hortlak into the mix), pack AP Rifles and a Missile Laucher (and Blitzens for the Hortlak!), are good shot, and quite resilient. They are decent all-rounders, and mine have a few downed TAGs to their name.
    Ok, they are not supersoldiers, but don't let that hold you.
    I'm afraid you'd need to find a different niche than "anti-TAG" for the Khawarijs.
  4. Brokenwolf
    Which is fair, but Janissaries are HI, with all associated the hacking limitations. But they also might get a cost decrease if the new Griffins and Orcs are any indication. But I just want my Akbar Janissary doctor back.
    For Khawarijis, I hope they improve in N5. They are beautiful models and I would love the idea of using the box set as two Duos in RFT.
  5. Cadwallon
    Cadwallon Well-Known Member
    The role for khawarij, like CB try to do in n4, should be versatile, able to do a lot of things, but not better that the specialiced supersoldier.
    Cheers.
    #145 Cadwallon, Nov 26, 2024
    Brokenwolf likes this.
  6. Errhile
    That would be great.
    But how to achieve that, that is the question.
    Without falling into the jack of all trades, master of none trap, as well as the trap of slapping on several abilities, and driving the cost through the roof.
    The military-religious brotherhood of Khawarijs, the "Red Turbans", was founded by a group of HaqqMuztazilite sages to protect Haqqislam from its foreign and domestic enemies. It is a tough, audacious light assault force of supersoldiers that recruits its members individually.
    - that's the fluff I was able to quickly find online.
    Then there is the one trademark skill of Khawarijs they always had, and by which they are recognized: Superjump.
    So, if you want to play the game, guys, I'd suggest wiping the slate clean on Khawarijs. Then put the basic requirements on the board. Khawarijs are:
    • Superjump-capable. It is an ability normal humans don't have (unless assisted by, for example, a jetpack) so it is enough on its own to make the statement of their supersoldier nature valid.
    • Religious (because they come form a religious brotherhood). This may also represent their audaciousness (as they tend to hold their ground in Guts check) and / or toughness (for the same reason)
    • light (whatever thet means, Obviously, likely not TAGs, HI or REMs).
    Anything beyond that is okay, as long as it covers these three requirements above. From here on, gentlemen, the sandbox is oyurs.
    Brokenwolf, Papa Bey and Cadwallon like this.
  7. Brokenwolf
    Do you think this could point to a sub-30 point Djanbazan HMG? I am excited!
  8. Papa Bey
    No, not really.
  9. psychoticstorm
    More or less correct.
  10. Brokenwolf
    Hope springs eternal.
    Here is the comparable N4 Govad:
    MOV CC BS PH WIP ARM BTS W/STR S
    4-4 15 12 11 14 2 3 1 2
    Skills and Equipment: Multispectral Visor L1, Religious Troop, Veteran
    Heavy Machine Gun, Breaker Pistol, CC Weapon
    The N4 Govad is the same price and SWC as the N5 Tanuki HMG, which gets MSV2, BS+1, CC+2, Dodge (+3), Immunity (shock), Number 2, and Terrain (Total) in exchange for WIP+1 and a Breaker pistol. This gets me excited for the N5 points formula and hope that it benefits all factions.
    Cadwallon likes this.
  11. Papa Bey
    If it didn't, this is all a giant waste of time.
  12. Brokenwolf
    I can work with at 14-17 point drop in price. Maggie looks great and I am excited for a Plastic Model!!
    Urobros, Ephrilune and Cadwallon like this.
  13. Papa Bey
    Plastic is for the weak.
    saint likes this.
  14. Brokenwolf
    Its for the people who didn't want to spend $80 on a single model :grinning:
    Urobros likes this.
  15. Brokenwolf
    Thanks @Wizzy
    They still didn't bring back my Akbar Doctor, but I will take the point savings, large direct Template, and improved gunfighting.
    Urobros and Cadwallon like this.
  16. Cadwallon
    I agree with @Brokenwolf about Jan doc. We have to assume him to be a specialist for missions instead for a combat doctor because a lot of our troops lacks cube. I think they work well with Azrail.
    BS-3 IS nice, and look like quite common in n5.
    Gain pulzar to compensate shotgun changes.
    Theirs cc weapons lost shock trait, but gain heavy pistol instead normal ones.
    Cheers
    #156 Cadwallon, Dec 5, 2024
  17. Brokenwolf
    They are so improved. The tinbot LT is not a bad Lt. With the N5 changes, they have a myriad of uses now in Vanilla. A Missile Launcher/HMG pure duo could be fun. Or using the tinbot profile with a mukhtar hacker or Shakush. Or the doctor with the Asawira AP Spitfire or Azra'il. Hopefully, you can continue to duo them in N5 Vanilla.
    Cadwallon and Urobros like this.
  18. Urobros
    Urobros Well-Known Member
    I wish it was the case, but I think regeneration isn“t cheap. But we will see.
    About the new "Jenny" I really loved what they did. Simple fix but effective.
  19. Brokenwolf
    I hope that the Azra'il gets just Warhorse and maybe a price cut. I love it's ability to destroy it's targets and with the Fireteam changes, BS 13 is respectable.
  20. Errhile
    Personally I was always wondering why the Azra'il weren't Religious (in either N2, N3 or N4), given they are all former Janissaries...
