Crit rework proposal
Discussion in 'Access Guide to the Human Sphere' started by Voidrunner, Jul 13, 2021.
  1. Voidrunner
    Voidrunner New Member
    I don't think this crit system is fun for any player (active or reactive). In one game my Hac Tao killed an Avatar. I didn't feel that it was a deserved win to be fair. I didn't pay better, I just rolled luckily on one dice and my opponent lost more than 1/3 of his list (and a game obviously).
  2. Robock
    Robock Well-Known Member
    Hac Tao reactive Missile Launcher wiping a fireteam is not a problem with the crit system, it is a problem with ML templates from Hidden Deployment.
    If you don't like to win by revealing on ARO and wiping a team due to a crit (or equally likely just simply due to rolling high enough and the fireteam dodge rolling poorly), I'd propose you simply don't take a Hidden Deployed ML.
    *the fireteam is dodging, if the team leader shoots he gets FtF while everyone else clipped will take saves if you pass you roll. Team leader can't FtF on behalf of the other members.
  3. Voidrunner
    May be in this case it is better to remove crits at all? They do nothing good for game balance and experience anyway.
  4. Robock
    I lost a TAG to a rocket launcher, not even a crit. just a normal roll that beat all of mine, and fire damage that I roll poorly on my saves. :hankey:happens.
    RolandTHTG and A Mão Esquerda like this.
  5. WiT?
    WiT? Well-Known Member
    If your primary issue is "A lucky crit kills my guy, I can't do anything about it" would your proposed change even fix that? It would just become "A lucky crit and failed save killed my guy..." and I feel that if we took crits out, it would become "my guy rolled five 1s and lost to a 2 and died..."
    Bad luck is a part of the game. I don't adore the crit mechanic but its certainly a lot better than it was. Just not convinced that any 'fixes' proposed here would improve the game or, more specifically, address your issue with it.
  6. Voidrunner
    Issue I think is that you can't even trade your model in this case,since your successes are canceled. I would be fine for example with trading my Hac Tao with his Avatar (it would've hurt my opponent's army more anyway).
  7. Tanan
    Tanan Well-Known Member
    Avatar isn’t invincible and has vulnerabilities. It can be taken down by few good dice rolls.
    If you want 100% safety while advancing, try marker state troopers.
    Also Avatar doesn’t trade with anything. It tries to stay alive as long as possible while killing enemy with near impunity.
    #27 Tanan, Jul 13, 2021
  8. WiT?
    I don't see why you should get to trade your model if you lost the face to face. Especially if that was the specific in-game example you are referring to.
    Edit: Ninja'd
    As an Avatar played, I can 1000% back this up. It can feel invulnerable to oppose it in some games, but I promise that other guy is sweating over every order and every possible vector for some shitter to come and brick his 118 point model lol
    Tanan and Robock like this.
  9. Voidrunner
    Lost because of crit that canceled another successful rolls. Big difference.
  10. Papa Bey
    Thank you. I think that's a clearer way of explaining yourself than the previous attempts.
  11. Robock
    while it is possible you didn't play better, I'm not sure we can say that the avatar player didn't play worse. I'm not an avatar player, but to those who are, would you go FtF with a ML, a panzerfaust or a blitzen ? I mean, sure you have more dice, but if now is the time the ARO wins you are in trouble. It could be wiser to use your backup attacker to hunt the ML first.
    edit: following Mahtamori comment i guess Avatar vs ML was the correct play, but if he did not had a doctor worm or contingency he lost the game due to placing everyeggs in one avatar basket.
    #31 Robock, Jul 13, 2021
    Tanan likes this.
  12. WiT?
    Not really. Its just a part of the same spectrum of face to face resolution that we use for everything else. No different than just one model or the other spiking a good roll and beating the other.
    IE, few days ago I had that Nisse thing from O12 move out and take a shot from my Noctifier. He rolled 4 dice on 7s vs my one on 6s, and my one dice beat his misses and low hits and he died. Unlikely but part of how face to face rolls are resolved.
    A Mão Esquerda and Tanan like this.
  13. Mahtamori
    It should be nearly impossible to lose an Avatar to a Hac Tao in just one Face to Face... Where's Doctor Worm and contingency planning?
    Besides which, exemplifying this with a Hac Tao is probably not a good idea since this is an extremely expensive unit and I'm presuming it's the Missile version which is quite ineffective in the active turn.
    It is quite a bit a game of risk management. Unlike most RPGs and most wargames, where you never face any risk to your own units while rolling (even a critical failure is quite mild in most gaming systems), Infinity is built so that you can keep trying with the same unit several times while you have to be aware that you risk losing it at all times as your opponent gets to fight back (ineffectually if you know what you're doing).
  14. Robock
    crits bring excitement, but if it did other thing instead of extra-saves (or auto-wound in previous edition) it might work. It just would be a major shift in the game. Say, if crits would give you Momentum to use later.
  15. Voidrunner
    Doctor was already dead. Tiger soldier killed him turn before and also some support models. But it wasn't a genius play or anything. All players go for support first and Avatar later.
  16. Ugin
    Assuming the general consensus out of your personal feelings won't help.
    In N3, a Critical hit scored an auto wound on top of auto win, which was quite excessive IMO. It's now changed into an auto win + additional save, which offers another opportunity to survive. I would call it a progression.
    I think uncertainty is also a part of the game. And I also think the current system is fun enough, since it feels like it's at the acceptable level of uncertainty.
  17. tox
    I lost an Avatar to a single D-Charges CC Attack. Higly improbable but not impossible.
    I lost an Avatar in my active turn spending 7 orders against a single Black Friar HRL. Yes, after 7 orders my Avatar died.
    And in both scenarios there where no critical involved. Just unlucky rolls.
    When you propose changes to Criticals, you need to remember that they apply to A LOT of cases and rolls, not only BS/CC Attacks.
    Generally speaking, a Critical wins a FtF roll. Why? Because it applies to EVERY roll. Have a good time coming around how to manage a Critical Dodge with any different proposal (just to say one).
  18. Before Infinity was a miniature game, it was an RPG.
    Their own futuristic-type setting that some friends played with the rules of «Mutantes en la Sombra» (a Spanish RPG from the early 90s), rules that contemplated the existence of the crit.
    In short, the crit, in Infinity, has been around (Edit and Add: almost unaltered ) even before it was a miniature game... and it is extremely highly unprovable that it will cease to be in the rules system, or substantially modify it, in the near (or even distant) future.
    #38 Pettynyt Pelaaja, Jul 14, 2021
  19. Tanan
    Using Tiger soldier to bypass combine army deployment zone defences is genius play. A better combine army player could have probably avoided this fate. I mean that’s one of the reasons why Taighas are in every list, right?
    Also check out Caliban Engineers. They are way better than Dr Worm for this particular role.
  20. Sirk
    Sirk Well-Known Member
    I think in this discussion critical system and ftf mechanic have been conflated. While I also think the latter is the trademark of the game and works pretty well, I also am not a fan of criticals in general.
    One way they could be downgraded without changing all the ftf system could be:
    - for each critical, the player rolling it decides whether to cancel a higher roll OR to inflict an additional wound.
    This would mean that LOW roll criticals would be somewhat less effective as they could be faced, sometimes, with multiple higher hits they cannot cancel. Also, when the critical lets you win a ftf you would not have, you don't also get the extra wound.
    Personally, I would like it more for sure.
