Cheapo Standing Tokens for Slightly Easier Play
Discussion in 'Access Guide to the Human Sphere' started by Del S, Jun 22, 2018.
  1. Del S
    Del S Tunguskaball
    With Kurage coming, some of us may be fumbling in frustration with our flat bits of card tokens. If only there was an easier way to have camo tokens with their basic silhouette known, or deployable equipment, or even just easier to move markers for fireteams and such.
    Well, there is, there's like a dozen ways, like you can buy some or put those little beady-blob things on to make a token easier to pick up, or you could print off some standing ones on some thin card.
    This is the last option!
    Pretty basic. Print on thin A4 card, use the blank discs as extra supports, and boom, cheap and cheerful tokens and markers that are easy to pick up and move.
    Some of these are recycled from an older post (https://forum.corvusbelli.com/threads/3d-camo-and-imp-markers.1271/#post-17668) but some of them are new! Ish...
    https://imgur.com/a/tKW7yvH
    As a little extra, I did a crude flat objective room. It's not perfect, but place it down and it should give you the boundaries of an objective room for some scenarios. Also put on gates and markers for it.
    [​IMG] [​IMG] (These are crude Generic/NA2/JSA camo tokens)
    Abydog, tox, OCEE78 and 17 others like this.
  2. Section9
    I hate to ask, but could you have pity on us poor 'Murricans, who have to deal with Letter-size paper instead of A4?
    Thanks!
  3. Del S
    Del S Tunguskaball
    I think these should do: https://imgur.com/a/te1pFR0
  4. Section9
    Del S likes this.
  5. Del S
    Del S Tunguskaball
    Small update to cover some ITS11 stuff https://imgur.com/a/wfidav2
    Tried to get letter and A4 sizes from the start.
    Planning to try do a few other ones like some larger camo silhouettes, spawn-embryo, seed-embryo, supportwares. Anything else I should look for?
    solkan, Section9, Abrilete and 2 others like this.
  6. Abrilete
    Abrilete Well-Known Member
    Awesome, thanks!
  7. Del S
    Del S Tunguskaball
    Some Asteroid Blues tokens, namely standies of the characters for being very lazy! A4 and Letter
    Also a few Shasvastii tokens, KO, and Casevac
    Section9 likes this.
  8. Del S
    Del S Tunguskaball
    Did someone say Megalodron?
    [​IMG][​IMG]
    Letter sizes in link. You may wish to try adding other things into the large spaces but since I'm a derp a lot of my earlier tokens are at different resolutions and some adjustments are gonna be needed :P
    #8 Del S, Nov 16, 2019
  9. Ashtroboy
    Ashtroboy Well-Known Member
    Okay so I seem unable to print these out at the right size, please help
  10. Del S
    Del S Tunguskaball
    What's the problem you're encountering?
    I hope to try update the whole lot soon, since I have noticed a few small problems with them.
  11. tox
    @Del S you should create PDF files already fitted in A4 or Letter format to avoid shrinking of weirdness.
    And you need to add a DAZER!!!!
  12. Del S
    Del S Tunguskaball
    That's probably one of the biggest problems to fix actually.
    Also there's inexplicably no official Dazer marker afaik but I can try bodging one together I guess...
  13. Sabin76
    I suggest your current profile pic for the Dazer marker. Looks pretty dazed to me... :laughing:
    Section9, Abrilete, Del S and 2 others like this.
  14. cazboab
    You should see him IRL....
  15. Ashtroboy
    When I try to print at actual size they come out too big and when I shrink to fit they’re too small. A pdf would be perfect, either way thank you for your work
  16. Del S
    Del S Tunguskaball
    Could be a letter/a4 difference but pdfs probably the best fix all round.
