    Daaz, Whaleofforum, cspo and 22 others like this.
  2. Nuada Airgetlam
    That is awesome :3
  3. jmmelo
    jmmelo Well-Known Member
    Painted up my first "Altsawira"... 3 more to come :)
  4. Kumachan
    Kumachan Well-Known Member
    I gave one of my Zond Remote helper bots a marksman rifle. Now I am able to put all three puppets into suppressive fire.
  5. Savnock
    Savnock Nerfherder
    @Kumachan good work, so much cooler than the official minis for the Puppetbots!
    What’s the rifle from?
  6. Kumachan
    It is the rifle of the original model
  7. Kumachan
    I just finished the conversion of my Bakunin Überfallkommado Pupniks. I do like the original models, however I want all my puppets to be trusty little expendable robots as I am currently building a list that uses all Nomads Models with Puppetbots like Puppetronica Company, Zoe & Pi-Well, Jazz & Billie, Interventor & Fast Panda etc…
    7BE162D6-F292-4CB6-9947-B38EB1E82371.jpeg 4779E4C5-D15A-458B-8F3B-2EF25D61B9E1.jpeg 2E2CEA6F-677A-4D81-9C3B-9D8A94468E8D.jpeg 193C5CBB-8FA8-4502-8049-4F02EA7041A6.jpeg
    I will try to mitigate the S1 model vs S2 silhouette in profile with bases that raise the minis higher
  8. Brokenwolf
    Have you thought about a model on the shoulders of another to make them s2? Kinda like the goblins in Warcrow?
    Whaleofforum and Savnock like this.
  9. Golem2God
    Nice use of Dark Eldar/Drukarhi bits.
    Really like your tinbot/puppet conversions.
  10. Tristan228
    Made a new Grenzer sniper since I converted the original one a few years ago:
  11. Savnock
    Savnock Nerfherder
    @Kumachan that is such a COOL idea!! Really looking forward to seeing what you do with this.
    Fed4ykin and Golem2God like this.
  12. Kumachan
    I did, but I figured out that this is a task that is currently beyond my skill level or I do lack the vision to pull this off…
    This is the current solution to raise the Pupniks to S2 level
    I also got an idea of what to do with the leftover Bunny Puppetbot. I switched the boarding shotgun for a shield and uploaded a firewall program - et voila, I have a new tin bot
    #2312 Kumachan, Nov 6, 2022
    Daaz, redeemer, Whaleofforum and 16 others like this.
  14. chromedog
    Komagataheavy is a friend of mine, and is not a her. He's been in the infinity game for a loong time - but spends more time modelling/converting than playing these days.
    Golem2God, Wizzy, Savnock and 2 others like this.
    Conversions of Mavericks and Desesperadoes on horses, from the blog : lead-rising.
    http://www.lead-rising.com/2017/03/operation-cowboy-part-3.html
    http://www.lead-rising.com/2017/02/operation-cowboy-part-2.html
    http://www.lead-rising.com/2017/02/operation-cowboy.html
    Conversions with manga heads, from hey_bert_8d, on his instagram:
    https://www.instagram.com/hey_bert_8d/
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    I have created this index to recap the heads that may be compatible for infinity:
    Index ranges of Heads to convert
    https://forum.corvusbelli.com/threads/index-ranges-of-heads-to-convert.41790/
    Daaz, redeemer, aphexblue and 13 others like this.
  16. Golem2God
    Is there a link of where to purchase these heads?
    Perhaps links to the STL files for those who have 3d printers?
    Whaleofforum and Gwynbleidd like this.
  17. DeepThought
    DeepThought Well-Known Member
    Ok, so I have a design I just got the materials for. I want to create a Marut with 4 full sized arms in place of two large arms and two small ones. I feel it's the only mech-sized unit that justifies more arms than the others, being essentially an XXL robot instead of a pilot driven remote control or manned arm-suit, but I was rather disappointed they made the 2nd pair of arms that hold the gun so small, so I decided to try something unusual: I bought an O-Yoroi with aims to use its large arms for the upper body (which is doable with the O Yoroi arms since it has those shoulder sections in between!)
    In theory, I will have it look something like this:
    (NOTE: Forgive me for the poor perspective, this was a quick rendition using Photoshop to illustrate my concept)
    Loose fitting shows they should actually go in place with minimal problems. If anything, moving the large Marut arms down to where their tiny arms would go will require more alteration to the fittings than the O-Yoroi arms will. The only difficulty is the plastic-on metal. I wish they'd not made the new Marut out of plastic, rather than switch to plastic for this remake of the model, as I'm now seriously worried about the plastic body of the Marut holding up those heavy metal O-Yoroi arms. Any suggestions on how I should attach them so it won't come apart?
    #2317 DeepThought, Nov 14, 2022
    Whaleofforum, Golem2God and Jumara like this.
  18. Mob of Blondes
    Pinning, probably also with some kneadtite cushion to make the parts match without gaps. So make holes in body and arm, put metal pin in one, add putty and press together. Once cured, separate, and glue pin and the epoxy block in one side, then glue to the other part. Some people do it all in one go, without curing the putty first, but it can get nasty if glue or putty starts to flow out when pressed.
    The tricky part here is drilling the plastic (too new and unknown), the rest is basic pinning technique.
  19. burlesford
    I'm just gonna say that I love this idea. Very curious to see the result.
    As for me, with the latest studio update it seems that my repurposed Zondmate that was converted into a Siriusbot will now serve a much exciting, high-mobility role in my upcoming O12:
  20. Angry Clown
    Angry Clown Well-Known Member
    I need two :P
