Daedalus Fall
Discussion in 'News' started by Ben Kenobi, Mar 4, 2019.
  1. Hiereth
    Hiereth AI Artichoke
    Well he's a mercenary hacker now you see...
    DukeofEarl, Kreslack and ObviousGray like this.
  2. maru
    maru Well-Known Member
    Are bike in KUM unit a Equipment ? so the model per say is a Human on it so 4-4 not 8-6 ??
  3. ijw
    Flash Pulse will have the Non-Lethal Trait added, but the wiki is still being updated.
    ZlaKhon likes this.
  4. Wyrmnax
    Wyrmnax Well-Known Member
    It is not, the B2 from autocannon is still very prone to get you in sticky situations.
    BUT the -9 you can impose due to camo+cover+surprise shot on one action is ridiculously good. On any weapon. Its just that a autocannon mostly need to win only 1 ftf...
    #644 Wyrmnax, Mar 27, 2019
  5. MikeTheScrivener
    How does having BS21 interact with FAT2? Does a crit still trigger on a roll of a "1", even though it's pushed up to a roll of a "2"?
  6. colbrook
    You mean the one that's been listed as Drize exclusive in the profiles PDF since release?
    Looks like they read their own rules at last!
    Splod likes this.
  7. Teslarod
    Like the Deva AHD+Upgrade Lightning was added to NCA and is here to stay now?
    Or just that JSA is his native Sectorial and it just makes sense they should have any sort of Special Profile, which they had access to for the last year.
    Doesn't make sense to just remove it without a comment after that long.
    #647 Teslarod, Mar 27, 2019
  8. CaptainVenge
    CaptainVenge Frog with Light Rocket Launcher
    I think so too, but Total immunity says that "owner doesn't suffer its effects
    You mean that symbiomate is immune to non-lethatl attacks and won't be removed from the table after getting attacked by flash pulse?
  9. ijw
    From Total Immunity:
    • If affected by a weapon or Ammunition with the Non-Lethal Trait (see Infinity N3) that forces an ARM or BTS Roll, owners of Total Immunity won't suffer its effects, so they won't make the ARM or BTS Roll, nor any corresponding Guts Roll.
    From SymbioMate:
    • The SymbioMate must be used when suffering a successful Attack—or being affected by any weapon or rule—that forces ARM or BTS Roll.
    My emphasis.
    ZlaKhon and Abrilete like this.
  10. eciu
    eciu Easter worshiper
    Teutons.
  11. eciu
    What a frikking mess.
    Also:
    So Shasvastii now have 12" Assault ?;P
    (yezz, that MO is just a bunch of cosplayers with their pathethic CC)
    AdmiralJCJF likes this.
  12. Benkei
    Benkei Well-Known Member
    But you don't get Total Inmunity until you use the mate, so you still have to do a BTS roll, which triggers the obligatory symbiomate use. Nice writing.
  13. Hiereth
    Maybe it's just me but this doesn't seem like a clear answer, is the total immunity applied without the actually expenditure of the mate? Or is the mate removed to ignore stun/flash etc
    CaptainVenge likes this.
  14. xagroth
    You are forced to activate the mate, and then make no roll. So it's like the mate from before the nerf :p
  15. CaptainVenge
    The question is - does mate give you totall immunity passively or you have to ACTIVATE it to get the totall immunity (and therefore remove it after the order)?
  16. Nuada Airgetlam
    Flash WILL have Non-Lethal, so you WILL NOT have to make an ARM/BTS roll, so you will NOT activate the Mate and it will NOT be removed.
    Capsed out the logic, not yelling :D
  17. eciu
    Deadalus Fall - The powercreep is real.
    Well at least I can save 60$.
    LuAn likes this.
  18. Bellyflop
    Bellyflop Well-Known Member
    Reread symbiomates. You have total immunity as a skill until the mate goes away.
    A SymbioMate provides its user in the Active Symbiont Armor state an ARM and BTS value of 9—replacing the ARM and BTS values of the user’s Troop Profile—and it also provides the Total Immunity Special Skill
    ijw likes this.
  19. chaos11
    chaos11 Well-Known Member
    That's just when it's activated though, right?
  20. Bellyflop
    No. It gives you total immunity as a skill
