Forming Fireteams: a Summary
Discussion in 'Rules' started by ijw, Mar 26, 2018.
  1. ijw
    As long as "When creating a Fireteam: Haris or Duo, the Fireteam belongs to the unit of the trooper with the Fireteam: Haris or Duo Special Skill." still gives you a Fireteam listed on the Sectorial Chart, sure.
    Azuset likes this.
  2. Azuset
    Azuset Well-Known Member
    For examples sake in Invincible Army:
    I can swap out a Hiadao for a krit dou and make a hiadao + Guija link, correct?
  3. pedrogzc
    pedrogzc Well-Known Member
    But for the haris you still need the troop that do it possible. IE a yadu haris fireteam still needs a yadu haris trooper, that can't be replaced by the wildcard.
    Enviado desde mi Mi A1 mediante Tapatalk
  4. ijw
    No, definitely not. You MUST include someone with the Fireteam: Duo Special Skill.
    Azuset likes this.
  5. Robock
    Robock Well-Known Member
    I guess Special in the sectorial charts count as Special Haris & Special Duo (whichever case applies to the trooper's note) ?
    Example: In Foreign Company, Bolt can make Haris and Special, if you take a Bolt Haris + another bolt + hannibal, that is a Bolt haris which is ok because Bolt can make Haris. Then if you take two regular Bolt + Hannibal Haris, that would count as a Hannibal Haris fireteam. But Hannibal cannot make Haris, only Specials. It is still ok, right ? Because it really is a Special Haris, and Hannibal can make Special Fireteams.
    Edit: 2nd example. Scarface and Cordelia both have Duo and can make Special Fireteams. If you take both you could make a Scarface Duo which is ok because it is a special duo. Then if instead you take Scarface Duo + Valerya, you still have a Scarface Duo, which is still ok because it is a Special Duo and Scarface is allowed to make special fireteam:duo ?
  6. Ogid
    Ogid Well-Known Member
    That's right after this 1.7 FAQ. However mind that troops which "count as" can have the Haris and it's still a Yadu fireteam (Shakti).
    You have to follow the sectorial table, the 2 bolts + Hannibal must be listed in the row of the unit with the Haris listed; in this case it can be in both because it's listed in both (Hannibal has the Special Haris listed, yep, it's ok).
    Yes, you have the Duo in the right model and you added a wilcard, it's right (in fact you could also make a Cordelia + Valeria Duo)
    Robock likes this.
  7. Masterblaster
    Masterblaster Well-Known Member
    Seems simple but a questioin came up here: what happens to fire teams in LoL? Do the link members become irregular but the link is still activ? Does the link break? Does the link f.e. the core link gives 5 regular orders to the pool even in LoL?
  8. Ayadan
    Everyone is irregular but the link is still active. If you spend one of those irregular on the link members, the link breaks.
    WarHound and ijw like this.
  9. Ogid
    Imagine the fireteam rules are a T-Rex
    Metal730, Ayadan and ev0k like this.
  10. Xeurian
    Xeurian Well-Known Member
    Right, so in a mixed Securitate link for example, you would get some regular orders from Vet Lv1 but don't go spending the irregular orders on the fireteam members that don't have Vet Lv1.
  11. Masterblaster
    Hope it is ok to take this threat: again fire teams:
    a tournament uses the Spec-Op rule. According to the latest FAQ at least one regular trooper must count as one of those troops. Does the Spec-Op aswell counts like that?
    With a concrete example: OSS Fireteam of Spec-OP (Deva), Yadu (Haris) and Rudra. Is it a legal Haris?
  12. Mahtamori
    The spec ops trooper is not obligatory, but if you do take one in an ITS event with spec ops extra it acts like a trooper of its origin, including consuming AVA. The Haris in your example contains one of 5 allowed Devas and is a legal Haris.
    The best illustration of how Spec Ops work now is the preview of the O-12 Kappa. Notice how Spec Ops is similar to Forward Observer here?
  13. pedrogzc
    The ava of spec ops is independent from the troop it represent. At least in Steel Phalanx, you can take 6 thorakites + spec ops and the army gives it as good.
  14. Mahtamori
    This is an issue with Army. If you read the Spec Ops rules you'll find that they explicitly take up AVA from their originating unit.
  15. pedrogzc
    Thanks, I will check it.
  16. Doa
    Doa Well-Known Member
    Hi guys, sorry for bothering but I have a big doubt
    I have a khawarijs Haris, a khawarijs and a ghulam.
    Since khawarijs count as ghulam for fireteam composition, Cai I form a ghulam Haris with those pieces?
    In wiki ghulam does not have Haris option
  17. colbrook
    Like you said, Ghulam don't have the option to form a Haris, so they cannot.
    Additionally, as per the latest FAQ the Fireteam type matches the trooper with the Fireteam Skill, so if the Khawarij has the Haris skill it is a Khawarij Haris, which Ghulam can't join.
  18. Mahtamori
    I think you are correct, but I have to nitpick that I don't agree with your explanation.
    Khawarij count as Ghulam, which means if Ghulam could have formed a Haris then the Khawarij Haris profile would've been able to form a Ghulam Haris. (But as you noted, they can't so Khawarij Haris is the only useful option)
    It's an important distinction as otherwise e.g. Patsy doesn't work.
    colbrook likes this.
  19. colbrook
    Yeah, I've double checked and it looks like they've used the same language for Patsy and Khawarij.
    So if a Ghulam Haris was on the Fireteam list then a Khawarij could be the one with the skill. But it isn't, so they can't.
    Mahtamori likes this.
  20. daszul
    daszul Well-Known Member
    So can Patsy form a Duo with a Cutter?
