Dealing with Flyers
Discussion in 'Yu Jing' started by Space Ranger, Feb 9, 2026.
  1. archon
    I also think so. A rule to fix an issue with another rule (or the complaints that a flyer can only go out of iso and imm on a 1, which is bad, yes). Better make them touchable if they are imm (like they slowy sink because their AG device fails working).
    Tristan228 likes this.
  2. Law Dawg
    Getting back on topic - Red Eye is the only flyer in my meta for now so I've not dealt with other flyers yet. What are people's experiences facing flyers of other factions?
  3. Brokenwolf
    While that would be great for simplicity, it would also allow people to engineering repair flyers, which would make things even worse. So I am fine with this minor rule.
  4. archon
    only if they are imm ;-) and also would be vulnarable vs cc attacks.
    #24 archon, Feb 13, 2026
  5. Space Ranger
    I went against the Go Pod. MSV can only get rid of the Mim-3. Not the BS -3. But if you do it hit it, it's only ARM2. So even small arms can potentially take it out.
  6. Space Ranger
    I FINALLY used the Feiquan. I had to use a proxy. I don’t like proxies but wanted to try it. It was the Multi-rifle, in White Banner, vs. Shasvastii.
    I can say it was, ok. I had an ideal situation playing against Shasvastii to use its sensor. I used it once out of LoS to discover a Seed Soldier and once in LoS to discover a Shrouded. But both of these were things I could have done with a Weibing. The movement was nice but again I could have done nearly the same with the Weibing and its Tac Aware order. Even with all the movement when I was trying to shoot anything they were outside of 16” and the X-Visor didn’t do much since it only brings the -3 down to zero. Better than nothing but not helpful against the mim -3 and cover I had to deal with. It was taken out by Corax mid-game. Having only a single Akrylate to shoot over 16” kind of sucks. I wish they gave both versions the +1 SD. The Mim -6 is good but then No Cover so rule. Not so good. Corax was only at -3 with 4+1 dice. So, at most I accomplished to use Sensor twice.
    I’ll keep trying it. I want to give it a chance. But I still feel it needs a weapon that can get a +3 over 16”. If they just changed it to a Multi-Marksman, I’d be happier.
    I know some like the Pitcher version. But I’d only take that if I had hacking in mind from the start. I wish they would bring back Sniffers. Now THAT would be helpful on it. And then after it’s shot its Pitchers, what does it do? I would need to get within 16” to use the E/M Carbine effectively because that version doesn’t have the X-Visor! Then when you do get with 16” you are now inside the enemies +3 range making your Mim-6 less effective. Or worse, inside template range.
  7. archon
    The majority of the flyers have mime-6 and no cover - normaly brings them on -3. If you facing a Red Eye you will be happy that its "only" -3.
    Excepitons are Nomads and Haq with albedo I guess.
    I used the Feiquan now approx 5 times (4 bc in the first game it did not move much and were just providing ARO). I use only the EM Version bc of the SD+1. Last game I end up ambushing a OSS group and divided my fire - managed to Isolate two and took one wound in return. Not so bad, but the isolated LI/MI can return fire ... idealy you encoutner only a singel target or two, but I was running of orders. I still like it and yes, when shoots gets through ARM 3 is not much. If you facing an ARO out of your own range, the dodge-3 is very helpful.
    I like it more and more. At the moment I have no time to play Nomads and test the Go Pod. Switching between YJ and Aleph. The Aleph flyer look also strong on paper with its Multi-Spitfire with inbuild shock ammo ... the Pan O one seem still the strongest.
  8. Law Dawg
    I've had to face the Skyhound a few times and it's gross. It's got AP thunderbolt for HMG range and plasma at short range, all at +1B. It doesn't have sensor like Red Eye but still has discover +6.
    I just got my Feiquan and it's built but not yet painted. Eager to put it in my list. I see it more as a support piece rather than an attacker like the Red Eye or Skyhound. I got my eye on the pitcher profile. The speed and range means I can throw down repeaters and retreat. It can aro with akrylat or flash pulse. +1SD would help.
    archon and Tristan228 like this.
  9. Space Ranger
    I used the FQ again yesterday and it did absolutely nothing. Well I moved up a bit and tried shooting a Nexus in the open no cover. Was in zero range and missed every single shot and it dodge away.
  10. Law Dawg
    Bad luck with the dice. I have fumbled so many rolls that were in my favour. My Longwang though, made 8 consecutive armour saves in my last game. So it goes both ways.
  11. archon
    That says nothing about the Feiquan - only about your bad luck.
  12. Space Ranger
    Yeah it was bad luck. I'll keep trying it. It at least did it's main job. The missions was Crossing Lines and I just wanted to get into a dead zone for points. Just thought of something that would make the FQ automatically better, Baggage! so i can reload it's Panzer and AK. Reload anyone in ZoC. The count for an extra 20pts. Hell if Maggie can have it, why not the FQ?
  13. Papa Bey
    Faction Identity? :D
    Brokenwolf and Space Ranger like this.
  14. archon
    Come on. Keep it serious. Baggage is on slow REMs (except CA) and Maggie is the biggest walking tank infinity has to offer. An agile jetbike / flyer is not the platform for baggage.
  15. Space Ranger
    Just put an Amazon logo on it! :stuck_out_tongue_closed_eyes:
    They only keep to faction identity if it's convenient for them. :stuck_out_tongue:
    Faction Identity went out the window when they gave the Red Eye Sensor.
  16. Papa Bey
    I threw that term into the pot, because I don't think three left over forum posters will agree on what that means.
  17. Space Ranger
    I’ve now used the Feiquan 4 times. I really need to re-learn super jump because I F’d up how it’s done. But anyway, my last game was against MO and I used it to shoot a missile bot on a rooftop and a Tuton out in the open. I admit I was dumb and didn’t use its sensor and paid for that by a Trinitarian coming out of hiding and killing Adil with a BSG. I should have realized it would be near an objective. We were playing Evac and it was near the console. Man, that FO minelaying BSG Triny is too good! I will say that he had the area covered with a thunderbolt REM so it would have been hard to get up to do the Sensor.
  18. archon
    I had some uncomplete games (the time were running out) but I used the Feiquan two times: Vs Varuna it soacks up many orders from Kamau HMG on long range (-9 for the Kamu = 4 and for me also (Range, Cover, Mime-3) with the Akrylat) later I switched to Dodges and then he just walked in the open (should have done it before). Feiquan looses 1 str in the proces - Varuna apporx 5-6 orders ... in my match vs Nomads it did nothing in the first tun (the Brigada Ml was still watching) and fired 1 pitcher later. Far from overpowered.
